BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > N20, N26, B46, B48 Turbo Engine / Drivetrain / Exhaust Modifications > Bootmod3 stage 1 gains
      06-20-2020, 03:01 PM   #89
DadzBmer_N2o
DadzBmer_N2o's Avatar
Drives: F30 320ix
Originally Posted by Nustle14 View Post
On our 2015 320xi, we added BM3 stage 1, transmission flash, awe cat back, Injen air intake, catted downpipe, and charge pipe. Dyno clocked it at 251.36 hp and 297.97 lb tq to the wheels. Subsequent runs had slightly lower hp and slightly higher tq. 0-60 per dragy is 5.95 (5.60 1ft roll out) with zero engine loading...just stomp and go...and that's with two people in the car on a half tank. Based on an online calculator, we estimate 311hp to the crank, but realize this conversion is often debated. RENNtech estimates a 17% loss for an automatic all wheel drive MB based on their experience... Hope this helps...
That 0-60 time seem's abit slow, since from stock its like a +115 ish or so. I believe the 0-60's on stock motor is around 7s. I've already messed around a 535d and could have passed him anytime i wanted with this stock Stg 1 BM3 on 93...
And with those mods your like a FMIC away from Stg 2 lol..
2013 320ix N20 8AT|BM3 stg1|Muff Res Delete|HPB-LED-Amber-DRL's
IG: DadzBmer_N2o
      06-20-2020, 03:14 PM   #90
Nustle14
Drives: 2015 320xi
Agreed...Probably can do better with 0-60. Oil Catch Can goes in tomorrow... FMIC and S2 may be on the horizon...
      06-20-2020, 06:41 PM   #91
pierreye
Drives: F10 & G01
Get xHP Stage 3 first. This is one of tune that really change the throttle response and very fast gear change. Switch to sports mode and you will no longer feel the rubbery gear shift.
      06-20-2020, 07:14 PM   #92
Nustle14
Drives: 2015 320xi
Does xHP replace the BM3 transmission tune?
      06-20-2020, 10:08 PM   #93
pierreye
Drives: F10 & G01
Yes. It's better you flash back to stock before installing xHP tune. If you like sporty drive with fast shifting, you will love xHP tune. I'll do this first instead of FMIC and Stage 2 tune as it's very noticeable improvement. You can download the apps first before purchasing license to check your gearbox condition before tuning. As long as the Clutch pressure is not more than +-450 mbar and Quickcharge time not more than +-40ms it's consider normal. The clutch will still work until +-750 mbar.
      10-22-2020, 12:34 PM   #94
j2dad5389
j2dad5389's Avatar
Drives: 2020 M340i
Originally Posted by TK335iMSPT View Post
In case anyone was wondering. This is what my stock f30 put down.
Specs:
2014
F30 335i XDrive
32,000 miles
Mods:Mperformance exhaust
Horse Power: 248
Torque: 250
Outside weather: 87 Degrees Fahrenheit
Reviving old thread because im curious. How did you get 248hp and 250 tq when our cars are rated for 300/300?
Also curious if anyone has numbers for stage 1 bm3. Don't want to go stage 2 cause I don't want to touch my cats for state inspection.
      10-22-2020, 01:18 PM   #95
sqwinny
Drives: 2013 6MT 328i M Sport
These numbers are at the wheels. It's very common for the 335i and 335i xdrive to dyno less than 300whp/wtq.
335i x drive stock vs essentially stage 1 (intake, catless downpipe, exhaust, JB4 map 2)
exE36M3487.50
      10-22-2020, 01:19 PM   #96
TK335iMSPT
TK335iMSPT's Avatar
Drives: F30 335ixdrive M Sport
Specs:
2014
F30 335i XDrive
32,000 miles
Horse Power: 248
Torque: 250
So my dyno run was on a Mustang Dyno. They call these the heartbreaker Dyno because they typically read lower than Dyno jet and other companies. The tech said my figures are really about 275hp/275tq after factoring in the Dyno correction. This makes sense because automakers use crank horsepower/torque when displaying numbers. Not all 300 horsepower is making it to the wheels. I'm XDrive as well so there's additional drivetrain loss there. While the original post was done completely stock, I am now currently stage 1 with my N55 but I'm running a FMIC so results may vary on Dyno results. I'll look into booking a session before I go stage 2. Covid has all the shops in my area booked, so it may be a bit.
      10-22-2020, 03:49 PM   #97
j2dad5389
j2dad5389's Avatar
Drives: 2020 M340i
Gotcha. Yeah, I'm curious to see those numbers. I threw on BM3 stage 1, as well as FMIC + Charge pipe. Disappointing if stage 1 just barely hits 300hp.
      10-22-2020, 10:42 PM   #98
Honeybadger23
Drives: 2012 f30 328i sportline
Originally Posted by HyperShot5 View Post
Appreciate all the responses. Just wanted to see what how close I'd be to 300 with just the tune.
Yes you should be somewhere between 290-320 hp
      10-25-2020, 04:46 PM   #99
sean.cooper01
Drives: '15 BMW 328i
I tuned my car about a week ago and did the stopwatch 0-60 method.
2015 328i with an injen intake 2 people and 3/4 of a tank of gas was 5.8, after tune 2 passengers and right under 3/4 of a tank was 5.25ish.
Take the numbers with a grain of salt lol, they're probably inaccurate but its just giving you an idea.
I can say that the butt dyno definitely felt it and it is 100% worth getting bm3.
VipinLJ1941.50
      10-26-2020, 10:12 AM   #100
sqwinny
I found this. Dyno numbers should be similar to bm3/jb4 stage 1 completely stock.
256whp/284wtq
      10-26-2020, 06:24 PM   #101
snipagang
Drives: 2017 320i xdrive
256whp/284wtq
well this is very encouraging.
      11-03-2020, 09:18 PM   #102
jkstyle834
Drives: 2016 BMW 330e M Package
i will get it done in between runs... once i find a shop around me... lol
