      01-26-2013, 08:28 PM   #2333
theothernguyen
Drives: '12 Jet Black 328i Sedan
I don't know.
Is 48.2 the only PSdZData version that you have?
I don't mean to cause you turmoil haha. I only have the 48.2 data right now unfortunately. I will try doing a clean install and rar extraction and such and see what happens...
Very much appreciate your help in trouble shooting, will return later with results!
cheers!
      01-26-2013, 11:59 PM   #2334
steve@codemybimmer
steve@codemybimmer's Avatar
Hong Kong
665
Drives: 2020 G20 320i M Sport
Originally Posted by kon View Post
not sure about 48.1 on 504, didn't try it, but definitely for sure 48.2 works on 504... already coded 2 car with 504, no issue
I can confirm that 12-11-504 does work with 48.1. I didn't realize that I was on 12-11-504 until I checked the integration level today.
I tried to code hrosenberg33's MY2013 today which had 12-11-505 and it actually allowed me to modify and save his VO but when I try to code an ECU, that's when it errors out.
Theoretically, if he goes to a dealership and just make up something to say there's a problem with his CIC Head unit, I have a feeling he will have the extended Bluetooth and iPhone support once they do a software update and code it.
      01-27-2013, 12:04 AM   #2335
steve@codemybimmer
Hong Kong
665
Does anyone know how trip import/export works for the Nav? I read earlier that someone here was able to enable that feature. Do you have to have BMW Assist? Also I enabled BMW Online and BMW Internet on HU_CIC and it didn't enable any extra options. I know I probably have to play with the VO to really do something but would leaving these settings enabled do any harm to the head unit/computer?
      01-27-2013, 03:25 AM   #2336
shawnsheridan
shawnsheridan's Avatar
Google Maps is a better and more efficient tool to generate routes than the BMW Navigation System. You have the flexibility to change routes as you wish and select specific roads from point A to point B. The attached manual (and program) describes how you can generate trip files that can be imported into your BMW Nav system. This is possible thanks to the great programing work of our fellow fester, Aussie40d, from the E70 forum. Enjoy.
JEG23
Google Maps to BMW Nav.pdf
Convert Google Maps and Google Earth to BMW V1.0.3.xlsm.pdf
Remove .pdf extension
      01-27-2013, 03:26 AM   #2337
shawnsheridan
cheers!
Ok. If that does not work, I think you should try 48.1 PSdZData.
      01-27-2013, 04:07 AM   #2338
pixelfreak0410
Drives: Ordered: M440i Convertible RWD
How can i determine the integration level of my car? Is there a tutorial some where?
      01-27-2013, 04:26 AM   #2339
shawnsheridan
Connect>VCM Module>VCM Master Tab>Read I-Step>I-Step Current.
      01-27-2013, 11:49 AM   #2340
martinf79
martinf79's Avatar
191
Drives: 2020 G05 X5 M50i
Originally Posted by bmw328jc View Post
Basically all of your current CAFD files will need to be updated to 48.3 version. These files have a security check that makes the token everyone was using useless. Therefore you have to purchase a new token AND a patch for E-sys, delete all your current PZSDATA files and replace with the new 48.3 versions. You can contact shawnsheridan for a link to the files and contact info to buy a token and the patch. Cost is $65 or 50 euros
Got it ... thanks very much JC...
      01-27-2013, 11:50 AM   #2341
martinf79
martinf79's Avatar
191
Hi shawn... would you mnd please sending me the link for 48.3 and contact info to buy a token and the patch? Many thanks.
Martin
      01-27-2013, 01:27 PM   #2342
shawnsheridan
Martin
PM sent.
      01-27-2013, 02:45 PM   #2343
pixelfreak0410
Is it possible to activate the webradio function when the car has only navigation professional, but not the bmw assist and bluetooth option?
      01-27-2013, 07:18 PM   #2344
kon
Singapore
Drives: F30 310i > G20 310i
That would be BMW Apps (6NR), can be program/retrofitted, the coding part is simple, but in addition require an expensive FSC code (think of it as license) ~ last I heard about US$200? Bimmertech seems to sell the code itself for Euro159...
If you don't need to control the station, I believe you can still download BMW Connected from Appstore, select the station to play ON YOUR PHONE, and stream the music through bluetooth, functionality is the same you just CANNOT CONTROL it from your idrive
      01-27-2013, 07:43 PM   #2345
DXL XLR8
hey shawn can you pm me the link to the files please? thanks!
      01-27-2013, 10:35 PM   #2346
steve@codemybimmer
Hong Kong
665
Shawn, can I get the link to the 48.3 files and contact info for the E-sys patch and token as well? Thanks!
      01-27-2013, 10:35 PM   #2347
steve@codemybimmer
Hong Kong
665
Hey, I never knew you can access that on the iphone. Thanks!!
      01-28-2013, 12:21 AM   #2348
kon
Singapore
It should THEORETICALLY work on Pandora & Aupeo, you just lose the "control via idrive", since all sound can be stream via bluetooth, including YouTube (tested & confirmed )
      01-28-2013, 07:44 AM   #2349
shawnsheridan
PM's sent.
      01-28-2013, 07:44 AM   #2350
XmX32
So i bought the patch and replaced the .jar files and E-sys crashes when i try to launch it. When i put back the original files it runs.
Anyone have any idea what could be going wrong?
      01-28-2013, 07:47 AM   #2351
shawnsheridan
The Patch is E-Sys Version Specific.
What version on E-Sys did you order the patch for, and what version of E-Sys did you apply the patch to that is now crashing?
      01-28-2013, 07:58 AM   #2352
XmX32
I have e-sys 3.22.5 and the read me file says its been tested on 3.22.5
      01-28-2013, 08:02 AM   #2353
shawnsheridan
Well, if you renamed, and replaced the two .jar files, it should work.
You did rename them to remove PATCHED from the name?
      01-28-2013, 08:10 AM   #2354
XmX32
I can't believe i forgot to do that
thanks
