BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > F30 DIYs and Coding Discussions > ISTA+ sanity check
      05-03-2024, 03:10 AM   #1
waza040421
Drives: F36 (4 Series)
ISTA+ sanity check
Hi everyone,
so, i have Esys in one Vmware image on Mac, works like charm. Coded many stuff, belts, start/stop, flash lights, bla bla. Being 10+ years in IT, but not that expert in Bimmer coding, was almost one click stuff.. (ENET cable, F36)
then wished to setup Ista+..
so after trying 3 Winz versions, at least 5 online circulating Ista+ versions and their PSD datasets, and even trying to manually validate sqlite DB's, also trying ExFAT, NTFS, any disk formats, can anyone confirm me that there is some valid version that does not throws errors in log just after starting:
(I can't believe it is because of Virtual machine..)
2024-05-02 11:04:57.221 WARNING [T] ISTA: [13] TypeKeyCharacteristicsHelper.Init - Can't determine the Characteristics for TypeKeyId 20000396776408! Error in Database data!
(ISTA "sees", my car, color, Vin, but when trying to diagnose comes that error), Check PAD, unable to find Vin, please enter 17 chars Vin, bla bla..
yes, yes, VCRedist are installed, .NET framework also, tried online/offline mode, not sure what i haven't tried available online..
full log attached.
Thank you a lot.
      05-03-2024, 07:54 AM   #2
Homersbud
Drives: BMW X1
probably be helpful what version(s) you have tried as you list everything but this info as most newer versions are deltas and not full versions.
4.39 is a standalone that has everything and a one click option installer. you must run the reg fix after installing 4.39 that is included in the download so the registry gets set correctly.
      05-03-2024, 08:27 AM   #3
waza040421
Thank you for the response!
I have tried: all mighty (ISTA_Standalone_4.39.20), 4.32.1, 4.45.20.
Even tried installing 4.39.2 then manually replacing damn SQLite files from 4.45 with manual registry editing.
(each install takes 2-4hours in VM, macbook air on USB disk, it's not that i'm missing some files)
Each version tried with reg fixes, and without. And result is exactly the same. ISTA starts perfectly, sees car in Connection window, even manages to find some basic info when querying only by VIN, but when trying to run ECU diagnostic, errors from screenshots and that DB error in log.
      05-03-2024, 11:03 AM   #4
Homersbud
Drives: BMW X1
don’t mix/match the sqdblites files. they must be the same version as the version of ista installed.
4.45.20 is not any standalone as that requires a license - so not sure what you were trying with this one.
4.39.20 is what i use. is the tcp/ip set to 169.254.1.1?
      05-03-2024, 11:33 AM   #5
waza040421
I have tried those out of desperation. Yes, Ip is set & Ista sees the car, color, VIN, when going to connect & start vehicle test, loader shows 15-25 seconds and then, can't identify VIN from vehicle, enter 17 or 7 characters VIN and that doesn't help.
I do still think root cause of issue is these errors, does anyone have them in logs and manage to do vehicle test?
Code:
C://EC-APPS/ISTA/Logs
      05-03-2024, 11:37 AM   #6
Homersbud
Drives: BMW X1
are you using the sqdblite files from ista 4.39?
if i was you, i would remove ista - delete the folder - clear registry (bmwgroup) & install 4.39 using the default settings then run the regfix afterwards to set the registry correctly.
seems to me like you have jacked up ista entirely and best to start from scratch as there was someone who posted recently they had same issue (non vm) and it was because they did not have the registry set correctly.
https://f30.bimmerpost.com/forums/sh....php?t=1809461
      05-03-2024, 11:48 AM   #7
MacAir
MacAir's Avatar
Drives: BMW F20 and F31
If you have this error, it means that you did not activate correctly
This use if not for programming - ISTA_Standalone_4.39.20
Find -> files_only_for_manual_install -> regfiles_diagnose_only_with_blp -> ISTA_Reg_Fix_x64
For programming with SDP - ISTA_Standalone_4.39.20
Find -> files_only_for_manual_install -> regfiles_full_sdp_blp -> ISTA_Reg_Fix_x64
Homersbud203.50
      05-04-2024, 02:47 AM   #8
waza040421
pozdrav Slovenia!
No, i have activate it as i wrote at least 5 times, on three different Winz installs with Reg clean, and that.. There is nothing more in reg files except 15 lines of registry entries.. no blackmagic
I will try one new full install with programing data..
      05-04-2024, 06:37 AM   #9
MacAir
MacAir's Avatar
pozdrav Slovenia!
PM sent
      05-06-2024, 04:50 AM   #10
waza040421
Just got from parking, so after fresh install from yesterday. VC x64, X68, .Net > 4.8, ISTA_firewall_rules, ISTA_Reg_Fix_min_x64, AppCheckDisable_to_use_different_DBs, regfiles_diagnose_only_with_blp -> ISTA_Reg_Fix_x64. all done
result: the same
when entering VIN in Ista without car connection (to confirm something works). Other screenshots are sttrugle with trying to diagnose via ENET..
This is 10th reinstall, on multiple windows versions so i have no idea now each install is courupt..
      05-06-2024, 08:30 AM   #11
Homersbud
Drives: BMW X1
get a different install of ista. either the copy you have is jacked up or you are simply not installing correctly as ista should have ZERO errors.
When it tells you to reinstall, then the install is corrupt and find yourself a different version.
      Today, 09:21 AM   #12
ciabatta
Drives: BMW 430
Did you ever get it up and running?
