BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > N55 Turbo Engine / Drivetrain / Exhaust Modifications > Transmission Possibly slipping?
Studio RSR
      12-19-2013, 12:00 PM   #23
M-terkait
M-terkait's Avatar
Kuwait
210
Drives: F30 335i 3/13
manual shifts are more aggressive & faster than DS shifts unless you haven't noticed that
Docrace 6266
      12-20-2013, 06:14 PM   #24
eyim1988
eyim1988's Avatar
98
Drives: 2022 BMW M4
2022 M4  [0.00]
Originally Posted by kyleb350 View Post
Went back and looked it up. The ZF 6 speed Steptronic (GA6HP19Z) transmission is rated at 400 nm. Very odd, since that is only 295 ft lbs. I think I'm noticing a pattern of these transmissions being underrated (for the most part). Either way, numbers aside, the F30 transmissions should be able to take a little more than the E90 ones.
the limits of the zf 6 speed is about 500 lb/ft. Thats the number people are experiencing slips and whatnot. I'm guessing the 8 speed will be similar.
      12-21-2013, 09:11 AM   #25
435iaffair
Drives: 435i, Z4M, M157 E63
2014 435i  [9.00]
Any updates from the Op?
      12-28-2013, 02:45 PM   #26
Eric SS
Drives: 2016 Chevy SS Sedan
Any update?
Also, these trannies are way underrated as ZF normally does. You think BMW would offer a factory tune that puts out more torque than the tranny is rated for if they were worried?
2011 335is Black/Oyster. 1 of 46 without moonroof (total of all years): JB4 E50 tune, gone
2013 335i M Sport JB4: Estoril Blue gone
2018 M4 ZCP: current
2023 X3M Comp: current
      12-29-2013, 02:15 AM   #27
Presario
Presario's Avatar
Drives: 2018 X3 M40i, 2016 435 GC
Originally Posted by Eric SS View Post
Any update?
The PPK doesn't put out more torque than the tranny can handle. It's right underneath it.
      12-29-2013, 04:25 PM   #28
Eric SS
F30 has the 8HP45 which is rated at 450nm which is 331.9 ft. lbs.
MPPK is (under)rated at 332 ft. lbs. Sorry I was off by .1 ft. Lbs.
I still stand by my statement that ZF has always under rated their trannies. We used to put a shit load of torque through the old ZF unit in the C4 Corvette
      12-29-2013, 05:08 PM   #29
2blu
2blu's Avatar
Drives: 540i XDrive ///M Sport
Do you have specific numbers of what it was rated at vs what you guys would put down ?
GONE: '13 335i X-drive ///M-Sport | GONE: '16 340i X-Drive ///M-Sport | GONE: '18 540iX-Drive ///M-Sport | NOW: '20 X3///M
      12-29-2013, 06:56 PM   #30
Jay562F30
Jay562F30's Avatar
Drives: 2013 F30 Estoril Blue
Nothing yet guys terry has me running on Map 2 at the moment
[FONT="Arial Black"]BMS JB4 DownPipe Flex Fuel[/FONT]
      12-29-2013, 07:11 PM   #31
Eric SS
It's been a while but I want to say the early ones were rated at 450 ft. Lbs. and the later ones with the different gears were rated around 525 ft. lbs.
These were manual trannies but we would regularly put 500-650 ft lbs through them. As long as you didn't power shift to often you would be fine.
Th point is, ZF (like another German company I can think of ) under rate their products
      12-29-2013, 09:28 PM   #32
Presario
Presario's Avatar
Why are you converting to ft lbs? No need. BMW claims 450nm for their PPK. Obviously the 8HP45 is underrated by a manufacture specified margin because they don't want their components running at it's absolute max capacity due to higher failure rate and they also need to factor in user error and safety precautions. Thus BMW takes it right up to the point where it is safe within 8HP45 operating guidelines to ensure consistent performance.
So when you say ZF underrated their trannies, you are citing an obvious fact. Now putting shit load of torque through a tranny without properly factoring in its limitation is just plain amateur.
You must upgrade your transmission along with your other engine mods so that you ensure proper, consistent, and safe operation for the new power output. So getting back on topic, if you are running more torque than what the ZF is rated at, you may very well be experiencing inconsistent performance. To what degree? That can never definitively be answered.
      12-30-2013, 01:44 AM   #33
M-terkait
M-terkait's Avatar
Kuwait
210
well look at this..
am sure thats beyond 450nm
it was a hot day tho, only thing was PPK nothing else.
Docrace 6266
      12-30-2013, 08:07 PM   #34
chetman7
Drives: F80 m3
Originally Posted by M-terkait View Post
well look at this..
....it shows peak torque of 314....which is less than 450nm
Am I missing something?
      12-30-2013, 08:24 PM   #35
2blu
2blu's Avatar
The 314 peak torque must be at the wheel. Add the 15% or so drivetrain loss and you're well over the safe "limit".
