08-07-2013, 01:27 PM | #45 | |
Rep 210
SCCA & Midwestern Council W2W, '91 Spec Miata, '07
NASA TTD Champion, Midwest, '99 M3, '09 Midwstrn Council TT Champion, BS, '10 GTI, '10 &'11 Midwestern Council TT Champion, BS, ‘17 BRZ, ‘19 |
08-07-2013, 02:08 PM | #46 |
Diligentia Vis Celeritas
558
Rep 1,477
Drives: 335i
I thought a brief press/release of the button put it in "DTC" mode, and a long press turned it off completely... (?)
08-07-2013, 04:36 PM | #47 |
Rep 573
Drives: 2013 F30 335i 8SA M-Adaptive
Correct
08-28-2013, 03:59 PM | #48 |
Rep 349
My head is spinning.
I have 6MT without DHP. Practically speaking, is this possible.. - Have some slip angle, but won't hit a wall if I go a little over the lateral tire limit. Mainly in long high speed neutralish throttle corners. - Won't have nannies kill my throttle steer on corner exit. - Progressive (non-sport) throttle response Yes, I want my cake and to eat it too! That's why I spent $40k+ on a car |
08-28-2013, 08:43 PM | #49 |
Rep 573
Yes, hold the DTC button down till it displays DSC off
You will have heavy steering, normal throttle and the E-diff will be active with no nannies The rest is up to you (I.e. not stuffing it into a wall) but I assure you, a drift is possible I've been doing all my auto crosses in this mode and all it takes to kick the rear out is a squeeze of throttle mid-corner Not a jab, a squeeze. I can also assure you a heavy dose of throttle mid corner will induce a spin-and no computer steps in to stop it |
08-28-2013, 09:05 PM | #50 | |
Rep 349
08-29-2013, 12:54 PM | #51 | |
558
Rep 1,477
Drives: 335i
For the street... Set mode to "Sport", and configure as follows:
For track/autoX... Press/hold DSC button to completely disable DSC and DTC, which configures as follows:
The questions I still have are the following:
08-29-2013, 01:37 PM | #52 |
Rep 573
On the track I slide the transmission into sport with DSC off
This prevents the manual mode from switching back to automatic after 10 seconds of no manual gear changes Kick-down on the automatic is disabled in Sport+ and DSC Off |
08-29-2013, 07:41 PM | #53 | |
558
Rep 1,477
Drives: 335i
So, the kick-down isn't disabled in "Sport" mode even with the transmission selector in sport/manual? Last edited by DVC; 08-29-2013 at 07:47 PM.. |
10-08-2013, 04:12 PM | #54 |
558
Rep 1,477
Drives: 335i
UT - a few things I'm still not clear on regarding the transmission...
I understand that in Sport/Sport+ mode, apparently you get quicker auto shifts when in "D" mode. But does this also affect "DS" mode? Or are the auto shifts always at their quickest in "DS" regardless of the Driving Dynamics setting? Also, I assume that the quicker shifts only pertain to when the car shifts for you, with manual shifts (via the paddles) always at the same speed in any mode... correct? (If this is the case, then Sport mode - reset to "comfort" drive line settings - along with DTC activated, and manual shift mode is the best way to get all the sport-oriented settings without the gonzo throttle response. By the way, I am also curious what settings affect the overrun "burble" sound... is this all throttle setting related, or is it partly to do with the shift dynamics as well? (Or DTC??)
10-09-2013, 08:53 AM | #55 | ||||
Rep 573
So on the track - DSC OFF, slide the stick left, pull a paddle to get to M and you're ready One more thing - the rev-limiter is really soft - hitting it in 3rd @~80mph, you hardly notice it. Hitting it in 1rst is like running into a wall - the change (drop) in acceleration is so immediate, 2nd is about the same - you know when you did it, but 3rd you can spend an extra second on the limiter when you should have shifted to 4th without realizing it. It's not a fuel cut-off, just the ECU limiting the throttle, so no popping/banging/rev-rev-rev'ing - just a steady red-line |
10-09-2013, 01:55 PM | #56 |
558
Rep 1,477
Drives: 335i
Cool - thanks for the intel. I did a bunch of testing on my commute last night and this morning; it's hard to tell for sure, but it seems like everything I experienced is in sync with the above.
Regarding the shift speeds always being the same (regardless of mode) when using the paddles... I meant when the stick is in "DS" mode, regardless of drive train mode. I think you're right that the paddle shifts are always less aggressive when the stick is in "D" mode. As for the exhaust burble, it's hard to tell for sure, but it does appear to be a little more prominent in Sport+ mode (or in Sport mode with Sport drive train settings). So many variables at play here... I think I may throw everything we've learned onto a spreadsheet and post it to this thread for general reference.
