01-23-2017, 01:55 PM | #23 |
Rep 2,124
Same, I've got myself in the habit of pushing the button twice. My mrs has forgotten a few times though.
Previous: 2010 F01 740d M Sport | 2015 F36 420d M Sport
Current: 2018 F36 440i M Sport (Stage 1 BM3, xHP stage 3) |
01-23-2017, 02:27 PM | #24 | ||
Rep 4,932
01-24-2017, 03:48 AM | #25 | |
Rep 4,932
01-24-2017, 03:55 AM | #26 |
Rep 3,815
Few others I have done
Windows Down/UP stop on door open - disabled Radio off on door open Wiper Sensitivity increased M Logo on I Drive for start up as Splash instead of animation Turned off Horn at Secure so you can lock the car while running without horn sounding. M Lap Timer Advance Bluetooth an turned off second microphone Digital Speedo Seperates Ambient Lighting from Cluster Lighting Auto-Start-Stop set to ‘Off’ at every startup Displayes entire SMS message on idrive rather than 3 lines Changes Sport Gauges to Silver from Amber Activates Siri Eyes-Free Button (Hold down voice recognition button)
F30 335i M Sport - now departed
01-24-2017, 04:20 AM | #27 |
Rep 2,124
I have another list on my laptop at home. I'll see if I can find the original link, or upload it.
01-24-2017, 07:04 AM | #28 |
Rep 8,081
You can't code the display to show what gear you're in in normal "Drive" without flashing the gearbox with Alpina software.
Ian
Current: 2021 G21 330i M-Sport Previous: 2018 A6 Avant S-Line MMI+, 2014 F31 320d M-Sport, 2013 F10 520d M-Sport, 2011 F10 530d M-Sport, 2008 320i M-Sport Coupe, 2002 325i, 2001 318i valvetronic, 1998 318i, 1996 525i, 1990 Porsche 944S2 |
01-24-2017, 07:56 AM | #29 | |
Rep 4,932
01-24-2017, 02:21 PM | #30 | |
Rep 1,924
if the car is running, it wont switch off the radio when you go to close your gate. But, if you like it the way it is..... |
01-24-2017, 02:25 PM | #31 |
Rep 32,881
Virtually everything that can be coded is in the cheat sheet here:
http://f30.bimmerpost.com/forums/att...8&d=1435767715 |
01-24-2017, 03:50 PM | #32 | |
Rep 4,932
01-25-2017, 04:37 AM | #33 |
Rep 1,799
I agree and so I have coded it to turn off when I open the drivers door . Downside is when I am washing the car the radio turns off every time I open the door
Is there any way to stop the radio turning off every 10 minutes or so when the car is parked & unlocked such as when I am washing it ? That is annoying especially when I have just turned it back on then open the drivers door & it switches off again !
U06 230e Active Tourer |
Previous : 2019 F31 340i : 2017 F31 335D M-Sport |
01-25-2017, 05:48 AM | #34 |
Rep 2,124
You can do it if you have a manual gearbox i think.
01-25-2017, 05:52 AM | #35 |
Rep 8,081
That's just the recommended shift up / shift down indicator, not coding. Even then it doesn't show you what gear you're in because it's pretty unneccesary in a manual...
Ian
DickieGibbo77.50 |
01-25-2017, 06:46 AM | #36 |
Rep 2,124
Im sure on one of my sheets it says about the gear staying on there all the time.
01-26-2017, 05:40 AM | #37 |
Rep 42
01-26-2017, 05:47 AM | #38 |
Rep 2,124
I think its just folding mirrors.
01-26-2017, 05:54 AM | #39 |
Rep 778
I don't know for sure but if it has electric mirrors I don't see why it wouldn't do it?
Try it. Make sure you have the slide switch switched to the drivers side mirror and put it in reverse, passenger mirror should dip. If it does, you'll be able to code the angle. |
01-26-2017, 11:50 AM | #40 | |
Rep 2,475
The folding mirrors on lock - does it not do this anyway if you hold down the lock button? And on an F31 - does the boot not open/close on the key anyway - or is the coding option about making it do it without holding down the button (which I guess is a safety thing).
340i F31
01-27-2017, 04:20 AM | #42 | |
Rep 8,081
Ian
Abzynthe1384.50 |
01-27-2017, 06:25 AM | #43 | |
Rep 3,486
Most dealers will not even acknowledge that coding exists. |
01-27-2017, 07:02 AM | #44 |
Rep 2,124
Its all to do with the parameters being set at the factory. I.e the ecu's need the code in there to be able to set it to whatever BMW want it to be. The side effect being, that it can be 'hacked' and altered.
