BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > Suspension | Chassis | Brakes > Blue M Sport Brakes
      06-27-2014, 11:37 AM   #23
335i_4D
Now in the dark side !
335i_4D's Avatar
Drives: 2011 911S 997.2 Cab
Originally Posted by Wlodi View Post
Wrong.
There are 2 versions of blue calipers.
34116799465 - left
34116799466 - right
SAME SIZE AS STANDARD 335i F30 - will work with 17" rim and up to 340mm rotor - used also in f20 series
Like you said, same as 335i original, so why change (and pay 500 - 600$ per calipers) if only for the paint.
So if you like this setup, and still want to use your 17" winters, do like I'll do:
Paint the front the color you like, and only get the back ones.
Upgrades for the 328i and 335i are (either M Sport blue or M Performance red-yellow-orange):
370mm disks with matching calipers front
345mm disks with matching calipers rear.
Present: 2011 Porsche Carrera S Cab, white (Now on the dark side!)
BMW X3 M40i (wifey)
Past:2012 335i Sport Black, 20" 356 wheels, M Sport Aero, MPE (Sold -kinda missed)
2010 X5 35d Black fully loaded (Sold)
2007 335i sedan Antracite (Sold and missed !)
      06-27-2014, 01:30 PM   #24
Sedan_Clan
Law Enforcer
Sedan_Clan's Avatar
Brazil
25055
Drives: '22 Chalk Gray Porsche C2S
...because the rear calipers in the M-Performance kit are different than an M-Sport 335i and the rotors are bigger on all four corners. I did the MPB upgrade on my 335i and there is a noticeable difference, and the software/anti-lock brake integration is upgraded.
      06-29-2015, 10:03 AM   #25
majkouch
Czech_Republic
Drives: e92 335i
Hi,
just found this post and have one additional question.
The difference between calipers is clear, BUT which brake pads should I use for calipers 34116799465/6 with 340mm rotor and which ones for calipers 34116799469/70 with 370mm rotor?
Thanks to anyone who can advise on this!!
m.
      06-29-2015, 10:36 AM   #26
Nomana
Nomana's Avatar
1466
Originally Posted by ybbiz34
Originally Posted by Gastoys View Post
I read a couple of reviews that found little to no difference in performance to stock brakes.
Why not spend the money on Brembos?
First of all, the standard 4-piston fixed front calipers on the F30 335i are made by Brembo for BMW.
Second, the M Performance Brake Kit is entirely made by Brembo for BMW. The kit consists of Brembo 4-piston fixed front calipers and Brembo 2-piston fixed rear calipers.
When I had my F30 M Sport 335i, I upgraded to the M Performance Brakes.
When you get a Sport or M Sport F30 335i, the car comes with fixed 4-piston Brembo calipers up front (non-painted) and single-piston sliding rear calipers at the back (Base and Luxury 335i cars might have them too but I only mentioned what I was certain of). The standard rotors have no drilling or slotting present.
When you upgrade to the M Performance Brakes, you get the same 4-piston fixed Brembo calipers up front (now painted in either red, yellow/gold, or orange), and the rear calipers are upgraded to 2-piston fixed Brembo calipers.
Furthermore, with the MPB, you get rotors with dimpling (partial drilling but not full cross-drilling) and slotting. These features both help with keeping the brakes cool by venting hot gasses away from the surface of the rotors.
During daily driving, the two different brake setups may feel similar. This is likely due to the fact that both setups have the same front calipers. In addition, while the M Performance rotors are dimpled and slotted, they are no bigger than the "standard" rotors.
As others have said, when tracking the car, the dimpling and slotting on the M Performance rotors, in conjunction with the larger rear calipers, will both help to mitigate brake fade.
Finally, the biggest difference I noticed between the standard brakes and M Performance Brakes was the pedal feel. With the latter, the pedal felt much less like an "on/off" switch. Instead, you could modulate the brake pedal and be more precise with how much speed you trimmed. In short, the pedal feel was more linear and progressive.
To those not used to BBKs, this may feel unusual because you may have to get deeper into the pedal to get more bite but trust me, as you do get deeper into the pedal, the bite is definitely there.
