02-04-2021, 10:55 AM | #1079 | |
Rep 48
I have personally seen rubber charge pipes expand on engine dyno - that is not a problem with plastic charge pipes. If you suspect the pipes are cracked, or if the seals are leaking; then you could upgrade the charge pipes, but there is no performance to be gained from it.
MODS: Turbo Transformer boost controller, ECO-SPORT auto selector (home brew), Electronic boost gauge vent mounted, RPM based LED Carbon paddles
WISHLIST: BM3, HPFP, Turbo + IC + water ... new car eventually |
02-04-2021, 06:55 PM | #1080 | |
Rep 384
but if your on tight budget, i suggest spending that $200-300 on something that provide performance gain, like XHP transmission flash.
Instagram: nightfall.f30
02-04-2021, 10:06 PM | #1081 |
Rep 2,815
Drives: F33 430 and F39 M35i
Any plans for B48E?
02-08-2021, 09:50 PM | #1082 |
Rep 14
did you find out dude? I'm also thinking of buying a 320i m sport
Bimmer Nation
02-09-2021, 01:11 AM | #1083 |
Rep 384
off course BM3 is available for 320i N20 or B48
03-16-2021, 11:38 AM | #1084 |
No Cones
Rep 105
I bought their OTS maps, ENET cable, and tuner license for my 2017 F3x, I have BMW's July 2020 DME firmware update. This version of the DME is locked and BM3 flashes fail. I worked with PTF / BM3 support, they said I can't do anything until the DME is bench unlocked and they "won't accept mail in modules to bench unlock due to covid."
Unless you have a local tuner with proven capability for bench unlocking the most recent DME firmware I recommend saving your money and waiting for PTF/BM3 to release a flash unlock. |
imperfectluck428.00 |
03-16-2021, 06:51 PM | #1085 | |
Rep 75
I have a 2016 F30 N26 that I purchased CPO in May 2020.... will I be able to flash? I already purchased BM3 but haven't tried to flash it yet... |
03-16-2021, 09:09 PM | #1086 |
No Cones
Rep 105
03-17-2021, 11:34 AM | #1087 | |
Rep 75
04-14-2021, 02:02 PM | #1088 |
Rep 1
I’ve got a BM3 (bootmod3) License for sell.
Bootmod3 N20 N26 - BMW F10 F20 F21 F22 F30 F32 125i 220i 228i 320i 328i 420i 428i 520i 528i X3 X4 TUNE Comes with the bootmod3 OTS maps bundle. License originally $595 OTS map bundle $50 Total - $645 SELLING FOR $450 |
04-14-2021, 02:14 PM | #1089 |
Rep 2,815
There’s a classified section and OTS map bundles do not transfer.
04-14-2021, 08:05 PM | #1090 | |
Rep 50
Thanks |
04-14-2021, 09:44 PM | #1091 | |
Rep 384
maybe you quoted a wrong person?
04-19-2021, 10:10 AM | #1092 |
Rep 100
Hello!
I am a user with a Mini cooper s f56 from 2014-06 with B48 engine, currently it has 45000km the car has automatic transmission It currently has Wagner intercoolers, NGK IRIDIO spark plugs, Coils replaced by the last original reference available, Remus V2 exhaust pipe, k & n panel filter, Ravenol RSP 5W30 oil, Ravenol OTC g12 + coolant, Redline ATF D6 automatic gearbox oil and I think I do not forget anything, at the moment the electronics is standard. I am somewhat concerned about the pistons since I read that there are many B48 breaks both from stock and with reassignments, some say it is due to LSPI, others that due to injection, etc ... Is there a way to mitigate or improve these problems without having to change the pistons (I would hate to disassemble my engine completely, if this engine could be changed from the bottom without removing the engine from the car, I would do it immediately, but since it is not like that. .) They say that using an oil with lspi formula mitigates these problems as well, such as amsoil 5w30 or similar, what can you tell me about all that? First of all thanks for reading! The question is, in the 2014-06 B48 engines like mine, how to mitigate the breakage of the pistons in some way, without having to replace them, the engine now has 45000km and electronics as standard, but soon I will reassign to 280cv // 400nm and I want the motor to be safe and not have breakage problems as I have seen previously in others. Some say that the problem is mitigated with LSPI oil, others that the problem is injection, I also want to know what is the origin of the piston breaks. will it be possible to install bootmod3? A hug! |
04-19-2021, 11:58 AM | #1093 | |
Rep 417
Or maybe it doesn't transfer cross platform?
'16 M4 bone stock
'13 335ix Msport BM3 stage1 - MAD FMI - FTP CP - Bilstein B4 (SOLD) '85 635csi M30 turbo race car (SOLD) |
04-19-2021, 08:43 PM | #1094 | |
Rep 384
Bad fuel quality, bad oil quality, bad plugs, bad injectors, overboost, and the list can go on and on. what we can do is to do preventive maintenance, such as using good fuel quality, good oil spec and quality. I heard some of oil brand had obtain SN plus certification, which increase protection to LSPI. i'm myself, using B48 engine for 1.5 years with Stage 2 BM3, which deliver over 400nm and 300hp. My car is working flawlessly until now, which already run 10k miles with those power figures.
04-20-2021, 05:09 AM | #1095 | |
Rep 100
I normally use all the best for my car, good gasoline, good oil, good maintenance, good care, etc ... But I am somewhat scared with as much piston breakage as I see daily. |
04-24-2021, 12:27 AM | #1096 |
Rep 4
Hi guys
New to the BMW and bm3 world. This was my 1st flash attempt. I got my ots map and went to flash, got the error "flash successful but coding failed to apply" I tied to revert to the original tune but having the same results I now have a dash full of errors and malfunctions, and the car won't start. I have launched a ticked with PTF and super confident they can sort me out but unfortunately I'm in Australia and they are not available until 11pm my time Monday at the earliest. I'm wondering if anyone has had the same issue and how it was resolved? Car is a 2013 f32 428i with the n20 Lights and fan were off, Seatbelt plugged in, 25amp charger connected to a brand new battery (to be safe and as per instructions) I apologize in advance if I've posted this in the incorrect place, very new at forums as well lol Thanks in advance for any advice |
04-26-2021, 05:54 PM | #1097 |
Rep 2,815
hooligan_G016430.00 |
04-26-2021, 07:12 PM | #1098 | |
Rep 417
'16 M4 bone stock
04-26-2021, 07:23 PM | #1099 | |
Rep 2,815
they let you sell it once. or you can transfer it to your next car. |
Tags |
bm3, bootmod3 |
