07-31-2015, 02:27 PM | #1 |
Rep 699
Quick talk about options on this 2014 335i
I am looking at this car: http://www.knauzbmw.com/certified/BM...8102118a69.htm
It lists the upgraded premier sound, which I like. It's m-sport as well. Has the adaptive m suspension and navigation professional. Couple questions: 1) Is the adaptive m suspension equivalent to DHP or do I need to find a m-sport with that option? 2) Navigation professional is considered standard navi or part of tech package? Basically, what does tech package give me past HUD and is it worth trying to find? Thanks for your time! Mike |
07-31-2015, 02:33 PM | #2 |
ghey
483
Rep 2,041
That car has xdrive, I don't see the adaptive suspension button near the shifter, and it should be there as far as I know. Unless it's DHP, the xdrive suspension will override anything else, i.e. mine is a sport line xdrive, but it has xdrive suspension, so it sits higher, is more floaty and softer.
In 2014 you could order navi without the tech package. So like me, you'll have nav with the extended cluster but no HUD. Full spec list here: http://www.bmwarchive.org/vin/j465923.pdf
21 G05 > 20 G05 > 17 G30 > 14 F30 > 08 E90
07-31-2015, 02:36 PM | #3 |
Rep 699
Thanks for the info.
I just read the ad where it does say it is DHP, so I am a little confused. Looking at the vin lookup, it does have active m suspension and variable sport steering, so it should be DHP then? Weird it wouldn't have the button near the shifter though. I'm confused here. ON EDIT: Also, the harmon kardon stereo is considered the top or no? S688A. |
07-31-2015, 02:41 PM | #4 |
ghey
483
Rep 2,041
I might be making the button thing up; that could only be in higher series or maybe it's from an M series, but it's just sticking out in my head for some reason.
In the US, the base stereo is HiFi (standard) and HK is the premium option, so if it has HK then it has the highest option for the 3 series. The other possibility is that eco-comfort-sport are what determine the suspension, and as mentioned, the 3 may not get that dedicated button that I'm thinking of. It certainly says it in the VIN sheet, I doubt that would be wrong.
07-31-2015, 02:45 PM | #5 |
Rep 699
OK great, thank you.
Last question would be about the navigation. Have any info on this? It has navigation professional. What am I missing without the tech package, other than HUD? Thanks! |
07-31-2015, 02:51 PM | #6 | |
Rep 6,586
The Adaptive M suspension has no button. Cannot be turned off with a console button if an option. It is a set of sensors that adapt suspension every X milli-seconds. OP, the Adaptive M Suspension was an option ($700) with he M-Sport package or a part of DHP (along with variable steering) NAV could also be ordered as a stand alone option or as a part of Technology Package (includes HUD) |
07-31-2015, 02:53 PM | #7 |
ghey
483
Rep 2,041
I think you're good. If it was missing things like S6NRA, S6AKA, S6APA you'd be missing on enhanced Bluetooth, etc. but I think you've got a build similar to mine - I have remote services, connected drive apps, etc.. I have everything but the HUD.
07-31-2015, 02:55 PM | #8 |
Rep 699
OK, thanks. You've been a great help. I can do without the HUD so that's no a big deal to me. Just want to make sure I'm not missing other things as well.
I'm planning on checking the car out tomorrow, so we will see how it goes. |
07-31-2015, 02:58 PM | #9 | |
ghey
483
Rep 2,041
Yeah, definitely give it a look re: the adaptive suspension. Since there is no dedicated button check the drive mode settings, it adaptive suspension is there then you should be able to tweak things a little.
07-31-2015, 03:00 PM | #10 | |
ghey
483
Rep 2,041
But it sounds like that settles it; there is no button for it, any customization is done via iDrive, and even then, some of that is only available in the latest integration level (where you can say, have comfort mode use sport suspension).
07-31-2015, 03:27 PM | #11 |
Rep 1,476
Drives: 2022 G01 X3 M40i (Black/Black)
I almost bought this car. It's a good deal, though I ended up passing for another vehicle that I'm (hopefully) picking up next week. Note that the car does NOT have the Tech Package (Heads-up Display), which I was looking for. It is also (obviously) X Drive, which I really didn't want. I was also looking for the 403M wheels.
Anyway, yes, it does have the Adaptive M Suspension and the Variable Sport Suspension, as noted in the VIN lookup. Those are bundled together and sold as the "Dynamic Handling Package" in the U.S. market. The interesting thing you need to know, which won't show up on the VIN lookup, is that the current owner, an employee at the dealer, has added the M Performance Exhaust and a LOT of M Carbon Fiber accessories - full interior trim, mirror caps AND the CF M Performance shifter. Very unique! VERY nice car...on some levels I regret passing on it. I actually prefer Alpine White (mine is EB). Good luck, and post back here to let us know if you opt for it!
2022 G01 X3 M40i (Black Sapphire/Black), HK, DAP, PAP, Shadow Line
2014 F30 335i (EB) 6MT, M Sport, Premium, Tech, DHP, HK, CW, M Brakes, M Exhaust 2006 E90 330i (Silver) 6MT, Sport |
07-31-2015, 03:45 PM | #12 |
Rep 1,718
07-31-2015, 05:52 PM | #13 |
Rep 1,476
Guys, there's NO DHP button! Only the driving mode button, which is present on every F30. The only way you know if the car has DHP is by navigating to the mode settings to see if "Chassis" is an option, or if you have the build sheet.
07-31-2015, 06:18 PM | #14 |
ghey
483
Rep 2,041
Yeah, sorry for the misinformation everyone. I recall seeing a suspension button in some of the cars I was looking at while waiting for service, and for whatever reason decided that if it had DHP it had that button. I think it's exclusive to M models only.
07-31-2015, 07:21 PM | #15 | |
Rep 6,586
08-05-2015, 03:18 PM | #16 |
Rep 6,239
Drives: 2018 340i M Sport
Garage List 2018 BMW 340i M Sport [9.38]
2020 BMW M340i xDrive [10.00] 2018 BMW 340i M Sport [8.00] 2006 BMW 330i Sport [4.50] 2004 BMW 330i ZHP [7.25] 2000 BMW 328i [6.00] |
So, how did your assessment of the car turn out and how was your experience with Knauz?
www.bmwcca.org member #388003 - Use me as a referral & you could win a one day ///M Driving School!! ___________________________________________ |
08-07-2015, 07:22 AM | #17 |
Rep 699
Car was nice. I was surprised that the m performance exhaust was so quiet. It seemed pretty much like stock to me. Also couldn't believe that it had the parktronic but no backup camera. Should be a given for a car at this price point. Overall, nice car. Biggest issue is that I am unsure if it is the right car for me. Still debating this vs a 550i.
08-07-2015, 08:00 AM | #18 | |
Rep 4,449
Drives: '23 X1 28i xDrive
Tech Pkg only adds HUD over the Nav Pkg. |
08-07-2015, 08:06 AM | #19 | |
Rep 4,449
08-07-2015, 01:21 PM | #20 |
Rep 1,227
Small correction: Just because there is a 'Chassis' option in iDrive sport mode settings does NOT mean the car has adaptive suspension. I have an '15 F32 w/o DHP or adaptive M suspension, and my iDrive sport mode settings have both steering and chassis. Obviously, the chassis selection does nothing, but it's still there.
08-07-2015, 01:22 PM | #21 | |
Rep 1,227
08-07-2015, 01:51 PM | #22 |
Rep 4,449
And, if you press the button for the parking sensors, and push the iDrive controller to the left, the top menu choice should be to select the backup camera.