10-09-2013, 05:20 PM | #57 | |
Rep 886
If I want the car to be as fast as it can be, hold down the traction control button till all the traction aids go off, pop the shifter to the left and click the paddles for manual mode. If I want the throttle response but don't care about the car being as fast as it can be, I select sport+ and drive in either full manual mode or automatic/automatic sport (this just depends on the mood I am in haha). I usually select Sport+ on the highway or at mid-range speeds where I'm not worried about losing traction and having all the aids step in to cut power.
2015 M3 - AW 6Spd w/ CCB
MCS 2WR Dampers, Spec Twin Disk Clutch, MaxPSI CH, F80Paul Ethanol Tune, 3.5in DPs |
10-15-2013, 08:17 PM | #58 | |
558
Rep 1,477
Drives: 335i
One interesting thing I learned from playing around with the settings is that when in "Sport" or "Eco-Pro" Modes, pressing/releasing the DTC button automatically puts the car in "Comfort" Mode... unlike when you press/hold the DTC button (to turn off DSC entirely) where it sets driveline to "Comfort", but leaves chassis settings in "Sport". So there really is some benefit to having the "Sport+" mode after all, as you can retain Sport driveline and chassis settings, and still enjoy the reduced stability control settings that DTC provides. ** Edit - Table updated in post 68 for a little more clarity, and to show slight differences between transmission characteristics in some modes.
10-17-2013, 05:05 PM | #59 |
Rep 573
Sweet - you must have about as much to do at work as I do
Question - Sailing - what is that? Does the car shut off and let you roll when you're off throttle at speed or something? I ask b/c mine doesn't have that or launch control. I have been driving it for a year though, so I have that going for me |
10-18-2013, 08:49 AM | #60 |
558
Rep 1,477
Drives: 335i
LOL - plenty that I SHOULD be doing, but this was more interesting.
Yes, that's exactly what sailing is... (new for 2014 cars with 8AT) It works pretty well; there's just a slight engine braking slow-down when you touch the gas again as it re-engages a gear. Not sure yet how much of a difference it would make for gas mileage on a long highway trip, but it seems like it would help. (Interestingly, I noticed that it doesn't function when cruise control is active.)
10-27-2013, 05:37 PM | #61 | |
Rep 1,044
How do you configure the drive line in sports mode? I understand you can configure the chassis if you have adaptive suspension but drive line?? I have the no-lines 335i so I don't have sports+ - does that matter? Also, in that table does "throttle" means throttle response? So DSC OFF plus shift lever set to "DS" mode should give me almost everything -- no traction nannies, stiff steering, higher shift points except the "throttle" (whatever that means - I hope it is not throttle response) ? Btw, do Sport or sport+ mode keep the turbo primed for a longer period ? Last edited by rallybull; 10-27-2013 at 06:01 PM.. |
10-28-2013, 11:40 AM | #62 |
558
Rep 1,477
Drives: 335i
As far as I know, driveline can be configured to either Sport or Comfort on any of the model lines (via the Vehicle Settings menu). Sport driveline encompasses throttle mapping (how much gas for a given amount of pedal travel) as well as some other nuances that affect things like the overrun burble, etc. (Not sure if this includes anything related to the turbo.)
Last edited by DVC; 10-28-2013 at 09:52 PM.. Reason: Corrected throttle terminology |
10-28-2013, 03:39 PM | #63 |
Rep 349
Great research! I'm really disappointed there's no way to have heavy steering, normal throttle BUT DTC on.
2013 EBII 328i M-Sport 6MT, M-Performance Brakes, M-Performance Suspension, APEX Arc-8 18 x 8.5 square, Pilot SS
1999 EB1 M3 - Bilstein PSS9, Vorshlag Camber Plates, Kosei K1, ZII Star Spec, PFC, gallon of distilled water. |
10-28-2013, 03:52 PM | #64 | |
Rep 349
http://www.f30post.com/forums/showthread.php?t=904211
10-28-2013, 06:52 PM | #65 | |
Rep 1,044
By the way, throttle response is not "amount of gas for given amount of pedal travel". That is more of a throttle mapping thing. Throttle response is generally considered to be the amount of time the engine takes to "react" when you hit the gas. My first car (years back): I would slam the gas pedal and the car would ask me "Are you sure you want to to go faster?"... I had to reply "Yes please", the car would then say "let me put that command of yours in my today's todo list".... and some time later the car would suddenly downshift and start accelerating. That is an example of poor throttle response. I find poor throttle response extremely irritating. So difficult to plan those difficult overtaking maneuvers. Most people have felt that the throttle response is better in sports mode/DS mode compared to comfort mode. Wonder if throttle response suffers in DSC Off mode. Need to try it out. EDIT: I found that the PPK improved the throttle response a bit. |
10-28-2013, 09:55 PM | #66 | |
558
Rep 1,477
Drives: 335i
** Edit - Both throttle mapping and throttle response are more sensitive in Sport driveline settings
