BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > 2012-2019 BMW 3 and 4-Series Forums > General F30 Sedan / F32 Coupe / F36 Gran Coupe Forum > Cool feature, find something, learn anything?
      05-03-2013, 11:47 PM   #947
MarkW83
Drives: F30 330d M Sport
Originally Posted by itwasepic View Post
I just found this out the hard way. I was washing my windshield at the gas station and kept trying to pull up on the windshield wiper arm. After 3 attempts, I realized it was rubbing against the inside edge of my hood and scraped some of the body paint off. Luckily it is not visible. But this is total CRAP design!
Not sure if this is what you mean: but to pull the wipers away from the windshield/windscreen, there is a special process. I can't remember it exactly (have a look in the manual), but it's something like turn ignition on and off, hold wiper stalk in up position for 3 seconds, and the wipers will then stay in an 'up' position, allowing you to then safely fold them back and away for washing.
Hope this helps?
F30 330d M Sport Mineral Grey / Coral Red
Pro Nav/Visibility Pack/Comfort Pack/Harman Kardon/Head-Up Display/Electric Seats/Comfort Access/Adaptive Suspension...
      05-03-2013, 11:53 PM   #948
itwasepic
Drives: 335i
Sorry, I edited the post. I was using the gas station's squeegee to wash my windshield and kept trying to pull up on the wiper blade arm to squeegee under it.
      05-04-2013, 09:09 AM   #949
ric124
ric124's Avatar
Jamaica
452
Drives: F87 M2 BSM MT
2017 BMW M2  [0.00]
My gti was the same way you have to get your wipers in a upward position before you can lift.
      05-04-2013, 09:47 AM   #950
elistan
Drives: F30 328i, AP1 S2000
The reason for this AFAIK is that it keeps the wipers out of the air stream when not in use, thereby reducing coefficient of drag and improving highway gas mileage.
      05-06-2013, 09:41 AM   #951
fj58
Trunk [boot] lid opening
I am yet unsure how "cool" this "feature" is, but my left cheek can, at will, open the trunk [boot] while I am sitting on the porch. . . .
      05-09-2013, 06:42 AM   #952
Left_eye
United Arab Emirates
Drives: BMW F30 335i
2 ways to close side mirrors - Comfort access and FOB
Not sure if anybody mentioned this earlier n not sure if US n Europian specs work like this but here in Dubai when u long hold the 3 lines on the comfort access door handle, the mirrors auto close after locking the doors by couple of seconds. Naturally, mirrors auto open when car is unlocked either by comfort access or FOB. stuff!
And:
Long pressing unlock on FOB also opens all windows n unfolds side mirrors.
Long pressing lock on FOB also closes all windows n closes/folds side mirrors.
Hope that was useful
      05-09-2013, 07:41 AM   #953
Steve33
Steve33's Avatar
Drives: 2018 SQ5
^this
I had an e350 rental car this last weekend and at the speeds my caravan was going, those darn things were smacking the heck out of the windshield. I think it's a combo of keeping them out of the airstream for a barely-measurable gas efficiency reason (I'm sure it saves a gallon of gas every 10k miles. The additional components of it probably cost more than the gas it saves), for blade longevity, and it looks better than a competitor's alternative. (They tried to tuck it, but doesn't go as far as it should IMO... makes it look like garbage)
      05-09-2013, 01:57 PM   #954
Alpine F31
Alpine F31's Avatar
Drives: MB E350 4MATIC Estate
And:
US spec cars don't do this, but they can with coding. My car does all of those things and more thanks to forum member Frogman. He helped me code in all kinds of cool features.
      05-26-2013, 12:52 AM   #955
jw30
Drives: BMW 328i
Originally Posted by CurlyFatAngry
If you try to go in reverse while the door is open, you know when you're backing a little on your driveway with one leg on the ground and the other on the gas? Car won't let you, sounds a beep and forces transmission to P. Pretty cool and annoying at the same time.
