04-10-2015, 12:39 AM | #1 |
Rep 1,170
so I have been driving my car for about 2 weeks now so I'm still new to the feeling and shifting points and downshifts etc.
Now my question is how smooth are your guys transmission on the f30s 8 speed AT I feel mine a little jumpy at times when it's downshifting on its own even on comfort mode doesn't really bother me I just want to see if that's normal or maybe it's not normal .. and also on sports mode manual in each gear the car has a jump to it like the gear kicks in pretty hard Like I said maybe it's normal since I'm not used to it I have read and the say the trans is super fast on gears so maybe it is normal give me your guys feed back on your guys 8speed AT of how smooth your guys are or if is the same that way I won't too much about it or get it checked out Oh another thing at WOT the gears are super super smooth and super fast I love it lol
bmw m2
04-10-2015, 01:24 AM | #2 |
Rep 233
i am by no means an expert on cars or anything but what you have described is very similar to me. during slow accelerations(sport mode) the shifts are pretty choppy, like someone who is not very good at driving a manual car, but when i floor it i really FLY and have lightning fast shifts. I have rwd btw
04-10-2015, 06:21 AM | #3 |
Rep 258
Drives: 2016 F80 MG/SO
At 2k miles, I'm still getting used to mine. You definitely feel the jerk at slow speeds and smooth throttle - usually when you don't expect it. And the shifts at smooth acceleration feel like a driver that doesn't know how to use their clutch (brief loss of power, followed by crazy - unexpected for those speeds - torque/pull). This is the nature of this transmission which connects you perfectly to the engine at full power and performs flawlessly at 5k-7.5k RPM. I realized that I can't have both the Toyota ridiculous smoothness and the BMW sportiness. It's the nature of this beast which provides the optimum connection to the awesome engine.
Current: 2016 F80 MG/SO MT
Previous: 2015 F30 IB/SB 335i AT |
04-10-2015, 07:18 AM | #4 |
Rep 433
My tranny definitely broke-in and smoothed out with use, downshifts in particular. Manual downshifts into second at 40 mph used to sometimes chirp the rear tires, even with the rev match!
04-10-2015, 07:29 AM | #5 | |
Rep 20,651
Back to OP. I believe with the 335i and AT it is a little choppy / unsure at times but when banging on the power it's almost psychic. With the 6 pot Diesels the 8AT is sublime, very smooth both up and down gears. Although setting it to Sport does make a little too responsive at times for in town driving. All in all I love the setup. |
04-10-2015, 07:38 AM | #6 |
Rep 158
The 8AT transmission downshifts more often than any other vehicle I have ever driven. Auto trans of course. It is so sensitive to speed changes it becomes noticeable.
However it does that to always have you in the correct gear of the power curve with abundant torque in reserve. Other vehicles leave you in a higher gear and you have to wait for the downshift to accelerate. The F30 8AT already has you there! You are more aware of the downshift while slowing because less intelligent cars are lazy and stupid. You will soon appreciate the downshifts when you realize the car is. Indeed psychic. Any Honda can keep you in Drive all day but try to pass someone and wait for the gear.
435i Imperial Blue 2015 /Luxury/Tech /Premium/MPPK/Dinan Stage 1/Dinan polished tip exhaust/HK/Driver Assist/Driver plus/M Sport Brakes/Side Cameras/Saddle Brown Dakota/Escort Max Radar
04-10-2015, 08:00 AM | #7 | |
Rep 20,651
Future technology changes to the 'auto system' make it even more psychic. It will have input from GPS mapping, also from ACC so that as soon as you indicate to over take, it pre shifts ready to over take. |
04-10-2015, 08:44 AM | #9 |
Rep 10,351
IIRC the shifts are faster in sport mode. This is normal. The problem occurs when you're driving style is more conducive to Comfort mode.
Diesels are less likely to have this feeling because they respond slower and the AT is programmed accordingly.
"Drive more, worry less. "
04-10-2015, 08:57 AM | #10 |
Rep 20,651
Could you expand on Diesels respond slower?
04-10-2015, 09:25 AM | #11 |
Rep 10,351
Diesel fuels burns slower so it builds revs slower.
Also diesel engines have among other differences more rotational mass so they loose revs at a slower rate between shifts.
435i, MPPK, MPE, M-Sport Line Last edited by F32Fleet; 04-10-2015 at 09:32 AM.. |
04-10-2015, 09:34 AM | #12 |
Rep 20,651
04-10-2015, 10:01 AM | #13 |
Rep 10,351
Correct..They'll give you that initial jump because of the torque.
04-10-2015, 10:08 AM | #14 |
Rep 20,651
04-10-2015, 10:16 AM | #15 |
Rep 851
Guys, let me explain it simply. The reason you have rough shifts in lower RPM is because of where the car hits peak Torque. As our cars hits peak torque low in the RPM range the transmission is dealing with transfering that torque to the next gear. As you go up the RPM range torque drops and HP takes over of which when you shift higher in the RPM range you will feel less herky jerky. If you tune the car it will feel even MORE as the torque is kicked up a notch. Personally I like it feels like a sports car.
04-10-2015, 11:12 AM | #16 |
Rep 1,170
don't get me wrong you guys I'm in love of the trans compared to the the e90 6 AT
it was just curiosity that I had since I'm still getting used to the car at one point I felt the e90 faster but now that I'm driving the f30 and punching it here and there it's way faster now I feel the difference no doubt about it Thanks for all the inputs 👌👌👌 What do you guys think of a gthaus exhuast ?
bmw m2
04-10-2015, 01:21 PM | #18 |
Rep 1,227
There definitely is a break-in period for the auto transmission in these cars as others have mentioned above. The first couple thousands miles I the car shifted far too quickly for me when accelerating and it felt choppy. This problem seemed to go away after 3000 miles and its amazing now.
04-10-2015, 02:32 PM | #19 |
Rep 1,113
Compared to the SMG M3 I came from, this tranny shifts like a dream.
2003 11/02 Steel Gray Metallic on Red M3 - SMGII - VF570 - SUPERSPRINT - KW - BBS - CSL ROOF SOLD
2015 09/14 Alpine White on Red 435i xDrive MPPK - Expensive black vinyl with special lettering. SOLD 2020 12/19 Mineral Gray Metallic on Black Vinyl interior M340i xDrive |
04-10-2015, 02:45 PM | #20 |
Rep 5,316
Drives: G80 M3 6MT
It's worth nothing here the transmission will adapt to your driving style, and if you drive it like a grandma all the time it will get used to slow shifting and if you drive like a maniac all the time it will get used to quick shifting which might then feel weird at low speeds.
Scott, Partner
Insight Automotive Consulting Click HERE for all discounted BMW New Car Pricing Click HERE for all BMW In Stock Inventory Specials Call/Text: 516-416-5481 Email: scott@insightautoconsulting.com |
04-10-2015, 03:38 PM | #21 | |
Rep 693
Put it in SPORT and rev it up into the 4k range and pull that paddle and the car shudders as the "gear" is slammed into place. They are harsh gear shifts to be sure, I like it though.
2018 M240i X-Drive | Sunset Orange Met
2015 328d X-Drive Touring M-Sport (Traded) 2015 Audi S4 Sepang Blue P+ | DSG | Tech Package | Adaptive Suspension | B&O 2015 Audi S3 Misano Red | 19" Sport pack w/Mag Ride | B&O 1983 Porsche 944 All stock |
04-10-2015, 04:18 PM | #22 | |
Rep 204
Or does everyone else ignore the break-in period? |
