BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > F30 DIYs and Coding Discussions > TPMS doing my head in.
      12-27-2014, 08:01 AM   #1
magic77
magic77's Avatar
Drives: ex- 335i
So after all the trouble before xmas with my TPMS I went back and re did everything. Coded TPMS back to
In HU_NBT > 3001, code RDC to activ
In HU_NBT > 3001, code RDC_SAFETY to active
In HU_NBT > 3001, code RPA to nicht_activ
then refitted my 19" and went for a drive after 5 miles pressures reset and system was fine.
Then recoded again to turn on RPA and turn off TPMS
In HU_NBT > 3001, code RDC to nicht_activ
In HU_NBT > 3001, code RDC_SAFETY to nicht_active
In HU_NBT > 3001, code RPA to activ
All settings got set and all looked good. Left the 19" with TPMS and drove around fine with RPA working. Then with temps dropping to below zero boxing day I swapped back to my winters 18". Today after 10 miles got the same error about RDC failure.
Its doing my head in as it should work or am I missing another area in the coding, though from what I read up above should be enough.
Either this or need to find x4 TPMS sensors - Doh
F30 335i M Sport - now departed
      12-27-2014, 08:31 AM   #2
JDS
Drives: 2021 MBB F97 X3MC
What is RPA? I am not familiar with this...
I coded on my tyre temps and pressures, but seem to remember this was only one line item to change...
Had no problems so far.
Drives: 2021 F97 X3MC LCI - Marina Bay Blue Metallic
Gone: 2019 G16 840i GC - Frozen Bluestone Metallic
Gone: 2018 F80 M3C - Sakhir II Orange Metallic
Gone: 2015 F80 M3 - Mineral Grey Metallic
      12-27-2014, 08:38 AM   #3
magic77
magic77's Avatar
Drives: ex- 335i
RPA is the old functionality that uses rotation to sense if there is a puncture. E90 series used them so no need for TPMS sensors in each wheel. Coing the temps etc works fine. But in my case rather not have to spend over £100 on some sensors for few months of the year. Hence coded them out and set car to use RPA. to be honest I might try setting all to nichactive otherwise
      12-27-2014, 08:54 AM   #4
TMD29
Don't care
TMD29's Avatar
Drives: 17 SO M3 ZCP
I had the local tire shop take the sensors from my summer wheels and put them on my winter wheels because they didn't have the correct sensor in stock at the time.
      12-27-2014, 09:06 AM   #5
magic77
magic77's Avatar
Drives: ex- 335i
yep that woudl set me back £50 at least then another £50 to put back in summer thats about half the cost of the sensors done in one year
      12-27-2014, 12:27 PM   #6
teaston
Drives: X3 M40d
Surely you also need to code the FEM_BODY module, as it controls the TPMS. The coding in the HU is only secondary.
Best way would be to find the vehicle order FA code for TPMS and remove it, then find the FA code for RDC and add it. Then of course code the FEM_BODY module and HU_NBT so the FA will automatically change all the corresponding parameters in those modules.
      12-27-2014, 02:30 PM   #7
teaston
Drives: X3 M40d
You can find the FA codes using the FP Viewer in NCD CAFD Tool (just google ncd cafd tool to find the thread on it in the 'other' BMW site, started by the one we can't mention on here!
      12-27-2014, 02:45 PM   #8
magic77
magic77's Avatar
Drives: ex- 335i
hmm that does make sense didnt think of it, dont know if I'm brave enough to go in blind. Would not know what to look for
      12-27-2014, 03:07 PM   #9
teaston
Drives: X3 M40d
It's a shame there isn't a list available of all the FA codes like there is for E9x! If we just knew them it would be the same as coding EBT (which is technically changing the FA, not coding)
You can use that tool to find the TPMS FA code within your FEM _BODY's CAFD, but then we don't know the one for RDC!
Maybe @shawnsheridan can shed some light?
