02-02-2016, 11:45 PM | #45 |
Rep 346
A Friend of mine bought this part# 61129335592 for his F22 to retrofit the airbag ambient light and it is wrong part. I have no idea what is the correct repair cable part#.
02-06-2016, 08:48 PM | #47 | |
Rep 346
My friend did the mod on his F22. He has the airbag logo but it is not a cover. It is part of the trim but same size as the removable airbag cover. He had it removed by cutting the airbag logo and then use the airbag cover with reflector and the LED light cum cable and hook it up to the existing ambient light. It is cheap mod so see if you are game to try it. |
02-07-2016, 11:07 AM | #48 | |
Rep 265
02-09-2016, 05:38 PM | #51 |
Rep 817
Drives: bmw M3 F80
09-13-2017, 03:08 PM | #53 |
Rep 23
Sorry, I know this is an old post. I'm now doing this retrofit, but I don't know where the connector from the air bag should connect to. Do I need to cut the wires from the B panel and attatch with the air bag wires? I'm so confused of doing this retrofit... I'll post some pictures later to illustrate what I'm taking about
03-19-2019, 03:56 AM | #56 |
Rep 122
03-20-2019, 12:28 AM | #57 | |
Rep 817
Drives: bmw M3 F80
Hello https://f30.bimmerpost.com/forums/sh...php?p=17360496 https://www.ebay.fr/itm/5-a-50pcs-LE...AzItcQkdF04pSw |
BackBlue107.00 |
03-22-2019, 06:04 PM | #58 | |
Rep 122
I'm having a bit of trouble finding the same LED's her in the US that you linked me too. Do these look like the correct size and type?: https://www.ebay.com/itm/LCBM67S-OSR...72.m2749.l2649 |
03-25-2019, 12:33 PM | #59 | |
Rep 817
Drives: bmw M3 F80
they look identical to my leds |
BackBlue107.00 |
08-17-2023, 12:31 PM | #60 |
Rep 33
Hi,
I have f30 lci with ambient lighting. When I've removed door connector, there is no white/blue wire, only the white/red. Can I connect from b pillar wiring 2 and 3 pins together to the white/red one? |
08-17-2023, 01:33 PM | #61 |
Rep 1,808
08-19-2023, 03:34 PM | #62 |
Rep 33
Did mine today. I've connected only two wires: ground in pin 14 and red/white in pin 17. And it's working. Without wire slicing or tapping.