How about 420i?
Are they the same brake as 335i?
Can directly replace stock calipers with blue one?
      06-30-2015, 12:41 AM   #27
RM7
RM7's Avatar
2893
Drives: Camaro SS 1LE
Originally Posted by Nomana View Post
How about 420i?
In the US,
428 gets 11.8" rear rotors and 12.3" front
428 GC gets 11.8 rear rotors and 13" front
335 brakes are 13" rear and 13.4" front, this uses the m-sport front caliper and a traditional 1-piston sliding rear caliper.
Upgrading to "M sport" brakes on the 428s gets m-sport front AND rear 2-piston calipers, which are fixed calipers and the bigger rotors from the 335. This is a no brainer upgrade if you like brakes (I do). For $600, you get a slightly better braking system than the stock on 335s.
Upgrading to the "M sport" brakes on the 335 for $600 paints the front caliper blue and gives you the blue rear 2-piston fixed calipers. This is not a great deal and doesn't do much for the braking, since most of your braking is done with the front anyways.
Upgrading to the "M performance" brakes on the 335 gets you 14.6" front rotors and 13.6" rear rotors, plus cross-drilled/grooved. Same basic calipers as above on the "M sport", but I don't know what the mounting looks like, since obviously it fits the bigger rotor. Most likely the caliper-half is a different part number from whomever really makes the brakes (brembo does lots of OEM stuff, even the relatively low-end). This could be worth it, but mainly you are getting the bigger rotors. IMO it's $$$ (several thousand) better invested in a real "big brake kit", with 4 or 6 piston stoppers up front and 4 piston in the rear.
      06-30-2015, 12:54 AM   #28
Nomana
Nomana's Avatar
1466
How about 420i?
In the US,
Thank you
I might go for m sport brake and 335 rotor but I just want the look of caliper. Not sure I need the rotor though.
      06-30-2015, 08:36 PM   #29
F32Fleet
F32Fleet's Avatar
Drives: 2015 435i
Originally Posted by majkouch View Post
Hi,
m.
M-Sport line, M-Sport brakes and M-Performance Brakes use same front caliper therefore they use the same size pad.
M-Sport brakes and M-Performance Brakes use same rear calipers.
"Drive more, worry less. "
435i, MPPK, MPE, M-Sport Line
      07-07-2015, 12:21 AM   #30
majkouch
Czech_Republic
Drives: e92 335i
ok, but on guy here has M-Performance with 370mm rotors, I have M-Sport with 340mm rotors, it means these are two different calipers
his: 34116799469/34116799470
mine: 34116799465/34116799466
so how can we have the same brake pads ???
      07-08-2015, 11:55 PM   #31
Piggieback
Drives: 2014 Cayman S, 2015 A3
That's because the Calipers are exactly identical. The part numbers on the calipers are identical, the end numbers are different because of color code. Your rotors are different size, but the calipers aren't, and the brake pads are cross-compatible also.
      07-11-2015, 03:36 AM   #32
obriennathaniel
obriennathaniel's Avatar
so in order for me to get the M performance brakes.....I can just buy the Msport rear calipers and then all 4 drilled/slotted rotors and then paint my front calipers and im good to go?
CG Precision VS-1 Exhaust\DR-1 DownPipe | PS2 Turbo\Inlet | PDU PI w/Fuel-it platinum kit & E sensor | GFB DV+ Diverter Valve | BM3 w/AIC2-V|Tune CaryTheLabelGuy | Full E85 | ATM FMIC | ER Chargepipe Inlet/Outlet | AFE Intake | BC Coilovers | PSS 255/40-275/35 Velos Designwerks S3 two piece 19x9/19x10 | Osram Xenarc | LED retro | AWRON digital AC gauge|
      02-06-2016, 06:45 PM   #33
siy1223
Drives: f32
Guys i have a question. So if i get the blue m sport brake calipers. Tht can fir the 335 rotors? 340 in the front and 330 in the rear? The rear wont be too small?
