06-08-2012, 04:01 PM | #1 |
Rep 215
Paint Issue
Well, I was washing my car and saw some strange brown spots around the passenger side front and rear wheel wells. At first i thought it was just tar or something but when I tried to clean it off, the clear coat started to come off.
I took it to the dealer and the head detailer tried to clay it but said that it was either in or under the clear coat. I have to take it back for the body shop manager to look at it. Any idea what it could be? I attached a pic of the front as the rear doesn't show up very well.
2012 328i Base, Auto, Melbourne Red
06-08-2012, 04:41 PM | #2 |
Rep 9,160
It's always hard to diagnose paint issues over the internet, but can you feel the defect? Is it higher or lower than the surrounding area? From the pic, it does look like a failure of the clear coat though, but again, it's very difficult to analyze this sort of thing from pics.
By the way, I assume we're talking about the lighter circle in the lower third of the picture, with all the scratches around it? The darker spots look like tire dressing slung off, try wiping the tire down after you apply product, or using a water based product like 303 and letting it sit for a few minutes before driving off. |
06-08-2012, 09:52 PM | #3 | |
Rep 215
06-08-2012, 11:01 PM | #4 |
Rep 793
As mentioned above, it's very hard to diagnose paint issues like this online. However, my guess would be that the paint and/or clear was affected by some kind of tire dressing, whether dealer- or owner-applied. It also could have been caused by a number of different road contaminants that hit the paint when it did not have sufficient protection.
If the spots don't feel raised, as mentioned, then the first thing I'd suggest is to take 91% IPA (rubbing alcohol) and a paint-safe microfiber and wipe down the area. This will remove most contaminants and give you a fresh surface to work with (you can also clay if there is any need to). Assuming you still have the spots, you will have to attempt polishing them out yourself or having a professional do so (and by no means should the body shop guys be considered polishing professionals!). Always start with the least aggressive and move towards the more aggressive steps as necessary. I happen to have all the stuff necessary (you may not), so I'd use my Flex XC3401 and probably start with a finishing polish like Menzerna 106FF on a white pad, and if that didn't work then I'd move up to an orange or yellow pad with Menzerna SIP or PG. Finishing with a milder polish would be necessary, of course, to be followed by a sealant or wax. Good luck. I imagine some combination of polishing steps will work. If not, the only choice to get it back perfect will likely be a repaint.
2017 Porsche 911 Carrera S
2019 Porsche Cayenne Past BMWs: 2015 M3, 2014 550i, 2013 M3 ZCP, 2012 535i, 2011 E90 335i, 2009 E90 M3, 2008 X5, 2006 330i, 2004 330i |
07-16-2012, 12:55 PM | #5 |
Rep 215
**Update**
So i take my car to the dealership and they look at the spots. They also find a few more. I left the car with them and they were able to get ride of SOME of them by sanding away some of the clearcoat (Yikes). Apparently the spots are in the clear. One fender still has the spots and BMW is offering to strip and repaint the fender and "blend" it with the rest of the car. They cannot say what the spots are or what caused them nor can they say that they won't reappear. I am NOT at all happy with this. I brought the issue to BMWs attention when the car had 1,000 miles on it (it only has 1,900 now) and I really don't want a new car with a repainted fender (and door and hood for "blending" purposes) and a bunch of clearcoat sanded away. Am I being unresonable? Any suggestions?
07-16-2012, 01:21 PM | #6 |
woof
84
Rep 1,233
Yes, you are being unreasonable.
They are willing to satisfy your concerns and fix the issue. Paint matching from a reputable shop, especially on a vehicle with fairly new paint (<25,000 miles... in your case less than 2k..) is completely unnoticeable and I'm sure you will be satisfied with the results. Suggestions.. Do not use any tire dressings.. Wax the vehicle 2-3 times over (once the new paint settles.. abt 30 days after) I highly recommend zaino, http://www.zainostore.com/ 1x base coat of Z5 followed by a coat of Z2 and you're protected for 6 months (in Detroit). Reapply Z2 once every 6 mo thereafter. If you aren't able/willing to detail the vehicle, pay someone else to do it. It goes a very long way in protecting your exterior, especially in a nasty winter area like Michigan. Good luck!
2013 F13 ///M6 Sakhir Orange 2013 F30 335i Estoril Blue II 2008 E92 ///M3 Interlagos Blue 2007 E92 335i Montego Blue |
07-16-2012, 01:26 PM | #7 |
Rep 9,160
I'll take the other angle. You're not being unreasonable. A blended paint job is something that a $200 paint thickness gauge will pick up and many folks will be able to see even the best work with their naked eyes, probably including you.
