02-28-2019, 04:07 PM | #23 | |
Rep 72
02-28-2019, 05:15 PM | #24 | |
Rep 3,680
03-22-2019, 06:42 AM | #25 |
Rep 191
I suppose it's time to update my time. So as of now, I am "Stage 2". I have a VRSF Catless Downpipe and VRSF IC. I am in the proccess of a custom tune with Cary. End game will be full e85. For these runs, I was e60. So with that being said, these runs were with an incomplete tune, with a poor 60ft (working on that) and an "okay" DA (642ft on my best run). I was pretty happy with these runs (minus my shitty 60).
Relative Density: 98.68 %
IG: @derringerF10
2016 550i RWD N63TU 8AT | Catless Downpipes | BaskiSpeedworks STOCK TURBO RECORDS 1/4: 10.90@128 60-130: 7.43 |
03-22-2019, 09:12 AM | #26 | |
Rep 3,680
Nice runs! A big jump from your last couple. Being this close on E60, I can't see how you wouldn't be in the 12's once your tune is sorted and you're on full E85. I bet with a better DA and 60' you could get there as she sits now. This is looking like a pretty quick board with 3 guys getting 13.0x's and one in the 12's. It should only get quicker with the season (at least for us non-Floridians) coming up fast!
BettyFkinCrocker180.00 |
03-26-2019, 11:28 PM | #27 |
Rep 184
Drives: F30 N26
Well, SVTruong is up there now with his 14.1
-2013 F30 328i xDrive Melbourne Red- Injen CAI | GFB DV+ | FTP CP & TP | CW DP | G-Plus Oil Cooler | Mishimoto CC | VSRF FMIC | BM3 Stg 2| H&R Rear Sway Bar | H&R SS & Bilstein B8 | Carbon Fiber Dealibobs | 525 LPFP | Soon to come upgraded HPFP (B58TU) and Navardi Tune |
03-29-2019, 06:57 AM | #28 |
Rep 191
Well, the DA wouldn't cooperate but still made some improvements.
IG: @derringerF10
sspade2468.50 |
03-29-2019, 07:43 AM | #29 | |
Rep 3,680
Don't have time to update now, I'm on my way out the door, but I'll update the chart next time I get a chance. Just to clarify, these most recent runs are on an OTS map running E60, or is it an unfinished custom tune running E60? Trying to find out how different our setups are to see how close I am to a 12 second pass
03-29-2019, 09:09 AM | #30 | |
Rep 191
This is a custom tune by Cary. We are still going through revisions, turning up timing/boost and ironing out stuff.. so the tune is currently incomplete/unfinished. I've just been doing logs on my 1/4 runs for him to tweak. So once it's completed, the 12.87 or lower will be easy work. A better DA, a tiny bit better 60, or having an empty car alone likely would have netted a 12.8 or better.
IG: @derringerF10
rjd_F302000.50 |
03-29-2019, 09:59 AM | #31 | |
Rep 3,680
Without all the extra weight and with the right tune up and conditions, I have a feeling you'll be sub 12.87 in no time, like you said. Even with just a better 60' you're there. I've 60'ed 1.82 (w/ xDrive), so if you could get there with some sticky tires, which I'd guess you can, that alone puts you at #1. Just out of my own curiosity, can you post a link to the log of the 12.909 pass? Just curious to see what you're tune looks like...
03-29-2019, 10:08 AM | #32 | |
Rep 184
Drives: F30 N26
03-29-2019, 10:22 AM | #33 | |
Rep 191
Here's the log. And again, this is still in revisions so keep that in mind. http://www.bootmod3.net/log?id=5c9d7394ae729b7a6e83c5d2
IG: @derringerF10
03-29-2019, 10:25 AM | #34 |
Rep 191
Yup, mods are in sig. What do you mean tune out some torque? I imagine he'd have to pull timing down low (if you are referring to the concern of peak torque at 1800rpm stretching the rod bolts) which wouldn't be ideal. I don't think we are near the rod bolts limit anyways. I haven't dynod but those times are indicative of 300-330 whp and similar wtq.
IG: @derringerF10
03-29-2019, 12:46 PM | #35 | |
Rep 3,680
And boy is he really throwing some timing at it! I'm sure a lot of that is for the ethanol, but still way more than a normal OTS stage 2 map. I guess it's better to get the power there than from the boost, which looks about the same, if not a little lower than OTS stage 2.
03-29-2019, 01:23 PM | #36 | ||
Rep 191
IG: @derringerF10
2016 550i RWD N63TU 8AT | Catless Downpipes | BaskiSpeedworks STOCK TURBO RECORDS 1/4: 10.90@128 60-130: 7.43 Last edited by BettyFkinCrocker; 03-29-2019 at 02:05 PM.. |
rjd_F302000.50 |
03-29-2019, 03:30 PM | #37 |
Rep 184
Drives: F30 N26
Hell, that is a lot of timing.... O_O
rjd_F302000.50 |
03-29-2019, 08:01 PM | #38 | |
Rep 3,680
And yah, ethanol's a magical thing when it's tuned for correctly. Excited to see how she does when it's all buttoned up
04-03-2019, 05:12 PM | #39 | |
Rep 72
You’re So close too! My 12.87 run was a little wild. I too had a packed car (tools, me (solid 260lbs), full tank, seats, and little cooler with dos XX). Barely launching at 1900 rpm with run flat tires. Damn it! So, now that you’re close... I may have to come out of retirement. This time i’ll do it right. Gutted with some drag radials. |
rjd_F302000.50 |
04-03-2019, 05:48 PM | #40 | |
Rep 3,680
04-08-2019, 08:30 AM | #41 |
Rep 242
Drives: 2013 328i 6mt
You think we could get one started for the 1/8th mile guys? The closests 1/4 mile is 2 hours away for me.
F30 328i 6mt
Injen, ER, BM3, Solowerks, IND, BMS, BBS E46 M3 smg2 Bimmerworld, H |
04-08-2019, 08:41 AM | #42 |
Rep 5,458
04-08-2019, 09:06 AM | #43 |
Rep 242
Houston raceway is a ways away from me. I might go soon though but theres an 1/8th mile that closer to me. And I thought you got banned? Or am I missing something lol
F30 328i 6mt
04-08-2019, 09:21 AM | #44 | |
Rep 3,680
sspade I realize now that you're back this was a thread-jack to the highest degree on my part lol. If you want to go back to your thread I can delete this one, or we can keep it here... up to you
