10-31-2018, 02:08 PM | #67 |
Rep 19
This might be a chicken and egg problem. Which happened first? Going to try to figure it out. If chain stretched first I would think it should have slipped over the exhaust teeth? The intake sprocket is a direct pull from the crank sprocket. On the other hand, the intake is only wrapped 90 degrees whereas the exhaust is something more. The chain jumping over the teeth would certainly make the chain hit the retainer and take it out. The pull on the exhaust would be constant since the lobes do not change. Maybe the valvtronic on the intake could vary the load quickly if one floors the throttle so the lobes/valve lift goes from almost nothing to full lift, if the chain is already stretched that might be enough to cause it to slip. Now that I am writing it would seem to me to be a good explanation. If the intake retainer just randomly broke it should have fallen outside of the chain and I believe that is what happened but there would be no way for a plastic bit to jump up and get under the intake sprocket.
Yeah, more I think about it, I would say my first explanation is probably correct. So maybe do not floor the throttle if the chain is already stretched! Actually, my chain seems nice and tight still. If I find any other issues I will report back. |
10-31-2018, 04:10 PM | #68 | |
Rep 2,382
It's definitely a low % chance of failure based on numbers of failures but I think the unpredictability is what causes it to be so worrisome. Even when we look at detecting it before failure, it's practically 50/50. Some have noticed that loud whine and some have noticed no changes. That may have to do with how/where it wears down. If it's a more consistent wear, maybe you get that loud whine as a result but if it's more anomalous, you just get unlucky when that small area causes the chain to go haywire. It also mostly seems to be that those with unmodified (and possibly modified, who knows) may not have something to worry about as BMW seems to be mostly cooperative with people. That seems to vary from fronting a large part of the bill to fronting the whole thing. I think the more occurrences we have, the easier it may get for future failures.
2013 F30 328i: MHI Big Turbo, GFB DV+, Mishimoto CAI, ER TIC/CP/Catless DP, AWE Touring Quad Exhaust w/ Resonated Midpipe, NGK LI Plugs, BM3 with PTF Stage 2 91 AGG Tune, Fuel-it Stage 2 LPFP, Solowerks S1 Coilovers, and DEPO/M-Sport Retrofit |
rjd_F301999.50 |
10-31-2018, 06:48 PM | #69 |
Rep 170
That is also an interesting question. If you flash the car or similar and the timing chain clearly failed wouldn't BMW still have to replace the engine...? It seems like it would be hard to argue that a flash put extra strain on a timing chain. This is all assuming you are within warranty/ELW.
10-31-2018, 10:32 PM | #70 |
Rep 19
If BMW used polycarbonate for the chain tensioners, no wonder they break. I own an injection molding business. I would NEVER use Polycarb for an interior engine part. Polycarb is good for impact but bad with chemicals. I would start with nylon 66 at a min and work up from there. Now I am going to check my broken pieces, if it is Polycarb, clearly their engineers did not know their business. As well, if someone came to me to mold those parts in Polycarb, I would not do it. As well, now I will examine the design for sharp inside corners and just bad overall design. You would be surprised what a tiny increase in internal radius can do for strength.
We had company tonight so I did not get to have a look at the car tonight. |
11-01-2018, 07:04 AM | #71 | |
Rep 3,680
11-01-2018, 08:41 AM | #72 |
Rep 159
One more theory for failing timing chain and guides could be that because chain can be very loose when engine is stopped, the chain will put more stress on the guides when engine starts to move again. So everytime that engine is stopped there is a chance that chain is loose (I don't have exact reason why it's sometimes loose and sometimes tight when engine is not running) and then it will rattle more against the guides. When this is repated enough the guides will broke and chain will skip a teeth. If chain is also little bit stretched it will be even harder to the guides.
So I would not use auto start-stop as it increases the strain to the chain. TBH, I don't use it for various reasons, it causes delay when I want to move again, it puts stress to the battery, start motor and bearings. For the whining, what I've understood it comes from the oil pump chain. (Stretched) Timing chain makes more like a rattling sound which can be heard best when starting the engine. I actually do exhibit some weird metallic rattle when starting up the engine and also on certain rpm range. I will ask the dealer to measure my chain when I have next appointment there. |
BunkerJ1032.00 |
11-01-2018, 08:47 AM | #73 | |
Rep 2,382
"The lawsuit alleges the plastic guide for the timing chain is made with a defective polycarbonate composition that causes the guide to break apart and lodge in the crankshaft drive sprocket, causing the chain to damage the engine." I remember reading the lawsuit and it goes through this pretty well. This coincides with them changing the composition of the guide following 2014. As for the warranty claim, I think it'd be a more difficult battle but I think you'd have a chance still. BMW has often fronted the bill either partially or in full for even those outside of warranty. Now, don't get your hopes up thinking they will even do that but know that others have succeeded in circumventing that 20k bill (through the dealership, not 3rd party). Remember, BMW has to prove that your modifications caused the issue in order to deny your claim. So, if you do your research before and go in guns blazing (respectfully and tactfully), then I think you have a good chance IMO.
