08-13-2013, 12:19 PM | #4291 |
Rep 88
Hi,
can someone help me here? Before I send the guy some cash... What name do you want to put into your EST? It is shown when you enter the PIN and NOT stored while coding Do I just choose a name? or is it stored somewhere? PIN I guess thats a 4 -5 digit sequence I chose or? Thanks |
08-13-2013, 12:45 PM | #4292 | |
Rep 1,892
RE: the PIN: pick any one you want. You will be prompted to enter it whenever you go try to FDL code a car. |
08-13-2013, 01:11 PM | #4293 | |
Rep 182
08-13-2013, 01:26 PM | #4294 | |
Rep 40,884
http://www.f30post.com/forums/newrep...ply&p=14487749 You need to first read the guides and understand Coding, and Modifying your VO, then you will understand how to change your VO, which you will need to do to switch from Basic Bluetooth to Enhanced Bluetooth, and then you will simply VO Code NBT with modified VO (FA) as follows: Connect => Read FA (VO) => Activate FA (VO) => Read SVT (VCM) => Right-Click on NBT (the ECU itself not the underlying CAFD) => Select CODE.
08-13-2013, 01:51 PM | #4295 |
Rep 40,884
With hardware Activation Model, you should need no coding, as the car never thinks it is moving. I assume this works for all Video, but I am not sure about it also working with Internet.
08-14-2013, 09:13 AM | #4296 |
Rep 60
Drives: F30 330e & E92 335i
Can someone confirm for me for the targetselection in Esys.
F001 > 7-Series? F010 > 5-Series(F10) (Sedan/Touring) F020 > 1-Series(F20) and 3-Series(F30) (Sedan/Touring) F025 > X3(F25) K001 > Mini? PR01 > Rolce Royce? |
08-14-2013, 10:01 AM | #4297 |
Rep 263
for bmw f10 is FRM and KAFAS,
it is equivalent to f30? how to work out connection, to look without unload the car battery thank you Last edited by thebadboy; 08-14-2013 at 01:45 PM.. |
08-14-2013, 02:43 PM | #4298 | |
Rep 40,884
F001 = F01/F02/F04/F07 (5 Series GT) F010 = F06/F10/F11/F12/F13/F18 F020 = F20/F21/F30/F31/F35 F025 = F25 K001 = Motorbike RR01 = Rolls Royce I001 = i3 Like older Exx Chassis, Mini's use R056, which is SP-Daten rather than PSdZData.
08-14-2013, 03:08 PM | #4299 | |
Rep 40,884
KAFAS (Camera Module) should be present in both F10 and F30 depending on the car's options (e.g., Lane Departure Warning, High Beam Assistant, Speed Limit Info). I do not understand your question about the connection and the battery. If you are asking how to connect and code the car without draining the battery, you can and should code everything with the motor running, except the DME Module.
08-14-2013, 09:45 PM | #4300 | |
Rep 263
how to browse all folders (CAFD) without the PC is connected to the car. thank you you know what it is Uploaded with ImageShack.us Last edited by thebadboy; 08-14-2013 at 09:53 PM.. |
08-14-2013, 09:55 PM | #4301 | |
Rep 40,884
As for: ENT VIDEO VORNE GESPERRT Kommentar=Die Funktion sollte die Videoanzeige im CID von TV, MMC, interne Laufwerk sperren I only know its translated meaning: ENT VIDEO FRONT LOCKED Comment = The function should display the video in the CID of TV, MMC, disable internal drive I am not sure exactly what it does. I am guessing it is for use with factory option 601 TV Function.
2018 F06 Alpina B6 650ix GC; Space Grey; Vermillion Red Nappa Leather; Executive; B&O; Driving Assistant 2017 F15 X5 xDrive50i MSport; Glacier Silver Metallic; Black Dakota Leather; Executive; B&O; Driving Assistant; RSE Last edited by shawnsheridan; 08-14-2013 at 10:03 PM.. |
08-15-2013, 05:58 AM | #4302 |
Rep 41
I'm not so sure about that translation
ENT VIDEO VORNE GESPERRT => ENT VIDEO FRONT LOCKED is correct Die Funktion sollte die Videoanzeige im CID von TV, MMC, interne Laufwerk sperren I think means: The function should (have) lock(ed) (or maybe disable(d)?) the showing of video from TV, MMC and internal drive in the CID |
08-15-2013, 06:10 AM | #4303 | |
Rep 40,884
08-15-2013, 07:12 AM | #4304 |
Rep 60
I'm working on a windows application with a database connected to it, so we can have a central place where all codings are stored, people are also allowed to submit new codings.
Will make the application compatible for F series and E series. I will post the app when its done. |
08-15-2013, 08:19 AM | #4305 |
Rep 263
I'm lost, I'm looking at all price encode high beam assist for it on automatically with the headlights
I traveled all the Fembody folder and I can not find ==> Flemish self-aktiv Moreover, in the f30 there is no ecu Kafas. I find it, do you think that will be what I want. thank you Uploaded with ImageShack.us |
08-15-2013, 08:21 AM | #4306 | |
Rep 40,884
08-15-2013, 08:23 AM | #4307 | |
Rep 40,884
08-15-2013, 08:57 AM | #4308 |
Rep 1
Shawn,
Could you please email me the links for the latest E-sys version, PSDZDATA, and EST token? Thanks for your help. Last edited by nonamedesired; 08-15-2013 at 10:01 AM.. |
08-15-2013, 09:15 AM | #4309 |
Rep 263
08-15-2013, 09:53 AM | #4310 | |
Rep 40,884
08-15-2013, 09:54 AM | #4311 | |
Rep 40,884
http://rapidshare.com/files/32018268...ries%20car.pdf VO Code: Connect => Read FA (VO) => Activate FA (VO) => Read SVT (VCM) => Right-Click on ECU (the ECU itself not the underlying CAFD) => Select CODE.
08-15-2013, 02:09 PM | #4312 |
Rep 407
I have searched everywhere and still can't find this: How do you disable the safety feature that puts the car in Park when you try to drive with the door open?
