05-13-2021, 08:24 AM | #89 | |
Rep 190,807
06-11-2021, 01:08 PM | #91 |
Rep 190,807
Its a good option for daily drivers
06-11-2021, 06:48 PM | #93 | |
Rep 190,807
Depending on how hard you push the car, you can get away with the MAD 5", Wagner EVO I, VRSF 5", or Active Autowerke a
06-11-2021, 07:09 PM | #94 | ||
Rep 28
06-12-2021, 10:35 AM | #95 |
Rep 190,807
If you have the 5" BMS and you are looking for better cooling, check out the BMS race
06-18-2021, 11:47 AM | #96 |
Rep 43
Hi Mike, I'd appreciate your recommendation for my N26 running, Mst C.a.i , E.R charge pipe and turbo to I.C pipe, Mst turbo inlet pipe, 2nd cat delete awe exhaust, and Bm3 stage 1, possibly upgrade the Dp this year.. mainly DD.. thanks again
06-18-2021, 12:08 PM | #97 | |
Rep 190,807
Stage 2 6"+ (CSF, Wagner EVO II, Evolution Racewerks, MAD 7"). For a daily driver, you won't notice a difference no matter which brand or size you go with as any of these options is a major upgrade over stock
hooligan_G016430.00 |
09-27-2022, 03:23 AM | #98 |
Peachmode
Rep 1
Intercooler recomendations
Hi, I know this is an old thread but gotta ask what intercooler I should buy.
I have a F32 with about stage 2 (280hp tuned, with sports cat, exaust). I do go on tracks somedays and drift also. I was considering wagner only when I thought bigger intercooler the better. After seeing other blogs... I changed my mind to VRSF HD for 550whp (5') cause it's cheaper than wagner... BUT now seeing this thread... all the bar & plate and tube & fin stuffs made me confusing. What intercooler should I get? Wagner competition? or just the VRSF HD...? |
09-27-2022, 09:35 AM | #99 | |
Rep 190,807
If you are running stage 2 or more, get a race high-density core 7" (BMS/MAD) If you track your car and want the best possible track times, I'd consider the Wagner tube and fin as it does work well on the track with the fastest recovery between runs and the lightest weight
alohasurftoad3081.50 |
09-27-2022, 01:28 PM | #100 | |
Rep 4,922
10-13-2022, 09:18 AM | #101 | |
Rep 34
I am running a Stage 3 F30 N55 (so Hybrid turbo) with 450HP. I am mainly tracking the car. So what you recommend? My currently installed IC is a bar & blate from Do88 which is heating up like hell after 2 rounds of going hard! Link to it https://www.do88.se/en/artiklar/bmw-...tercooler.html Thx Simon |
10-13-2022, 10:50 AM | #102 | |
Rep 4,922
Could be a mix of your turbo creating to much heat from high boost and intercooler heat soaking. Would have to see your Iat logs to see how the intercooler is performing. Is that intercooler a 5 inch? You could try a 7 inch if so.
10-13-2022, 11:53 AM | #103 | |
Rep 34
https://datazap.me/u/sithf30/v15e-final?log=0&data=3-16 Outside temperature was around 55-60F On the track with just 70F outside temp I was hitting more than 130F The do88 has the same size than the Wagner Evo 2 |
10-13-2022, 12:00 PM | #104 | |
Rep 4,922
10-13-2022, 05:01 PM | #106 |
Rep 190,807
I think he is going to recommend his own brand
MAD/BMS offer larger intercoolers with high density cores, you can't go wrong with either one
10-14-2022, 12:46 AM | #107 | |
Rep 34
so if I understood correctly, I have three options: 1. MAD 2. BMS 3. VRSF What is the best in your opinion? Thx best regards Simon |
10-14-2022, 11:49 AM | #108 | |
Rep 190,807
I recommend you check customer reviews on all three, availability, warranty and pricing when making a decision on which to get
09-16-2023, 01:32 AM | #109 |
Rep 51
2016 428i F32 N26
Street car to have fun with Stock engine internals Navardi OTS Enhanced Stage 2 tune Hi Flow Catted 4 inch downpipe Upgraded all charge, boost, intake, turbo inlet and air box pipes Stuck between the CSF 8115 and the Wagner EVO 2 Competition. Which would you suggest? Or do you have a better suggestion? Thanks in advance. |
09-16-2023, 10:29 AM | #110 | |
Rep 190,807
Since it's a street car, I'd go with CSF. Wagner's major benefit is the tube and fin core optimal for track use.
HELLCO24.00 |