11-01-2018, 10:00 AM | #74 |
Rep 19
I had a closer look at the broken parts. I did my quick test and they are almost certainly nylon. BMW likes nylon. The valve cover is Nylon 66 with 35% glass filler. (It said that. I am good but not THAT good) The trick with molding plastics is to use the most cost effective material for the purpose. The lawsuit almost certainly did not question a plastic professional and a lawyer just named a plastic they thought sounded good. If in fact they did start out with Polycarb then wanted to switch to nylon, they would have had to change the mold as shrink for nylon is a lot compared to Polycarb so all dimensions would have been out.
I examined the broken bits and I didn't see any obvious bad design elements. Interesting my chain is tight, not a bit of slack at all. The tensioner on the exhaust side is all still intact. All the more reason for me to say in my case the chain slipped over the intake sprocket causing the intake tensioner to break. I had not thought of the start-stop "feature" I would turn it off on any car I owned. |
Stubok471.50 |
11-01-2018, 10:37 AM | #75 | |
Rep 2,382
11-01-2018, 09:48 PM | #76 |
Rep 170
https://www.pacermonitor.com/public/...LLSCHAFT_et_al
I have been using this to follow the class action... The case is pretty early along though. At this point they're still sort of "setting up" so to speak. Might be a few years before anything comes of this. |
RMachuca3d723.50 |
11-02-2018, 08:47 AM | #77 | |
Rep 2,382
11-04-2018, 03:36 PM | #78 |
Rep 19
Update. Yesterday I was going to set the intake cam to the adjustment point. I turned the crank back about 30 degrees to keep pistons from hitting valves.
The timing chain was just jumping over the intake sprocket. I then just turned the cam back. Then I noticed some shinny bits by the cam bearings. I pulled one cam cap off. Totally galled away. Unfortunately, those bearings are just machined in the head no bearing inserts. So that means new head for sure! Damn To make matters worse, now I think I had better pull off a main and rod bearing just to see if they are galled as well. My oil analysis showed okay but if oil wasn't flowing well it might not have flushed crap into the oil pan. Now I am thinking, maybe the oil pick up screen was plugged causing low oil pressure, maybe for a while and staving the cam bearings. Maybe that caused a much higher drag on the timing chain and that caused the chain to skip causing everything else. Looks like I won't get away cheap on this fix, either a head or most probably entire engine. |
RMachuca3d723.50 meltbox43.00 |
11-05-2018, 02:52 PM | #79 |
Rep 943
Drives: F30 328i Msport
Ouch
11-05-2018, 10:48 PM | #80 |
Rep 59
Drives: F30 328i RWD
Does anyone have a pre 01/2015 n20 which doesn't have an orange/brown timing chain guide?
Or are they all that colour due to discolouration. |
11-05-2018, 11:10 PM | #81 |
Rep 19
The color of the tensioners is probably a function of how often oil is changed. I know insides of engines with 15K oil changes are almost Brown while 5000 mile changes are almost free of discoloring.
11-06-2018, 02:09 AM | #82 | |
Rep 59
Real OEM when i change between e.g. 2012 and 2015 shows same parts so there is no way to no for sure whether you have the updated parts or not. Considering whether its worth to have to pay my mechanic to pro-actively change out all the parts since the timing chain issue would lead to engine replacement. $$$ |
11-06-2018, 08:52 AM | #83 |
Rep 2,382
He's referencing the change in color. The pre-2015 guides appear much darker than the post-2015 ones. (Despite mileage) I think the pre-2015 ones either came as an orange or similar color or stained much easier.
11-06-2018, 03:16 PM | #84 | |
Rep 19
There was no reason to color the parts. In the molding business, we usually buy resin either as natural or Black. They just picked up the color as time went on. |
sspade2466.00 |
11-06-2018, 03:23 PM | #85 | |
Rep 3,680
11-06-2018, 03:26 PM | #86 | |
Rep 2,382
11-06-2018, 03:29 PM | #87 | |
Rep 5,457
Drives: F30
11-06-2018, 03:32 PM | #88 | |
Rep 3,680
Maybe what you said is the answer though: the newer plastics implemented in the new guides stain less easily and appear lighter in color (EDIT: or they're just newer so less stained regardless of plastic used ) ? Like the video in the first page of this thread shows, even the old guides were white at production. Still confused that the revision date is 01/2015 though. Like I said, at that point we were only months away from the LCI hitting dealerships, so why even bother revising the N20 so majorly for a couple months of production. The whole timing chain issue is just a crap shoot.
sspade2466.00 |
