BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > Mechanical Maintenance and TSBs: Break-in / Oil & Fluids / Servicing / TSBs and Service Bulletin > Torque report. is there an issue with O2 sensor bank1
      07-21-2015, 12:14 PM   #1
mdavis12
El Presidente
mdavis12's Avatar
Drives: 328i xdrive
Hi,
For people familiar with the test result from Torque app, is the O2 Bank1 Sensor 1 FAIL, an issue?
I just got an isaddle mini from amazon. and getting familiar with it. Today I ran the report and got the following. Not sure if this is the right forum to post this, but here it goes.
Mode $06 report generated by Torque for Android
Vehicle VIN:
Vehicle Manufacturer: BMW
Vehicle Calibration ID:
ª
Test report:
MID:$01 TID:$4f
- O2 Bank 1 Sensor 1
Max: 5 Min: 8,273
Test result value: 20,224
FAIL
MID:$01 TID:$63
Max: 5 Min: 8,273
Test result value: 25,344
FAIL
MID:$01 TID:$83
Max: 1.99882 Min: 0.39985
Test result value: 1.08339
PASS
MID:$02 TID:$01
Rich to Lean sensor threshold voltage(constant) - O2 Bank 1 Sensor 2
Max: 0.68808V Min: 0.68808V
Test result value: 0.68808V
PASS
MID:$02 TID:$02
Lean to Rich sensor threshold voltage(constant) - O2 Bank 1 Sensor 2
PASS
MID:$02 TID:$05
Rich to Lean sensor switch time(calculated) - O2 Bank 1 Sensor 2
Max: 650ms Min: 0ms
Test result value: 80ms
PASS
MID:$02 TID:$06
Lean to Rich sensor switch time(calculated) - O2 Bank 1 Sensor 2
Max: 1,000ms Min: 0ms
Test result value: 130ms
PASS
MID:$02 TID:$07
Minimum sensor Voltage for test cycle(calculated) - O2 Bank 1 Sensor 2
Max: 0.20008V Min: 0V
Test result value: 0.12688V
PASS
MID:$02 TID:$08
Maximum sensor Voltage for test cycle(calculated) - O2 Bank 1 Sensor 2
Max: 7.99527V Min: 0.75152V
Test result value: 0.81008V
PASS
MID:$02 TID:$86
Max: 650ms Min: 0ms
Test result value: 50ms
PASS
MID:$02 TID:$87
Test result value: 40ms
PASS
MID:$21 TID:$81
- Catalyst Monitor Bank 1
Max: 655.34998% Min: 100%
Test result value: 204.12999%
PASS
MID:$35 TID:$80
Max: -24.75° Min: -47.25°
Test result value: -36.09°
PASS
MID:$35 TID:$81
PASS
MID:$35 TID:$82
Max: 32.2° Min: 12.2°
Test result value: 23.79°
PASS
MID:$35 TID:$83
PASS
MID:$3c TID:$81
- EVAP Monitor (0.040")
Max: 65,535minute Min: 10minute
Test result value: 150minute
PASS
MID:$3d TID:$8f
- EVAP Monitor (0.020")
Test incomplete or dependant test failed
MID:$3d TID:$90
MID:$3d TID:$94
Max: 65,535 Min: 3
Test result value: 3
PASS
MID:$41 TID:$85
- O2 Heater Monitor Bank 1 - Sensor 1
Max: 6,553.5°C Min: 765.10004°C
Test result value: 825.10004°C
PASS
MID:$42 TID:$81
- O2 Heater Monitor Bank 1 - Sensor 2
Max: 1,544Ohm Min: 0Ohm
Test result value: 92Ohm
PASS
MID:$4f TID:$9d
- O2 Heater Monitor Bank 4 - Sensor 3
Max: 53,230 Min: 22,537
FAIL
MID:$7e TID:$d8
Max: 53,022 Min: 22,537
Test result value: 25,939
PASS
MID:$81 TID:$60
- Fuel System Monitor Bank 1
Max: 5 Min: 8,273
Test result value: 24,704
FAIL
MID:$a2 TID:$0b
EWMA Misfire counts (average) for last 10 drive cycles - Misfire Cylinder 1 Data
Max: 65,535Count Min: 0Count
Test result value: 0Count
PASS
MID:$a2 TID:$0c
Misfire counts for last/current driving cycles(calculated) - Misfire Cylinder 1 Data
PASS
MID:$a3 TID:$0b
EWMA Misfire counts (average) for last 10 drive cycles - Misfire Cylinder 2 Data
PASS
MID:$a3 TID:$0c
Misfire counts for last/current driving cycles(calculated) - Misfire Cylinder 2 Data
PASS
MID:$a4 TID:$0b
EWMA Misfire counts (average) for last 10 drive cycles - Misfire Cylinder 3 Data
PASS
MID:$a4 TID:$0c
Misfire counts for last/current driving cycles(calculated) - Misfire Cylinder 3 Data
PASS
MID:$a5 TID:$0b
EWMA Misfire counts (average) for last 10 drive cycles - Misfire Cylinder 4 Data
Test result value: 1Count
PASS
MID:$a5 TID:$0c
Misfire counts for last/current driving cycles(calculated) - Misfire Cylinder 4 Data
PASS
MID:$b0 TID:$4c
Max: 53,022 Min: 22,553
Test result value: 51,523
PASS
End of report.
      07-28-2015, 03:39 PM   #2
Ganxxta
Drives: F32 4er Coupé
I checked mine, didn't have any issues with the O2 sensors.
However I didn't get the same amount of sensor like you have, so for example the misfire counts were completely missing.
Do I need to do something special to get all the data or do I have to wait longer?
Also N20 here.
      07-28-2015, 06:16 PM   #3
mdavis12
El Presidente
mdavis12's Avatar
Drives: 328i xdrive
after driving the car for a while i noticed it shows more PIDs compared to right after starting. Been searching what the number mean. Dropped my car of at the dealer to get it checked out. Will update once I get it back.
      09-12-2015, 03:01 PM   #4
FSociety
IG @bmwF9xG80
FSociety's Avatar
3813
2023 BMW G80 M3  [0.00]
2020 BMW X4MC  [0.00]
16' BMW X4 M40i  [10.00]
06 Cadillac STS  [0.00]
What was the result?
60-130mph 6.5s X4M #HCP
60-130mph 5.0s G80 M3 #OrlandoAutowerks Sauce
IG: @bmwF9XG80
      09-12-2015, 03:37 PM   #5
mdavis12
El Presidente
mdavis12's Avatar
Drives: 328i xdrive
the dealer said they did not acknowledge those PID as there were no code thrown. But they ended up finding a faulty map sensor and replaced it. and updated the i-level on the car (i dont really understand the i level stuff).
      09-12-2015, 03:39 PM   #6
FSociety
IG @bmwF9xG80
FSociety's Avatar
3813
Cool thanks, so I guess as long as there no CEL or lights then it wouldn't matter too much.
IG: @bmwF9XG80
