09-09-2014, 05:43 PM | #1 |
Rep 131
Jb4 12v wire tap...why?
Does anyone know the technical reason why the jb4 needs a power tap and the stage 1 does not? I'm an engineer thus my inquisitive side is coming out.
It seems to me this little requirement is what tends to sway people away from the jb4 to stage 1... I am one if those who don't want ANY physical installation trace. |
09-09-2014, 06:53 PM | #2 | |
Rep 123
09-09-2014, 07:48 PM | #3 |
jairon2
20
Rep 237
As far as I know, that hasn't happened to anybody yet. It will be easier to find a split wire than to look and prove you had a tune installed at some point.
09-09-2014, 08:47 PM | #5 | |
Rep 1,997
Although I think he was asking why the need for power at all. That I'm not sure. Maybe for logging and other features like map changing. |
09-09-2014, 11:46 PM | #6 |
Rep 18,713
@BMRGUY, I think that is a question to the maker. You can email them or ask at N54tech.com forum.
Email:sales@rgsport.com | IG:RGSport_USA | Web:RGSportShop.com PM for Everyday DEALS!! MSS • iSweep • RaceChip • Sterckenn • AutoTecknic • Akrapovic • Vossen Wheels • Eventuri Active Autowerke • KW • H&R • Ohlins • Remus • and more... |
09-10-2014, 06:05 AM | #7 |
Rep 131
I made a possible false assumption the taps were for power.
It's an interesting approach bms took to interface with the computer. CAN is a simple messaging bus protocol (communication method for systems and sub systems). It seems the CAN standard has no provision for encryption or other security means to protect the communications. Seems this would be the secret sauce for the jb4 to either monitor or intercept communications between systems and sub systems and interface with items like the steering wheel to change maps. Thus this would be needed to alter parameters that control related and unrelated systems. Seems like the jb4 is taking the place of the ecu by using this method..which would be like flashing your ecu with new parameters... Interesting ... Of course this is all hypothesis and interpretation based I What I have read.. Last edited by BMRGUY; 09-10-2014 at 06:25 AM.. |
09-10-2014, 09:04 AM | #9 |
Rep 115,980
BMS actually has an F30 EWG specific harness and board in testing that does not require a 12v connection. But what you're thinking of is not the 12v connection it's the CANbus wires. Just connect them inside the harness where its covered by factory conduit. Easy.
09-11-2014, 06:16 AM | #10 |
Rep 131
Yes... ^ a couple of messages up I admitted I made a false assumption. the challenge is it still leaves a physical trace. But after reading about the CAN protocol I see why the need (good approach to intercepting and altering engine parameters) thus I also see why there will be no alternative to tapping into the can layer of the car... Good design but for me jb4 would not be an option due to the physical trace left behind after removing the unit.
It's nice there is an alternative but would be real nice to have jb4 capabilities without any physical trace. |
09-11-2014, 12:02 PM | #11 | |
Rep 115,980
But look at it this way. To avoid the hidden mass airflow detection codes you need to do one of three things. Run 3.5psi or less so they are not triggered like the BMS Stage1, intercept the MAF sensor wires directly to alter their signal like Dinan claims to do, or use the CANbus to intercept and alter the signal like the JB4 does. There is no free lunch here. So if you don't intercept CAN then you basically need to run no more than BMS Stage1 power levels to avoid detections within the DME. And unlike the wires where someone has to go look for them any tech can see the software detection when they connect to the OBBII port. Mike |
09-11-2014, 05:38 PM | #13 |
Rep 435
mike, first let me say sorry for never checking this ahead of time. but with all the hesitation around the splice have you considered another approach? I can only assume that somewhere those CAN wires go to an ecu harness or plug. for the sake of argument lets say there are 50 pins on that plug. couldn't you make a passthrough 50 pin connector that had the two jb4 can wires tapped off of your provided connector, making it plug and play? I paid 800 for a tune from vrtuning, at that price point I would have bought the jb4 instead if I didn't have to splice the wires. I cannot imagine that connector would cost 2-300 bucks once you reach a reasonable qty. dinans tune basically does what I am describing in terms of providing you with a passthrough "tapped" connector. I am only assuming the can wires are accounted for in their harness. and of course if you went to that trouble for the can wires you could probably do it for all of your wires at the ecu connection instead of the individual sensors. I have seen atleast a dozen people echo my concerns with splicing. I would still switch at this point if you offered it..
09-11-2014, 06:00 PM | #14 | |
Rep 3,406
09-11-2014, 06:18 PM | #16 |
Rep 131
It's from a m235... The guy ended up getting a refund from Dinan after the dyno...definitely stage 1 is the best solution out there for the money.
I like the logging and monitoring features of the jb4. I don't care for the map switching from the steering wheel and honestly won't even make any more mods other than the tune (except exhaust). |
09-11-2014, 07:13 PM | #17 | |
Rep 3,406
Also note that the Dinan dyno is also with M Performance Exhaust on the car which is good for maybe 5 RWHP, where as the BMS did not. Still, it's down 10 RWHP and 20 RWTQ from peak figures and it's even worse if you look at some points in the mid-range. |
09-12-2014, 10:07 PM | #18 | |
Rep 18,713
But for you to opt out on the bang for the bucks and the best plug n play piggy back system that started it all, I would say you are missing out.
09-13-2014, 03:51 AM | #19 | |
Rep 648
This exhaust is just for show + sound. /Krelle
Ist der Motor kalt, Gib ihn sechs ein halb.....
09-14-2014, 02:43 PM | #20 |
Rep 435
does anyone know if the canbus wiring harness (what jb4 taps) is part of the main wiring harness or something else from a bmw part# standpoint. i am going to try and acquire the male and female plug for the canbus and just make my own jumper wire and splice my jumper.. it looks like there are only 12 wires on that stock harness, shouldnt be too hard to make if i have the right plastic connectors.
09-21-2014, 11:48 PM | #21 | |
Rep 106
09-22-2014, 12:51 AM | #22 | |
Rep 648
/Krelle
