03-13-2024, 03:52 PM | #1 |
Rep 1,384
[DIY] Air vent silver tabs template
These are the final bits of silver in my car that I NEEDED rid of
Everything else has been painted a dark grey and 2k lacquered to make them wear resistant, from the iDrive remote, glovebox handle/lock, ac radio dials, start button surround and steering wheel control packs.. they're all de-chromed/silvered Anyway whilst looking for photos to trace online I came across a few people appearing to have peeling tabs. Not sure how as they're actually aluminium inserts wedged between the plastic, I can only guess people have tried prying them off which you can't FTR. I did plan on painting mine but in the end opted for alcantara to make them soft to the touch. FYI I was only using the red vinyl for testing, that's not how I left them haha. Thought I'd make the template available which I used. The little kick out on the bottom edges of the red half are important, you need these to fill out the space as it folds. If you have a vinyl plotter you'll be able to cut these to the specs below: 2.5cm x 0.68cm was for the front vents, 2.3cm x 0.69cm was for the rear vents on an F32. The front should translate correctly, however I don't have any knowledge for the other cars so you may have to resize it slightly. FYI if you're using a laser cutter you may need to experiment with slight oversizing, the diode will take up some space shrinking the actual shape.
2015 435i - 401whp
Scorpion catless dp, VRSF 6.5" HD FMIC, MST V2 inlet, NGK 97506, MHD Stage 2+ 102, xHP Stage 3, M Performance Exhaust (modified for valved straight thru) Last edited by fortythirtyfive; 03-13-2024 at 04:07 PM.. |
03-13-2024, 04:02 PM | #2 |
Rep 1,384
oh I forgot, I also de-chromed the light switch trim.. that had to go too
Same treatment as before, primed, painted and then lacquered with a 2k matte clear coat.
2015 435i - 401whp
Scorpion catless dp, VRSF 6.5" HD FMIC, MST V2 inlet, NGK 97506, MHD Stage 2+ 102, xHP Stage 3, M Performance Exhaust (modified for valved straight thru) |
