09-26-2017, 11:09 PM | #1 |
Rep 144
Drives: 2023 M3 Competition xDrive
USR Angel Eye Beam pattern
Hey guys,
I've had my lights installed for about 8 months now and love the better output of the projectors and morimoto elite hid kit, but still not completely satisfied with the beam pattern. Does anyone else have pictures of what your beam patterns look like? Here are mine from about 20 ft away and 3 feet away. Any ideas/suggestions are appreciated |
09-27-2017, 08:20 AM | #2 |
Rep 16,065
That doesn't look bad, but the right side should be aimed higher than the left, so that the side of the road is illuminated at a longer distance without bothering oncoming traffic.
09-27-2017, 08:59 AM | #3 | |
Rep 1,686
Drives: 2014 428i and 2018 X5
Good to know, thanks.
___________________ 2014 F32 428i M-Sport 2018 F15 M-Sport |
09-28-2017, 12:39 AM | #4 | |
Rep 103
That's not a normal HID projector beam pattern. The projectors were likely made for halogen bulbs. Hard to see from the photo, but it doesn't look like there's a good hotspot, the light is dispersed everywhere as opposed to along the center of the cutoff. This throws too much light at the foreground, constricting your pupils and your ability to see further down the road. OP, you might want to try shimming the bulb in your passenger side headlight. The bright spot should be centered with the step, but in the top photo it looks like it's too far left. You might be losing some beam width. Measure the distance from the ground to the center of your projector. Mark the same height on your wall with some tape. At 20 ft, the lower step of the driver side headlight should be about 1.68" to 2" beneath the tape. Last edited by atam1980; 09-28-2017 at 12:53 AM.. |
dr adequate91.00 |
10-31-2017, 03:19 PM | #6 |
Rep 327
I have the same headlights and have the same issue. The problem is that there's a step in the cutoff shield itself inside the headlights. If someone was able to open up the housing and sand down that step you would get a nice even line all across.
Mods: MHD Stage 2+ FlexFuel, xHP Stage 3, VRSF 5" HD Intercooler, VRSF Charge Pipe, CircuitWerks Catless DP, AFE Pro Dry S Intake filter, Eldor coils, NGK 97506 @ .026, Bilstein B14 coils.
dr adequate91.00 |
03-17-2018, 01:44 AM | #7 |
Rep 92
Hmmm. Seems like we've all got similar issues with the beam pattern. My beam looks almost identical to yours. It's kind of distracting because those "dead zones" grow and shrink depending on the distance the lights traveling. I notice it a lot when making a turn, and the pattern shining against a wall transforms as the distance to the wall changes.
Is the consensus to just live with it? I was considering to reorient the bulbs a bit this weekend, but now thinking twice about it.
F30 328i Mineral Grey Metallic, M Perf Kit, M Perf Exhaust, Matte Black Kidney Grills, H&R Sport Springs, 19" Velgen VMB5 Rims.
03-17-2018, 09:51 AM | #8 |
Rep 804
i think mine is F up. headlight adjustment is on point but when start driving on the road you see the left side has a dark spot. using stock h7 bulbs but hid comes in today. well see if that helps or not
03-17-2018, 10:13 AM | #9 |
Rep 2,382
They won't get rid of the spot, but the brightness helps. Unfortunately that's just the beam pattern.
2013 F30 328i: MHI Big Turbo, GFB DV+, Mishimoto CAI, ER TIC/CP/Catless DP, AWE Touring Quad Exhaust w/ Resonated Midpipe, NGK LI Plugs, BM3 with PTF Stage 2 91 AGG Tune, Fuel-it Stage 2 LPFP, Solowerks S1 Coilovers, and DEPO/M-Sport Retrofit |
03-17-2018, 10:25 AM | #10 | |
Rep 92
It may just be that there's not much you can do... the design of the cutoff shield may be the issue inside the projector. And you're using halogen bulbs, which is what the headlight was designed for.
