03-23-2022, 01:30 PM | #1 |
Rep 92
wheel alignment specs
Hi,
I just had wheel alignment done after installing new tires on a 2018 440i coupe with stock 704m 19" wheels. I don't know how to interpret the wheel alignment report, so here are a few questions. 1) Based on the report, was wheel alignment necessary? 2) Do the numbers looks fine after the wheel alignment? Thank you |
03-23-2022, 10:59 PM | #2 |
Rep 3,368
There isn't much to do upfront, other than adjust toe. Factory specs are OK, but I feel like they dialed in unnecessary toe which is primary cause of wear, but can make the car feel more planted. I asked for custom specs and weighted (close to 500lbs in car), dialing in toe as close to zero. From the looks of it, they really didn't do much for you other than increase rear toe.
Below is mine, on a 340 for reference...before is all out of whack from lowering the car on new suspension |
03-23-2022, 11:23 PM | #3 | |
Rep 92