I just had this happen to me on my new 335i. I thought I threw it in park and hopped out but quickly found it slowly rolling backwards. Not sure if I accidentally put it neutral but it wAs a little nerving on the second second day having it!
      05-27-2013, 07:19 PM   #956
300hp
Drives: X5 & 335xi
Can someone try this, I just tried it in an X5 but that one has the electronic parking brake. If I start the car with the electronic hand brake on and the door open, the car will allow me to drive it after I release the hand brake and start driving while the door is open. I am away from home and do not have the F30 till tomorrow. Wondering if this works with the manual hand brake but it would be great if this can work on the F30 too.
EBII 2014 335i xDrive
335HP, Sport AT, 19" Wheels, MPE, Prem, Tech, Cold, HK, Driver Assist & DH pkgs
Deep Sea Blue Metallic 2013 X5 35d Sport
Prem, Convenience, Cold and Premium Sound packages
      06-05-2013, 01:02 PM   #957
300hp
Drives: X5 & 335xi
I will respond to my own post above. Yes you can disable the feature that stops you from driving if your door is open. As stated above before you put the car in drive (auto trans), make sure the handbrake is applied. Once you put it in drive, remove the hand brake and you are good to go.
      06-05-2013, 01:17 PM   #958
tdizzle
Drives: 2017 F80 ZCP
I think if you start the car with the door open it'll let you drive it also.
      06-05-2013, 01:46 PM   #959
300hp
Drives: X5 & 335xi
That has not worked for me before but I will give it a try again today
      06-05-2013, 06:27 PM   #960
CHCCubs
CHCCubs's Avatar
Latvia
97
Drives: 2013 BMW 328i xDrive Sport
This does work as I once got back into my car to move it a little further back in a parking spot and was able to do so with the door open.
2013 BMW 328i xDrive Sport Line
Mineral Grey on Everest Grey
      06-05-2013, 06:55 PM   #961
300hp
Drives: X5 & 335xi
Then this would not have been reported as a problem in the first place right (see post 959). The issue was you get in your car and the door is not properly closed, start the car and the car will not allow you to drive and will revert to neutral the moment you hit the accelerator.
What you guys are essentially saying is the car will drive irrespective of whether the door is open or closed.
I am very confused here
      06-05-2013, 09:22 PM   #962
tdizzle
I think the difference is not closing the door prior to starting > putting the car in gear. If you've already closed the door then try to open it and move it acts differently.
      06-05-2013, 09:23 PM   #963
tdizzle
It's been awhile since I did it, but close all doors/lock the car, then unlock it and open the door, leave the door open and start it then put it in gear without closing the door, it should let you move.
      06-05-2013, 09:33 PM   #964
300hp
Drives: X5 & 335xi
Maybe we are skinning the same cat. Lol
I will try it in the morning
      06-06-2013, 07:19 AM   #965
300hp
Drives: X5 & 335xi
Yes this is true, I tried it today. We were skinning the same cat. If there has been no attempt made to close the door the car will move. However if the door has been closed but not firmly shut then the car will not move, the only way out is the handbrake approach.
      06-08-2013, 01:04 AM   #966
adge7
adge7's Avatar
25
Drives: F30 330i MSport
I've had two bits of plastic floating around in my boot/trunk since I picked my car up. Thanks to this thread, I finally realised where they go! They're the bag hooks! I stuck them into the holes and can now hang bags up in my boot. Awesome.
      07-09-2013, 10:54 AM   #967
Maximus_850csi
Member
Maximus_850csi's Avatar
Drives: 2023 F90
2021 BMW S1000XR  [0.00]
2018 YMB F80  [0.00]
Is it possible to change the comfort access to unlock all doors instead of just to the one door that is touched?
      07-09-2013, 10:59 AM   #968
Frogman
Drives: 2012 F30 328i
Sure, just change the unlock to all doors in Settings -> locks
