BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > Wheels and Tires -- Sponsored by The Tire Rack > Will these fit? F: 19x9 ET20 / R: 19x10.5 ET30?
      10-13-2016, 10:18 PM   #1
Adamt916
Drives: 2013 BMW F30 328i
Hello, I'm new to the forum so I apologize if starting a new thread is the incorrect thing to do for a simple question. Anyways, I purchased some wheels with the dimensions listed in the title. Fronts: 19x9 +20, 225/35/19 - Rears: 19x10.5 +30, 245/30/19 5x120...
The wheels whom I purchased from used these on a 435i on bags no problem. I am still very new to this stuff and this was my first real nice set of wheels. He said these will fit very nice for my car. I have been researching for the past day or so and I literally been on every thread I think trying to find the closest rim specs to mine. Quite a bit of people running some super aggressive setups and don't seem to have any rubbing, then some with less do. So I'm confused about this... I got an amazing deal on these wheels and tires and I hope they will actually fit!
What do you guys think?? My F30 328i is sitting stock atm. Will these rub in the rears? Do I need to fender roll or have the hub shaved by mm?? Add some negative camber?
Thanks very much guys!! Hope I can make these work.
      10-14-2016, 07:52 AM   #2
wdeerfield
A family of bimmers
Drives: '18 G01 X3M40i
no, front is way too aggressive. they will sit 27mm further out than stock 18x8 et34s. pretty sure without camber, stretched tires and a whole lot of low these will not fit and look ridiculous.
this thread from a few days ago is pretty much the same as yours
http://f30.bimmerpost.com/forums/sho....php?t=1313678
2018 PB/Black G01 X3M40i | 699M | ZDA | ZPP | ZPX | Maxton front lip | X3M vents | 15mm Spacers | Diamond G20 style grills
      10-14-2016, 04:05 PM   #3
Adamt916
[QUOTE=wdeerfield;20704412]no, front is way too aggressive. they will sit 27mm further out than stock 18x8 et34s. pretty sure without camber, stretched tires and a whole lot of low these will not fit and look ridiculous. "
I am planning on lowering it and if some camber is needed, I will do that as well. Thanks!
      08-12-2018, 08:45 AM   #4
johnbenedict
johnbenedict's Avatar
Drives: 2016 BMW M3
Question:
Did it end up fitting?
Thanks,
J
      03-29-2024, 05:25 PM   #5
mohamed0112
Drives: 2017 bmw 440i xdrive gran coup
Hey everyone, I was reading through the forum about the offset. I purchased some hre ff04 19x9 et 20 squared. the fitment does look to be very agressive in the front but if i throw on some 225/40 on there, does anyone know if it’ll look alright. anybody have a similar set up as well? Returning them costs way too much, but i might list them up for sale. I’d appreciate any help!
      03-29-2024, 05:55 PM   #6
alohasurftoad
Drives: 440i gran coupe w/mppsk
Originally Posted by mohamed0112 View Post
I purchased some hre ff04 19x9 et 20 squared. the fitment does look to be very agressive in the front but if i throw on some 225/40 on there, does anyone know if it’ll look alright?
225/40/19 will be super stretched on 9". 235/40/19 would be the narrowest i'd stretch on 9".
"alright" is subjective...if stretched tires poking out looks alright to you, then it will look alright. personally i'm not a fan of stretched tires or poke. stretched tires and out of spec neg camber are the only way to have the upper tire shoulder poke less if the offsets are too low. imo both front and rear offsets are too low.
depending on the tire size, the outer shoulder of the front may rub the fenderwell liner while turning at or near full lock
next time, determine the tire size(s), proper widths and offsets before buying. especially if they are big ticket items that are unreturnable...
      03-30-2024, 11:19 AM   #7
weehe126
Drives: 2017 340i
The fronts offset is 10mm too aggressive. Even with a 235 tire you will be poking 15-20mm past the fender on stock suspension. You might not poke if you get camber plates and 2.5-3° of camber. Ideally you should run a 255 on a 9".
      04-20-2024, 12:24 PM   #8
poteznydranf30
poteznydranf30's Avatar
Drives: BMW F30 328i
I have 8" ET30 in the front and 9" ET35 in the rear.
Fits perfectly with the wheel arch (especially at the rear)
19x10 wheels, fitment, question
