07-25-2023, 11:03 AM | #507 |
Rep 1,591
Search for “breite”. There is schmales just two lines above (small/narrow) must be a relation to breite. I used Bimmercode so do not know how Esys does that FDL.
07-26-2023, 04:22 AM | #508 |
Rep 9
Good morning, I currently have the 6.5 inch display with navigation part number is 65509322120, I was hoping someone may be able to tell me if the 8.8 inch part number 65506822626 will just be a straight plug and play swap with coding, car is a 2016 3 series LCI, many thanks.
07-26-2023, 05:08 AM | #509 | |
Getting there
Rep 11
Drives: 320d 2018 LCI
Enter your 7-digit VIN number > Search > Verify you car model/year is correct and select Browse Parts Next page, select the Speaker icon "AUDIO, NAVIGATION, ELECTRONIC SYSTEMS" Scroll down and select the screen unit image "CENTRAL INFORMATION DISPLAY" And now you will see all parts that are compatible with your vehicle. Looking up your screen part number, it came up as a "F34 GT"? Which means you can upgrade to: - 65509292248 - 65509387453 - 65506822626 - 65509270393 - etc Good luck |
Halfb8d86.50 |
07-26-2023, 06:15 AM | #510 | |
Rep 9
07-28-2023, 04:51 PM | #511 | |
Rep 204
07-29-2023, 04:23 AM | #512 | |
Rep 9
07-29-2023, 08:35 AM | #513 |
Rep 813
07-29-2023, 10:59 AM | #515 | |
Rep 813
https://f30.bimmerpost.com/forums/sh....php?t=1711432 |
08-01-2023, 07:57 AM | #516 |
Getting there
Rep 11
11-10-2023, 03:49 AM | #517 |
Rep 3
Hi,
I have been looking to buy a 8.8" for my F20 07/2017 LCI2 with ENAVEVO (ID6 EVO without navigation) , but i still have questions about ehat part number should i buy... I have looked up on realoem.com and got these 3: 65506844126 / 65508709338 / 65508709338. I was about to buy the 65508709338 but i just found out that some people have problems with screen that are touch, but the non-touch work just fine... i found a screen with the part number 6822626 that is a non-touch, but it is for f30, so i dont know if it would work for my F20. I think i have seen one or two people with F20 that have used this screen, but im not sure... Anyone can help? Anyone with f20?? |
