12-11-2017, 07:15 PM | #1 |
Rep 295
Rear dash rattle
I've been getting this rattle coming from the back. Its a stiff plastic-y rattle.
I tried to ignore it but it's been getting worse. Rattles on lane changes and bumpy roads. What I've investigated so far: -The child seat anchor covers: they are made of hard plastic and there is a tiny bit of play when closed, but i tapped with my finger around the area and it does not seem to be coming from those covers. -Third brake light: I got the car tinted so I assumed the broke a clip up there, but I pulled it back down and checked it out. Everything seems fine. The clips seemed loose so I put tape between them to cut down on the play. The LED bar thats inside the housing does rattle when I tapped on the TBL housing. I ended up wedging a small ziptie between the bracket that was holding the LED bar in place. I was able to get ride of all rattles from the TBL. However, the rattle still exists after I put everything back. When tapping in the corners of the rear ceiling the I can hear the rattle but cant pin-point where exactly it's coming from. Literally driving me nuts! Lmao... Is there a DIY on removing the rear dash? I'd like to do more investigation. Thanks in advance! I have a 2017 340i (if it matters for anything) TLDR: rattle from the rear dash. Tried a few things, but didn't work. Please link DIY on rear dash removal for further investigation. SOLUTION FOUND: I found out what was cause the noise. My cousin had thrown her bag into my trunk and it hit the clip that is meant to hold the floor liner up so you can access the compartment underneath. It was the hard plastic vibrating against metal on certain bumps that was causing the noise. I slipped a piece of tap between the two and problem solved. Last edited by Kevin_Trxn; 03-01-2018 at 11:58 AM.. Reason: Solution found |
12-12-2017, 11:53 PM | #2 |
Rep 118
Drives: 2024 330xi
There is another thread about the rear map light assembly rattle- I have it and it sounds like what you’re describing. See the other thread, supposedly a pain to try to DIY😤
12-13-2017, 01:26 AM | #3 |
Rep 295
12-13-2017, 10:54 AM | #4 |
Rep 118
Drives: 2024 330xi
12-13-2017, 05:27 PM | #5 | |
Rep 295
Thank you |
12-13-2017, 08:04 PM | #6 |
Rep 40
It's likely the rear shelf... this is really common. Just take it to BMW and have them add felt tape to all of the contact points. It fixed mine.
tex26702411.00 Kevin_Trxn603.50 |
12-13-2017, 08:22 PM | #7 |
Rep 5,457
Drives: F30
I have this as well especially when listening to music loud. I assume it is the rear child seat anchors and have planned to use foam or tape to eliminate it. Must be a really common issue.
12-14-2017, 10:06 AM | #8 | |||
Rep 295
Did they mention exactly where/what was making the noise? Thank you |
12-18-2017, 08:46 PM | #9 |
Rep 216
I have the same issue, it happens more in the winter months. I just learned to ignore it, it's kinda disappointing thou, my wife MB C300 don't have any noises and it's older.
12-18-2017, 08:48 PM | #10 |
Rep 5,457
Drives: F30
How difficult is the rear shelf to remove and install felt tape oneself?
12-19-2017, 10:12 AM | #11 | |
Rep 9
12-19-2017, 11:55 AM | #12 | |
Rep 376
Don't know if this is your issue but might be worth a quick try?
2014 BMW 328i, 6-speed Prem / Nav / Drivers Assist / Heated Seats / Lighting |
05-24-2018, 12:11 PM | #14 |
Rep 906
having these rattles too when i hit bumps just driving down all the damn roads. It drives me crazy. Only 1500mi on it, I'm gonna have to make an appointment with the dealer because this stuff is such a pet peeve... brand new car with rattles... especially one that costs $56K!!
2016 X3 35i M-Sport
2019 440i Coupe M-Sport - Retired 2018 330i Sedan M-Sport - Retired 2015 428i Gran Coupe M-Sport - Retired |