Stock N55s dyno at around 300 ft-lbs at the wheels, if you factor in the drivetrain loss once again you should be at or even above the factory tolerance of the transmission.
Also, the dinan tune that was is installed at BMW dealerships does not void your warranty and has over 400 ft-lbs of torque...
      12-30-2013, 09:00 PM   #36
chetman7
Drives: F80 m3
Gotcha..duhhh. completely forgot to factor that in
      12-31-2013, 02:54 AM   #37
Presario
Presario's Avatar
I'm just citing what is stated by ZF and by BMW. If you're putting down more torque than what is quoted by ZF, you should probably change out your fluid more often and expect the transmission's life to possibly be shortened.
F36 435i * MINERAL GREY * ///M Performance | G01 X3 * PHYTONIC BLUE * ///M40i
      12-31-2013, 08:45 AM   #38
btbossman
Drives: 2013 335xi M sport--2014 M6
And thats precisely why I lease cars.
      12-31-2013, 10:56 AM   #39
kaashia
kaashia's Avatar
Drives: 2014 435i MSport
I just posted this in another thread...
Originally Posted by kaashia View Post
While I agree with this, what I wonder is if some of the gasoline engines have the same tranny as the diesel.
http://www.zf.com/media/media/produc..._DataSheet.pdf
If you look at the torque converter for the diesel model
NW 240 DAT.
The gasoline model has the following torque converters -
NW 235 TTD/ZDW/DAT
NW240 DAT
So my guess would be that at least one of those '235 models is rated at 450 Nm.
The '240 model is 500 nM
According to the 8HP55A tranny, the ZDW and TTD models are rated at 650 Nm
Having worked on production systems before, often times manufacturers will use common parts between products to reduce overall costs. Also, given lead times for various parts, manufacturers will have "back up parts" when the typical part is out of stock or back ordered.
In the case 8HP45 - since one of the parts listed can only handle 450 nM, ZF cannot rate the tranny for more than that, even if the other parts can handle much more torque.
Obviously I am making certain assumptions and the above is all theory, but it would explain why people are able to put down way more than 450 Nm without transmission problems. But unless someone can figure out which particular torque converter is installed in their tranny, you wouldn't know if you have the NW 235 DAT.
Just my two cents.
      12-31-2013, 01:54 PM   #40
Eric SS
The only problem with that is that the 8HP55 is a different size on the outside and is heavier than the 8HP45. I would think you would have to change other items such as the driveshaft (but I could be wrong)
EDIT: NM, I think I was thinking of the 8HP70
That begs another question on some data that I found on http://www.google.com/url?sa=t&rct=j...58187178,d.b2I
Hopefully that link works. It's a Chrysler bulletin. It says the 8HP45 has "Engine torque capacity" of 450nm but "Input torque capacity" of 550nm. Does that mean the torque converter is capable of 450nm but the tranny itself is capable of 550nm? At least at Chrysler anyway.
      12-31-2013, 02:47 PM   #41
kaashia
kaashia's Avatar
Good find! I think that your interpretation would be true and would only corroborate my theory. By flipping out the torque converter with some of the models I've mentioned above, the tranny as a whole should handle much more than 450 Nm.
Also, from a logical perspective, it makes no sense for BMW to design the MPPK to output 450 Nm if that is the upper limit of the transmission. Doing so would risk transmission failures on a massive scale (i.e. BMW loses money).
I think its a combo of ZF underrating their transmissions and also I think BMW would like for us to believe that the transmission limit is 450 Nm in order to deter people from using 3rd party tunes (i.e. more money for BMW if MPPK is the only tune people think is safe).
Now that being said, I still plan on being conservative in my mods, but will have some confidence in knowing that the transmission isn't in jeopardy... The chargepipe is a different story...
      01-02-2014, 11:44 AM   #42
bosz
bosz's Avatar
65
Drives: F30 335i Ordered
cant wait for the snow to clear up, I miss my Jb stage 1 <3
**JB Stage 1** 2012 F30 335i/BSM/Coral Red Interior/Diamond Black Trim/Premium Pack/BMW Apps/Ext Blue Tooth/Sirius XM/Sport Auto W/Paddle Shifters/Sport Suspension/Meisterschaft Super GT Exhaust
      01-03-2014, 03:37 AM   #43
1azycat
Drives: 2017 F80 M3 CP
Hi all, my map 2 DP 335i has drivetrain errors and the transmission gets stuck at a single gear if I do full throttle from 2k rpm onwards. Its as if I am running with the torque converter only, without lock up. This happens about 5% of the time when I pull from low rpms at full load. I would then have to stop the car and restart for it to work normally. So now I will wait till im above 3.5k rpm before pushing full throttle. Sometimes I can feel the transmission slippage as well. I think we are at the limits for the 8sp auto...?
      01-03-2014, 03:55 AM   #44
M-terkait
M-terkait's Avatar
Kuwait
210
I don't think so, people are running map7 and daily driving it.
maybe an bad F30 produced for you
Docrace 6266