      12-27-2014, 03:46 PM   #10
magic77
magic77's Avatar
Drives: ex- 335i
have messaged him to ask but I have feeling its going to be easier to just get a second set of sensors or live with the warning light
      12-27-2014, 04:05 PM   #11
teaston
Drives: X3 M40d
If you can easily afford the sensors that's probably the best way to go, but if you want to save the money this is definitely worth a go if we can just find those two FA codes.
      12-27-2014, 04:08 PM   #12
magic77
magic77's Avatar
Drives: ex- 335i
its the case of for the few months I use them lot of cash to get rid of the light, annoying really. £150 I rather use on something else but if no other choice might have to go with it.
      12-27-2014, 06:10 PM   #13
teaston
Drives: X3 M40d
I've searched like mad for you mate, but i just can't find the FA codes for them!
      12-27-2014, 06:20 PM   #14
shawnsheridan
shawnsheridan's Avatar
List of FA Option Codes (SALAPA-Element, E-Wort and HO-Wort) can be seen with the FP Viewer in TokenMaster's NCD / CAFD Tool.
TPMS (RDC) is 2VB.
2018 F06 Alpina B6 650ix GC; Space Grey; Vermillion Red Nappa Leather; Executive; B&O; Driving Assistant
2017 F15 X5 xDrive50i MSport; Glacier Silver Metallic; Black Dakota Leather; Executive; B&O; Driving Assistant; RSE
      12-27-2014, 06:52 PM   #15
teaston
Drives: X3 M40d
TPMS (RDC) is 2VB.
Ah ok!
I think Magic has got things a bit confused in first post, TPMS is RDC, now we need the FA code for RPA (flat tyre warning) to replace 2VB?
      12-27-2014, 07:00 PM   #16
shawnsheridan
Ah ok!
I don't think RPA actually has an Option Code as it is standard, and RDC is the upgraded Option 2VB.
I would remove 2VB from FA, and VO Code NBT, Kombi, ICM, and RDC.
Then I would FDL code NBT => REIFENUEBERWACHUNG_RDC_RPA = rpa
      12-28-2014, 03:36 AM   #17
magic77
magic77's Avatar
Drives: ex- 335i
thanks, everybody will give it a go. Might work hopefully otherwise will just need to buy a set of sensors.
      12-28-2014, 04:26 AM   #18
teaston
Drives: X3 M40d
Shouldn't he VO code FEM_BODY ?
      12-28-2014, 05:51 AM   #19
magic77
magic77's Avatar
Drives: ex- 335i
well went back and reviewed any other settings for RDC and intersting results but no win.
Managed to activate the reset function on the NBT screen so could now force a reset of pressures but still RDC warning returns. Changing the main VO is probably a way to go but that's getting in too deep. Rather just get the sensors so thats the plan. FYI in total found the following RDC settings but even putting all these to nicht activ did not help fully with RDC remaining. So as sheridan said probably removing 2VB from FA but run out of battery power on laptop / time. Plus as this resets all other coding is not area I like to dig around. So sensors is going have to be
(also pulled the fuse and no avail)
Ones I found and set as below if anyone wants to try are >
FEM_BODY
30D0 - rc_rdc_enable - set to nicht active
KOMBI
3004 - st_tyr_rdc_timeout - set to nicht active
- st_tyr_rdc_alive - set to nicht active
HU_NBT
REIFENUEBERWACHUNG_RDC_RPA = set to rpa (enabled reset on the screen)
3001, RDC - set to nicht_activ
3001, RDC_SAFETY - set to nicht_activ
3001, RPA - set to active
      12-28-2014, 07:00 AM   #20
shawnsheridan
Sorry, yes, FEM_BODY too.
      12-28-2014, 07:03 AM   #21
shawnsheridan
(also pulled the fuse and no avail)...
Do you have ICM Module? If so, what is name of CAFD?
      12-28-2014, 10:56 AM   #22
teaston
Drives: X3 M40d
FEM_BODY
KOMBI
HU_NBT
I think no matter what FDL coding you do it will still come up with an error as the car still thinks it has TPMS/RDC
I don't think it's much bother re-doing previous coding after VO coding a module(s) so i will be trying this method on my next car when i put my winters on, so November 2016!
