10-24-2015, 11:51 AM | #1 |
Rep 46
Tyre Pressure Reset - not working
HI,
i am a new BMW user and bought a 2015 328i two months ago.. I have tried to reset the tyre pressure but not sure if what i am doing is correct or not - because the tyre pressure doesnt seem to reset at all Steps Tried
Any thoughts |
10-24-2015, 01:06 PM | #2 |
Rep 16,069
Of course, as you haven't done anything to change the tire pressure. The reason for calibration is so you don't get a false warning, or if you rotate tires/wheels. You don't start with any pressure over 32PSI, you start with the recommended pressure. The warning for low pressure goes off when pressure goes a certain percentage below the pressure present when you do the re-set. If you re-set at, for instance, 36PSI then you can get a warning at 32PSI.
10-24-2015, 02:33 PM | #3 |
Rep 4,446
Drives: '23 X1 28i xDrive
I didn't see in your steps that you drove around. You can't reset while stationary. Fill tires to the proper pressure, select reset, then drive a few miles during the reset procedure.
10-24-2015, 03:41 PM | #4 |
Rep 647
The iDrive actually tells you to stay put with engine on. I started the reset at a red light but started driving before it finished. It worked anyways.
10-24-2015, 04:25 PM | #5 |
Rep 4,446
You have to be stationary to start the reset, but you need to drive around to get the full reset completed.
10-24-2015, 08:21 PM | #6 | |
Rep 46
But the tire pressure still stays the same |
10-24-2015, 08:56 PM | #7 |
Rep 16,069
The tire pressure will stay the same until you either add or remove air from the tires. Re-set can't do that for you. All it can do is re-learn the tire positions if you rotate, and change the reference pressure for the low-pressure warning to whatever the pressure is when you do the re-set.
10-24-2015, 11:33 PM | #9 |
but no flokka
523
Rep 717
thankfully the car is fairly idiot proof (or so the germans thought...) it really wants to let you know that your air is low
10-25-2015, 08:15 AM | #10 | |
Rep 4,446
I had this issue--I had 32 front, 35 rear. On a cold morning, the pressures were low, and I filled the tires back up to these levels. But the warning didn't go away, like on my prior cars. Tech said because this system actually shows the pressures, rather than just a pass/fail system, you need to perform the reset after any warning. |
10-25-2015, 09:50 AM | #11 | |
Rep 16,069
Let's assume that you were calibrated to 35 all around. That could set off a warning for the fronts at 30, and filling to 32 probably would not take the warning away, as once the warning goes off the system wants you to fill to the base calibrated pressure. Fill the fronts to 32 and the rears to 35 and do a re-set and your problem should go away. I never had this happen with my old car with first gen TPMS. It would give a warning based on a factory set minimum pressure. Once filled to anything above that minimum, 28 as I recall, the warning went away. But that system wasn't anything like the current BMW, as it didn't have the ability to tell you the pressure, or to do a re-set. It was a simple pass/fail. |