      02-07-2016, 03:38 AM   #34
oceanview
oceanview's Avatar
Switzerland
207
Drives: 335i F31 RWD Autom.
No! This will not fit.
http://f30.bimmerpost.com/forums/sho...d.php?t=858607
S2NHA M Sport Brakes (blue colored):
S2NHA Variant 1:
Front rotor: 340x30mm (Millimeter) / Brake Caliper with 4 piston
Rear rotor: 345x24mm / Brake Caliper with 2 piston
S2NHA Variant 2: (all 335i/d Version, Europe Version of 325d, 328i, 330d)
Front rotor: 370x30mm (Millimeter) / Brake Caliper with 4 piston
Be aware that rear rotors 345mm are available in tow different version. You need to verify the fit the hand-brake/emergency brake installed.
You possibly also need to change the dust cover plates to fit larger discs.
M4_GTS1152.50
      02-07-2016, 07:02 AM   #35
siy1223
Drives: f32
brakes
S2NHA Variant 1:
Okay thanks. So let me clarify. I definitely need the 345x24mm rear rotors but for the front i can choose either the 370 or 340 rotors? I have a 428ix.
Part #34206797607 and 34116792223 are good? I can buy these instead of the slotted/dimpled ones?
      04-13-2016, 10:07 PM   #36
cmplaya
Drives: B58
Originally Posted by sif30 View Post
like that all blue
even the snow is blue
      04-25-2016, 06:50 PM   #37
PabloK
PabloK's Avatar
I have a complete set front and back for sale.
PM if you want details.
2014 F30 335i / 2014 F31 328d / 2014 F22 m235i
2019 G05 5.0 / 2012 E70 X5 50i / 2007 X5 3.0is
2011 e93 M3 / 2009 E60 M5 / 2004 E46 M3
2017 Alpina B6
22 Ram Trx / 22 M5 CS
      05-03-2016, 09:45 PM   #38
K320
Puerto Rico
131
Drives: G01-X3 30i MSport
If i have a sportline 328i with oem brakes can i only change the calipers to the blue ones or i need to change the rotors too?
      08-13-2016, 06:19 PM   #39
Dmitry83
Russian Federation
54
Drives: F30 320i (328i ECU) M-Sport
The calipers for 370mm and 340mm rotors are different due to 15mm difference in mounting holes position to carry 30mm bigger diameter rotor.
The pads are interchangable as the rotor working surface has equal width (say pad path)- the diameter is bigger so is the brake force arm, the contact area is the same.
'13 F30 320i (328i ECU) RWD M-Sport
Michelin PSS, M-Sport brakes, 320i LCI muffler
F32 bottom V-bar
F80 bottom reinforcement plate
Koni Sport, M-Performance springs, M135i Anti-roll bars
M4_GTS1152.50
      08-13-2016, 06:20 PM   #40
Dmitry83
Russian Federation
54
Both of them.
F32 bottom V-bar
      08-13-2016, 06:24 PM   #41
Dmitry83
Russian Federation
54
Hi,
m.
Do get the F80 M3/M4 pads- also interchangeable and unbeatable in terms of initial bite/fade resistance/brake pedal feedback/rotor wear/price balance.
These are miles ahead the M-Performance (same are in 335i stock fronts) pads, which have low initial bite and dull pedal feedback.
F32 bottom V-bar
      08-15-2016, 06:23 PM   #42
CazuaLLUK
Drives: 2014 335i Black F30 M Sport
I picked up a full set on ebay for £500
      08-16-2016, 07:23 AM   #43
Versipellis
Drives: '17 F36 440i xDrive M-Sport
Huh - F80 pads fit F30s? That's cool.
2017 440i Gran Coupe xDrive MPPSK M-Sport Estoril Blue II w/ Individual Golden Brown Full Merino & Fineline Anthracite Wood
Track Handling + Premium + Cold Weather + Technology + Driver Assistance Packages
      08-16-2016, 08:57 AM   #44
ipilcher
ipilcher's Avatar
433
Drives: 2024 M3 Compensation
How are they for brake dust?
blue, brakes, caliper, f30, msport
