BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > 2012-2019 BMW 3 and 4-Series Forums > General F30 Sedan / F32 Coupe / F36 Gran Coupe Forum > Horn problem
Studio RSR
      05-06-2024, 09:23 PM   #1
Arkin
Drives: F30 xdrive sedan
Horn problem
Realized for a while, that sometimes I press my horn it doesn't make a sound after a cold start.
Wonder do I have to take the airbag out of the steering wheel to grease the connections behind it? Does it have a have a connector behind that my need to put in the grease like the dielectric grease?
Does anyone have this issue?
F30 335i xdrive
      05-08-2024, 05:45 AM   #2
Skyhigh
Skyhigh's Avatar
1925
Drives: BMW F36
If you google it, you will see quite a few threads or even videos about it. Typically the problem is with one of the two or both horns under the hood, not with the steering wheel switch.
I don't use mine often, but every time I have used it it has sounded a bit "homosexual"... so I also wonder if maybe one of the horns is not out...
Some people report it all goes back to normal after a few seconds continuous honking (happy neighbours).
Dom147102.50
      05-08-2024, 07:49 AM   #3
Billfitz
Billfitz's Avatar
Drives: '15 328iX GT
Corrosion of the connectors on the horns is a possibility. It can be enough to keep the horns from sounding at first but after a while the current can push through the corrosion. Clean them with contact cleaner, dielectric grease should prevent it from reoccurring.
      05-08-2024, 10:41 AM   #4
Skyhigh
Skyhigh's Avatar
1925
Drives: BMW F36
Where are the horns and how accessible are they…?
      05-08-2024, 11:33 AM   #5
Billfitz
Billfitz's Avatar
      05-08-2024, 09:21 PM   #6
Arkin
Thought the connectors are inside the airbag. Will try to take out and put some grease in the horn itself
F30 335i xdrive
      05-08-2024, 09:55 PM   #7
Billfitz
Billfitz's Avatar
I meant the connectors to the horns. You're far more likely to have corrosion there than inside the wheel.
      05-09-2024, 12:52 PM   #8
McGyv3r
Drives: 1989 325i & 2014 335i
2014 BMW 335i  [0.00]
1989 BMW 325i  [0.00]
https://f30.bimmerpost.com/forums/sh...17&postcount=2
Here's how I replaced both of mine.
Skyhigh1924.50
