01-25-2015, 05:05 PM | #46 |
Rep 348
Drives: '20 330i MSport
Not hearing any howl but i'll still mention it to my service rep next time i bring the car in..
Also something I found interesting is the service technician said that they only have the ability to balance/road force for speeds up to 70mph.. I notice the slight vibration at highway speeds starting at about 60mph and up. Maybe I should bring the car to a local tire shop and have them check the tires to see if they are balanced correctly ??
2020 330i M Sport 2017 X4 M40i *Retired* 2014 F30 335i M Sport *Retired* |
01-26-2015, 12:28 AM | #48 | |
Rep 522
2017 430i GC
2013 335i 2004 330ci 2003 330xi (Forever in my heart ) |
01-26-2015, 02:00 PM | #49 |
Too much is never enough
655
Rep 3,079
Tires may have internal damage (belts damaged) that's not visible. They'll usually balance just fine because the mass is in the right location, but the tires can "bounce" on the road surface similar to a flat spot.
01-26-2015, 02:04 PM | #50 |
655
Rep 3,079
Yes and no. Worn bushings can affect the dynamic alignment while driving down the road - i.e. rolling friction compresses/deforms the bushings allowing the wheel to stray from the prescribed track. However, alignments are performed in a static setting. So while it's possible to make adjustments for bushing deflection, it's not necessarily effective since they will deflect much more once under way. If bushings are deteriorated enough to affect alignment they are long overdue for replacement.
Back in the day - say pre-1990, conventional steering systems on the majority of cars and trucks had numerous elements and joints comprising the steering linkage. The stacking error of the slop of all of those joints will negatively affect handling long before the components reached their end of life. In other words, they were inherently sloppy. Relatively frequent alignment adjustments were required to compensate for the progressive wear. Today's systems are a totally different animal altogether. With the introduction of McPherson struts, most cars and trucks only have provisions to adjust toe. Everything else is fixed. |
01-26-2015, 03:26 PM | #51 | |
Rep 2,802
So yes. That can cause uneven tire wear. |
01-26-2015, 04:57 PM | #52 |
655
Rep 3,079
01-26-2015, 07:25 PM | #53 |
Rep 348
BMW told me the tires were fine and not damaged..maybe ill bring them to a tire shop and get a second opinion
01-26-2015, 07:30 PM | #54 | |
655
Rep 3,079
It can be very difficult to identify internal damage. |
01-27-2015, 07:06 AM | #55 |
Rep 348
I'm def. going to look into this. Thank you for the suggestion. I know for a fact my car shouldn't be driving like this
