01-19-2016, 08:54 AM | #23 |
1st time BMW owner
Rep 33
Both Look like interesting options, I was looking into the Kenlowe electric plug-in Preheating system as my cold starts would almost always be from home where I have an outside plug. However, something has changed!
My 335d is heating up much faster! Within a couple of minutes on idle I am getting warm air through, less than a minute if I start driving. Within a mile from the house it's hot. I cleared the ice from my windscreen this morning within 3 minutes just with the standard windscreen de-mister. I think a Thermostat might have been stuck and now I've done a few hundred miles it's freed up. |
01-31-2016, 08:40 AM | #25 |
Rep 568
02-01-2016, 07:29 AM | #26 |
Rep 3,341
Drives: 2022 M3, 2022 X5 40i;
I don't know what the issue is here. Unless it's sub zero temperatures, my car's heater generally activates within 2-3 minutes of driving; My heated seats work in less than 60 seconds.
I generally have to turn down the heat dial within 5 miles of driving. The driving procedure should be - turn on car, wait for RPMs to go under 1000, and drive off. Maybe you all have a problem with your heaters or some sort of realistic expectation of when the heat kicks in. |
02-03-2016, 01:21 PM | #27 |
Rep 13
Where I live I get up and go to work at 5am, it's not uncommon for the temperature to dip to -30 C° or lower. The thought of being able to take some of that edge off prior to leaving my apartment and hiking across the parking lot is an appealing one.
02-03-2016, 04:04 PM | #28 | |
Rep 204
Source: http://www.popularmechanics.com/cars...-harms-engine/ |
02-07-2017, 10:48 PM | #29 |
Rep 220
Wintertime Vehicle Pre-Heating
The more I read about auxiliary heating systems, the more I want to undertake this install. In some markets BMW offers as an option but unfortunately I have not been able to find the part numbers on RealOEM.com.
I found that Eberspacher is also a manufacturer for BMW heaters (in addition to Webasco). M&L Automobile in Germany sells retrofit kits. Last edited by Zermatt; 02-07-2017 at 11:33 PM.. Reason: GIF ADDITION |
09-13-2019, 09:46 AM | #30 |
Rep 1
Webasto preheater
Use a Webasto TSL 17.
A kit like this, from any dealer, or even ebay https://shopcummins.com/products/web...SABEgJLkPD_BwE I have one installed in my 2004 Jetta TDI, (hope my attachments worked) I plan to install one into my new 2014 328d. |
09-15-2019, 06:06 AM | #31 |
Regular user
224
Rep 965
Drives: F30 330D M-Sport Auto
Or just let the EGR do it's job.... Oh hang on!
11-06-2019, 07:18 AM | #32 |
Rep 10
Hi,
I have managed to install a Webasto heater in the F30 with the ability to start it via the Connected Drive App. Your Local BMW Dealer would say that this is only possible with the 5 or 7 series vehicle but not the 1 and 3 (F20/F30). I show how to start it either with the iDrive Menu, the webasto remote control or even the Connected Drive App. Here is an example: I have written a manual how you can achieve this even with a cheap Evo 5/5+ branded heater. You do not need to buy the universal kit. If you are interested write me an email: webastoheaterf30@gmail.com and you will get the document. Regards, kombinator-318 |
12-01-2019, 04:38 AM | #33 |
Rep 1,031
Drives: Like a bat out of hell.
I'm waiting for a remote start module to become available for the 2019 model. The installer said their latest unit will only work up to 2016 BMW.
I just had my 2019 Hyundai hybrid installed with Compustar using OEM proximity key fob to start the car. To me, a preheating system seems overly complicated and expensive for North America. |
