BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > 2012-2019 BMW 3 and 4-Series Forums > Regional Forums > AUSTRALIA > Very loud clunk and shudder over speed humps
      02-11-2015, 06:05 AM   #1
djw007
Drives: F30 M Sport 335i
Hi there,
Has anyone one experienced a very loud clunk as your car drops down the far side of a speed hump... accompanied by a horrendous shudder?
Its almost like the shocks are stuck and release suddenly.
And to put this in perspective it's not from going to fast, it can happen on small speed bumps at 3 or 4 km/h sometimes.
I even startled a pedestrian in a Bunnings carpark the other day with the noise.
I have mentioned it three times at different service appointments but they have never acknowledged the issue.
Also should mention that not every speed bump will do it, needs to be a particular size/rise/fall, generally a completely smooth sided speed bump will do it.
      02-11-2015, 09:42 PM   #2
MikeVictor
210
Nope
      02-11-2015, 09:56 PM   #3
kommy
Drives: 2014 328i msport estoril blue
I have the msport suspension and my car is quiet over speed humps.
      02-11-2015, 11:02 PM   #4
HFW003
HFW003's Avatar
5683
Drives: 2024 M340i xdrive
I have the adaptive suspension and VSS and mine does it.
      02-12-2015, 03:30 AM   #5
djw007
Have you ever mentioned it to BMW, any idea as to what it is exactly?
BTW i have adaptive too... forgot to mention that.
      02-12-2015, 04:36 AM   #6
ontheway
Drives: F31 MSport 328i
In my much over-thought decision over active vs passive m-sport suspension I read quite a bit about noise in adaptive.
There are some threads elsewhere on this board where people have had similar problems and had them fixed. This was in the US so probably a big argument here...
      02-12-2015, 05:07 AM   #7
HFW003
HFW003's Avatar
5683
I have never mentioned it, did a lot of research when I first noticed it and found it seemed to be a NCO so it didn't worry about it.
It seems to be very much speed dependent so I just make sure I don't go over speed bumps too quickly, besides I'll only have the car for three years, and given my experience with BMW, I can't be shagged!
      02-12-2015, 06:47 PM   #8
Sladester100
Sladester100's Avatar
Drives: F30 320d & G29 M40i First Edtn
Mine used to rattle somewhat like this, no adaptive tho... It would also do it sometimes when on uneven roads at more of a pace. Was incredibly intermittent. After many back and forths to the dealer, two new shocks, suspension checks they then eventually changed the steering rack - perfect.
      02-13-2015, 12:50 PM   #9
digitallust
digitallust's Avatar
98
Drives: 2019 G20 BMW 330i M-Sport
Hi there,
Sounds very similar to my steering rack issue when I took delivery way back in 2012... Was fixed with a new rack and column however I would of thought this would of been completely sorted by now
Check out my old post I think it was titled steering rack issue poll
Good luck
__________________________________________________
On Order - 2022 BMW i4 eDrive40 M Sport Mineral White, Fully Optioned
Current - 2019 BMW G20 330i M Sport Alpine White
Retired - 2018 - Range Rover Velar SE D240
Retired - 2015 - Mercedes Benz C250d AMG Line W205
      02-13-2015, 01:34 PM   #10
Sladester100
http://f30.bimmerpost.com/forums/sho...d.php?t=798642
How did I never see that poll digitallust
F30 320d ED Melbourne Metallic, Vis Pack, Dakota Leather, & Other Goodies
G29 M40i First EditionFrozen Orange
      02-13-2015, 10:46 PM   #11
SteveAus
SteveAus's Avatar
263
Drives: G20 M340iX
Haven't noticed this issue. I have adaptive suspension and VSS.
Because I have a front splitter, I tend to treat speed humps with a great deal of respect.
G20 M340iX, Sunset Orange, Tartufo Merino Leather, Pretty Well Loaded, OEM Aero Kit, Drive Recorder, BlackVue Dashcams removed and replaced with ACE 2.0.
      02-13-2015, 11:12 PM   #12
TiresOnFire
TiresOnFire's Avatar
32
Drives: 2015435i,2015550i,2017M240i
I have the "joy" of driving over a speed hump in/out of my community daily. I take it at 15 - 20 mph. No issues other than an increase in blood pressure. Also no noise issues with the other four BMWs over the past 13 years other than alignment issues I attribute to that flipping hump.
      02-20-2015, 10:38 AM   #13
sk76
Drives: f30 320d
Any update? Mine was built on September 2014 (F30 320d) , After 3000 km starting to have "cluck" noise over speed bump, I drove to dealer have checked the noise was coming from steering rack,They told me there is no solution for this so I send an E mail to BMW HQ they told me there is a update part number for the rack which is improvement ,but not any mention about the noise, now I am waiting a part from Germany, Anyone actually solved this problem? Somebody said the noise disappear after change the tire from RFT to normal tyre because of softer sidewall will absorb the force Anyone?
      02-21-2015, 05:52 AM   #14
Sladester100
Mine disappeared after the steering rack replacement.
When ignition is on (but engine off) if you rock your steering wheel a little it does it rattle slightly too?
      02-21-2015, 09:32 AM   #15
sk76
Drives: f30 320d
Yes it does , When did you change the steering rack do you have part number?
thank you
      02-21-2015, 11:34 AM   #16
silencer2008
37
Drives: 2014 328i MSport
I don't particularly notice any 'clunk' going over speed humps on mine, September 2014 build, with adaptive suspensions as well. Just under 5000kms on the odo....
2014 328i MG , BM3 Stage 2, Injen Intake, M Performance Brakes+ Exhaust, CP + BP, FMIC, High Flow DP, NBT ID6
      02-21-2015, 11:44 AM   #17
Sladester100
thank you
Fraud not no; dealer did it about 6 months back
      03-01-2015, 06:02 PM   #18
Felosenco
Felosenco's Avatar
142
Drives: 428i M Sport Gran Coupe
Hi there,
I experienced this a few days ago, no shudder just the clunk. I took a traffic calming bump a little faster than normal. I have a Gran Coupe 2015 428 with M Sport Adaptive suspension and only 3000kms. I think I would have freaked out a little if I hadn't read your post. It's only happened once and I did hit the bump pretty fast, so I think in my case it was just the shock bottoming out.
2015 428i M-Sport Gran Coupe, Glacier Silver, 6sp Manual, HK Audio
"I fear the day that technology will surpass our human interaction. The world will have a generation of idiots." - Albert Einstein
      05-03-2015, 08:07 AM   #19
Sladester100
Mine's returned
Will post a new thread in general forums to discuss
http://f30.bimmerpost.com/forums/sho....php?t=1122539