I'd ask your dealer if they'd be willing to pay you for the diminished value, either with cash, or dealer credit. If your dealer is 100% sure this is a clear failure and not something that you might have caused, they should be more than willing to take care of you. As a casual car detailer and someone who has bought a used car or two, I hate blended paint and will personally not buy a car with paint damage unless it's something really unique. |
07-16-2012, 01:31 PM | #8 | |
1989
Rep 9,498
Repaired paintwork is NEVER the same.
2021 LCI M5 Marina Bay Blue/ Smoked White Leather |
07-16-2012, 01:46 PM | #9 | |
Rep 413
07-16-2012, 02:02 PM | #10 | |
Rep 413
07-16-2012, 02:39 PM | #11 | |
Rep 3,307
07-16-2012, 02:41 PM | #12 | |
Rep 9,160
Sidebar, with the aforementioned issue about diagnosing paint damage over the interwebs, the pictures damage sure does look like sling off of either a tire dressing or possibly some chemical left in a parking lot. Now whether this happened on the OP's watch, was done by the dealer or even at the point of manufacture is impossible to say. The outcome is that the paint is fubared, and the solution offered is suboptimal. If it were my new car, I would not accept a respray without some sort of financial compensation or a chance to swap into a similar car in inventory. |
07-16-2012, 02:43 PM | #14 |
woof
84
Rep 1,233
You're right, mis read the date. Fixed my post. That does change things a bit since the vehicle is so new.
I agree the issue blows. And yes, better pictures would be nice. I think the dealer is doing their fair part in accepting, recognizing, and repairing the issue. If they repair it behind expectation, in other words, if it is not repaired to match the quality of a new vehicle, then yes absolutely I would escalate the issue or see what else they're willing to do for you.
2013 F13 ///M6 Sakhir Orange 2013 F30 335i Estoril Blue II 2008 E92 ///M3 Interlagos Blue 2007 E92 335i Montego Blue Last edited by gerbs; 07-16-2012 at 04:51 PM.. |
07-16-2012, 02:46 PM | #15 | |
Rep 9,160
05-02-2012, 08:17 PM I do not recall seeing any F30's in the US in calendar year 2011. Just so we're on the same page, today's date is July 16th, 2012, correct? Gerbs, just for my curiosity, have you ever had a car repainted? Was it water based or oil based paint? Was it metallic or solid? In any instance you've had a car repainted, did you find it to be equal to the quality of factory paint, and just as importantly, unrecognizable in normal, outdoor lighting? I've seen some incredibly pricey, and incredibly cheap localized paint repairs and I've never seen one that I'd say was undetectable from a fair distance. |
07-16-2012, 02:48 PM | #16 | |
Rep 3,307
I'm not aware of even dealer demos showing up in the US until February 2012... |
07-16-2012, 02:58 PM | #17 |
Rep 510
Stone chips IMO. I have them on a car with low miles on it.
If my car was not leased I would have but 3M clear material on the front and the rockers behind the wheels.
2014 911 C2 Cab, Considering adding 2er convertible
Past - 2011 328i Convertible 2008 BMW 335xi Coupe (ED), 2003 BMW 530i, 1999 BMW 528i |
07-16-2012, 04:38 PM | #18 |
Rep 215
Let me respond here:
1) The car was delivered to me May of this year so it's less than 3 months old. 2) I did use MacGuire's Tire Shine. I contacted them and they said that in no way it would it eat thru the clear and shouldn't even stain it. The car was clay barred and the brown spots were in/below the clear. 3) The car had a fresh coat of wax (or so the dealer says) which would have further protected the paint. 4) the dealership cannot say what caused it other than to say that it is not a stain on top of the paint and compromised the clear in several spots.
07-16-2012, 04:59 PM | #19 | |
Rep 9,160
07-16-2012, 05:01 PM | #20 | |
woof
84
Rep 1,233
I do own a DeLorean though,
07-21-2012, 05:13 PM | #21 |
Rep 215
***additional update***
So the dealership had the car for a week. They were able to get out some of the spots (by wet sanding I am guessing) but not all. They contacted BMWNA and their solution was to put on free mud flaps that cover the spots/damage (actually doesn't cover entirely). They were also unable to fix the paint flaw on the front bumper but only made it slightly better. Even a guy at the dealership said that the paint job on the car had several "irregularities" and wasn't BMW's best work. I am supposed to call back Monday and tell then what i think. I think the mud flaps look cheap and don't even fit the car that well. My friends looked at it and agree that the mud flaps look cheap. One friend said "Why didn't they just use some f$%king duct tape?" They also roadforce balance the tires but the steering vibration still exists. I now also have an issue with the black trim that on the door. It has become discolored and spotty and won't clean up. I am simply telling me to order me a new car if they don't a pissed off ex-customer. I have worked with them and made 4 trips to the dealership on this already.
