03-06-2018, 04:41 PM | #89 |
Rep 3,157
03-06-2018, 05:02 PM | #90 |
Rep 190,807
03-07-2018, 01:29 AM | #91 | |
Nemo banks
65
Rep 253
rply
-Does the process of flashing ECU/DME allows us the option to revert or save the current state of ECU/DME in case it needs to be flashed to stock? yes -Any failsafes in case car overboosts? the tune was set for 19 psi it was cold out 63 degress started boosting 23 psi. -Is there a CAT Cel passive delete option included?yes -Will the flash itself be tied to a specific VIN? yes
FBO N20, G-Plus Oil Cooler , Injen Cold Air Intake, MST turbo inlet, AFE Charge Pipe, BMS Oil Catch Can, Forged Motorsport Blow of Vavle, Wanger FMIC, Circuit Werkes Catless Downpipe, Full Straight 3inch exhuast. Stage 2 Active Auto Werke.
03-07-2018, 01:35 AM | #92 |
Nemo banks
65
Rep 253
03-07-2018, 01:36 AM | #93 |
Rep 174
After the install of a intercooler, Do i need to revise the tune?
2015 MG 320i Mods: LTMW M6 Custom Front Bumper, AWE Quad Tip w/ Performance Mid Pipe, Active Autowerke stage 2 Flash, Bilstein B14 PSS Coilovers, Injen CAI, ER Charge Pipe & Catless DP, Bavgruppe Headlights, M3 Side Skirt, M Performance Rear Bumper, LCI BMW M Performance Black Line Tail light, M Knee Rest, Coby Wheels and Dinmann CF Interior
IG: AKLT320i |
03-07-2018, 01:45 AM | #94 |
Nemo banks
65
Rep 253
was for the n20 or the n26 they are two different.
03-07-2018, 06:35 AM | #95 |
Rep 327
I wouldn't think so. But they could have a bit more aggressive tune to take advantage of the cooler temps. Intercooler doesn't necessarily add power, it just restores power that is lost due to timing.
Mods: MHD Stage 2+ FlexFuel, xHP Stage 3, VRSF 5" HD Intercooler, VRSF Charge Pipe, CircuitWerks Catless DP, AFE Pro Dry S Intake filter, Eldor coils, NGK 97506 @ .026, Bilstein B14 coils.
03-07-2018, 12:41 PM | #97 |
Rep 190,807
Nice
03-10-2018, 01:48 PM | #99 |
Rep 190,807
03-20-2018, 12:07 PM | #100 |
Rep 18
I'm a new F30 owner (2015 328i N26) and want to go OEM+. I'm thinking about a Stage1 tune + Remus axleback, and then maybe an intercooler somewhere later down the road. Is ECU flash tuning for the N20/N26 generally considered to be a more fine-grained tuning solution compared to piggybacks? I really like what I've seen from this AA flash tune, my only concern would be if a warranty claim came up and having to deal with that (I have 1 year factory + 1 year CPO left on the car). That's one reason I'm considering the Dinan Stage1, but that is still basically a piggyback. I had a B6 and B7 A4 prior to my F30, and had the APR ECU flash in both cases. I really liked how the tune required no hardware modification, and you could even switch between maps on the fly via the cruise control stalk. Overall, I'm looking for reliability over absolute performance.
03-20-2018, 12:09 PM | #101 | |
Rep 190,807
We offer combo deals for Active Tune + REMUS exhaust. Let me know once you are ready to pull the trigger. Active Autowerke tune will give you a lot more power than dinan + a smoother power delivery
03-20-2018, 12:20 PM | #102 | |
Rep 2,382
2013 F30 328i: MHI Big Turbo, GFB DV+, Mishimoto CAI, ER TIC/CP/Catless DP, AWE Touring Quad Exhaust w/ Resonated Midpipe, NGK LI Plugs, BM3 with PTF Stage 2 91 AGG Tune, Fuel-it Stage 2 LPFP, Solowerks S1 Coilovers, and DEPO/M-Sport Retrofit |
03-20-2018, 12:54 PM | #103 |
Rep 18
03-20-2018, 01:53 PM | #104 |
Rep 190,807
03-20-2018, 02:30 PM | #105 |
Rep 325
Drives: 2016 F36
03-20-2018, 02:56 PM | #106 |
Rep 2,382
03-21-2018, 02:41 AM | #107 |
Big Turbo Boys N Girls
327
Rep 579
Seems very strange the Dyno graphs posted for the pulls are all measured in 3rd gear? As I recall F30 1:1 ratio was 5th gear? Also 14.9 afr seems super dangerous!!!! Any graphs/logs showing AFR and timing through rev range?
nemobanks64.50 |
03-21-2018, 08:44 AM | #108 |
Rep 2,382
For the ZF45HP, 6th gear is actually 1:1. And 14.9 is pretty dangerous..
03-22-2018, 11:06 AM | #109 |
Nemo banks
65
Rep 253
@Andrew@ActiveAutowerke ???
03-22-2018, 11:07 AM | #110 |
Nemo banks
65
Rep 253
Originally Posted by D041987 Seems very strange the Dyno graphs posted for the pulls are all measured in 3rd gear? As I recall F30 1:1 ratio was 5th gear? Also 14.9 afr seems super dangerous!!!! Any graphs/logs showing AFR and timing through rev range?
