02-01-2014, 02:55 AM | #1 |
Rep 260
Add tire pressure and temperature to the TPMS display
Hi all,
I have coded the following: F30 HU_CIC 3001 EXBOX RDC_SAFETY aktiv nicht_aktiv Add tire pressure and temperature to the TPMS display And I have checked. Disconnected then reconnected to the car re read and check and the setting is set to aktiv. So this might be a noob question but I assume you see the Temp and Pressure on the NBT under the TPMS settings in the vehicle information. But I don't see Temp and or Pressure. All I see are all the green tires am I doing something incorrect or am I looking in the wrong place? |
02-01-2014, 03:06 AM | #2 | |
Rep 131
There are two system: If your tire valve stems are rubber, then you only have flat tire monitor which compares rotational differences with the ABS Sensor. As a result it won't display the tire pressure/temperature even you coded it. If your tire valve stems are metal, then you have Tire pressure monitor system, so after you code it it should show the tire pressure and temperature (you might need to drive it for a distance before it shows) |
02-01-2014, 03:28 AM | #3 | |
Rep 260
02-01-2014, 06:58 PM | #4 |
Rep 40,310
TPMS does not work in every car. The car has to be equipped with Option S2VBA Tyre pressure control (TPC). If you do not have S2VBA, you will have FTMS. TPMS is Tire Pressure Monitoring System, aka Reifen Druck Control (RDC) and FTMS is Flat Tire Monitor System, aka Reifen Pannen Anzeige (RPA). FTMS operates on tire rotational speed and has no actual sensors to measure pressure and temperature like TPMS does.
12-13-2015, 06:09 PM | #5 |
Rep 157
Hopefully this gets seen as its over a year old thread, but....
I have 2VB Tyre Pressure Indicator when i do a VIN decode online. Is this the same as S2VBA? My stems are metal. I was going to try to code this tonight |
12-13-2015, 06:45 PM | #6 |
Rep 40,310
Yes.
02-01-2016, 02:02 AM | #8 | |
Rep 103
05-16-2016, 08:10 PM | #9 |
Rep 187
Drives: 16' SO/SO F80 ZCP
Does anyone know what could be wrong, I changed the values stated previously, and I have the TPMS system on my F32 but still don't see the values in the iDrive
2016 M3 ZCP, SO/SO, DCT
2014 435xi Msport Estoril Blue , MP brakes 2014 Ram 2500 CTD GTR Bondurant racing school 2006 |
05-17-2016, 03:09 AM | #10 |
Rep 2,302
05-17-2016, 10:33 AM | #11 |
Rep 187
Thanks, I figured out my issue it was late and I kept hitting Code and not Code FDL. Works like a charm, now just need to figure out why my M performamce logo doesn't work.
05-17-2016, 11:17 AM | #12 | |
Rep 2,302
But in this case only in NBT-Unit i think. |
05-17-2016, 12:06 PM | #13 |
Rep 187
You are correct, Code on the individual module will code it to what ever the FA tells it the defaults are, FDL Code will code what ever modifications you programed (TPMS temp).
07-25-2016, 12:43 PM | #14 |
Rep 266
Here is my story ,
My F32 has no OEM TPMS , since I didn't knew it I fdl change RDC_SAFETY to aktiv and RDC to aktiv. Then idrive stopped me to show the green indicator to tyres (RPA suppose) . Also is not possible to reset tyre pressure when car is on idle. At the meantime I retrofit as new set of 19`442M wheels with TPMS sensors. any idea how can I recall RPA (green indication on idrive) for my RFTs ? any idea what part is missing to convert the car to a TPMS ? thanks guys
F32 m428i estoril blue
E65 745i toledo blue Athens GREECE |
07-25-2016, 12:53 PM | #15 |
Rep 266
here is two pics from idrive now ,
I know those seems Greeks to you but , pictures speaking by their selves. no green indication for Runflats no reset for tyre pressurs (I have the same matter with oil level , no reset)
07-25-2016, 02:30 PM | #16 |
Rep 2,302
If you want to use the TPMS sensors in your new tires you have to retrofit the TPMS ECU (antenna).
Otherwise you can not display the tire pressure. To get back the green tires you have to code RDC_Safety to nicht_aktiv and RDC to nicht_aktiv. Then you get back the old RPA. |
07-26-2016, 04:06 AM | #17 | |
Rep 266
07-26-2016, 05:29 AM | #18 |
Schmollbraten
12503
Rep 1,985
Altogether and complete coded it should be appear like this, aside from my metric measures.
Before I got only the green bands onto the 4 tires.
Citizen of ///M - Town, where too much is just right Some say, that my scrotum has its own small gravity field and when Im slowing down that brake lights come on at my buttox |
07-26-2016, 08:21 AM | #20 |
Schmollbraten
12503
Rep 1,985
I'd done no further retrofit, as I got the car, only the green rings were appearing and after some coding the temp and press was also shown.
07-26-2016, 08:46 AM | #21 | |
Rep 2,302
http://f30.bimmerpost.com/forums/sho...highlight=tpms |
07-26-2016, 08:48 AM | #22 |
Rep 2,302
