BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > N20, N26, B46, B48 Turbo Engine / Drivetrain / Exhaust Modifications > N26 Forged internals Engine build
proTUNING Freaks
      09-19-2020, 09:58 AM   #1
Kel918
Drives: 2013 bmw 328ix
Just starting my engine build. I'm going to go with Maxspeedingrods connecting rods, cp pistons, and dry cast iron sleeves with support rings for the open deck from cylinder supports system. Just got my connecting rods from maxspeedingrods. Shipping was extremely quick. Next up is ordering the cp pistons
obert1781.00
VipinLJ1943.00
sspade2466.00
      09-19-2020, 05:56 PM   #2
sspade
sspade's Avatar
Drives: F30
2016 BMW 320i  [7.87]
2014 BMW 328i  [6.83]
Sweet. Looking forward to seeing your build as it progresses.
If it interests you, join us here:
https://www.facebook.com/groups/2443...651/?ref=share
      09-19-2020, 08:40 PM   #3
Slowestn20
Drives: Bmw 328i n20
About to start the same process as you !
      09-20-2020, 08:01 PM   #4
Kel918
Thanks, aiming for 600-650whp using a twin charge setup
      09-20-2020, 08:02 PM   #5
Kel918
Let's go!! hopefully everything goes smooth
      09-30-2020, 04:02 PM   #6
5mall5nail5
Not stock
5mall5nail5's Avatar
Drives: E34 525i Turbo
Would you mind measuring those rods center to center? They look like Eagle M5x rods.
Yep so, the rods pictured above are 135mm length c to c. Would need wrist pin and crank diameter but if that's the case, M50 based (m50, m52, s50, s52) rods will work - in which case I would go with Molnar rods personally.
2015 BSM 328i Sport Line - BSM
2015 BSM X1 M Sport - BSM
1992 525i
1987 325e
      10-07-2020, 06:36 PM   #7
Kel918
hey just saw this, on their website it says center to center length is 144.3mm . I actually called eagle rods and they didn't have any rods that would work before I went with maxpeedingrods.
here's the maxpeedingrods link for the rods : https://www.maxpeedingrods.co.uk/pro...(us-only).html
Here are the n20 specs from hurricanre rods and it's 144.35mm center to center : https://www.hurricanerods.com/produc...l#.X35RTajYrnE
      10-07-2020, 07:46 PM   #8
snipagang
Drives: 2017 320i xdrive
What is the purpose of this? Does this increase power ? What does it mean to “build and engine”
      10-07-2020, 07:54 PM   #9
Avaley
Avaley's Avatar
732
Drives: f32 430ix & 982 GT4 PDK
lets you run higher boost without blowing your internals. build can be just bolt ons (hell even rims + tune is considered "build" these days) but forged internals engine build is going big turbo + custom internals so your engine doesn't explode
      10-07-2020, 08:36 PM   #10
Kel918
The reason why I have to rebuild the engine with stronger forged connecting rods and pistons is because the engine will basically self destruct from what I've read with anything around 325-350 whp. I'm going for around 5-600 whp with my set up.
      10-07-2020, 08:37 PM   #11
Kel918
Thanks !! for the explanation
      10-12-2020, 05:25 PM   #12
prkr
prkr's Avatar
Drives: f30 328i Sport Line
Whats your budget if you don't mind me asking? I'm loving 300hp in this thing but 500 just sounds amazing especially if it can be done safely. And honestly, my car is paid in full and modded the way I want and its already worth almost worth nothing so.. fuck it?
F30 328i MSport Mods: Bootmod3 Stage 2, MPE, VRSF Catless Down Pipe, G-Plus FMIC
Previous Cars: e36 323i vert, e90 328i sedan
      10-12-2020, 08:24 PM   #13
Kel918
I really didn't have a budget planned just trying to get good parts for as low as possible. I paid $658 for the rods shipped, and just got the pistons with the upgraded rings shipped for $905. With the twin charge setup I have planned, it should put a minimal amount of strain on the engine.
      10-12-2020, 08:36 PM   #14
Kel918
Just got my pistons from Carillo !!
      10-12-2020, 10:12 PM   #15
sqwinny
Drives: 2013 6MT 328i M Sport
excited to see this build happen! who is making your sleves?
      10-12-2020, 10:25 PM   #16
Kel918
I plan on getting the Iron sleeves, cylinder support rings, and everything installed at cylinder support system. I have to find an engine block now because they're backed up about 8 weeks and I can't have the car parked that long.
      10-12-2020, 10:50 PM   #17
sqwinny
when you say sleeves, you mean OEM or is it an aftermarket solution aka Darton, APS, etc.
      10-13-2020, 03:19 AM   #18
Kel918
On their website - www.cylindersupportsystem.com it says including iron liners . I forgot to ask specifically which brand. I'll call today later on and find out
sqwinny478.50
      10-14-2020, 08:30 AM   #19
Kel918
I spoke with cylinder support system and they use melling cast iron cylinder sleeves. I actually looked them up and those sleeves are going for like $22 each.
      10-15-2020, 01:47 PM   #20
cedaj
Drives: F80
Taking it to a machine shop to bore out the cylinder and put in the sleeves?
      10-15-2020, 02:35 PM   #21
Kel918
I'm going to send it to cylinder support system, for $1,245 on their website they install support rings, the iron liners and machine everything to the block.
      10-15-2020, 02:37 PM   #22
Kel918
it's going to get everything else done with them so it's going to be more money. I'm just trying to find a block with a good crankshaft. They told me they’re real busy and I would be looking at an 8 week turn around
