04-06-2020, 01:18 PM | #1 | ||
Rep 3,549
Why Adjustable End Links?
So andino and I recently swapped our front and rear end links for KC Design's adjustable ones. Both of our cars are set up in a way that can actually take advantage of them. For most people, the stock end links are just fine, so what about our cars made adjustable ones worthwhile?
The end link provides the most leverage on the sway bar when it's at a 90deg angle to the effective lever arm. As you deviate away from that, the force applied to the sway bar is less than the force applied to the end link, so your sway bar effectiveness is reduced. As the ride height is changed we also run into a preload situation with the stock sway bar bushings on the F2x/F3x platform. The front bushings are permanently mounted to the sway bar and thus have a specific natural resting position. As the ride height is changed the bar is twisted out of this position and those bushings apply a preload to the bar trying to bring the bar back to the natural position. The stock rear bar's bushings aren't permanently attached, but have high enough friction that the rear bar doesn't twist within them very freely (you can change this though with grease). If you have aftermarket sway bars, the bushings are usually polyurethane and come with grease, so the bars spin freely within the bushings. We can also have preload due to different ride heights between the sides of the car. If the car naturally has different heights side to side, then if the same length end links are used, the bar will be trying to make both sides match with load. For andino's case, he likes his ride height decently low, so his end link geometry wasn't ideal, and he had a fair amount of preload on the stock front bar. In my case, I'm not too far off from stock ride height, so I didn't need the adjustable end links for geometry purposes, but I do have aftermarket sway bars and want to be able to play with the settings, which requires adjustable end links to dial in the proper geometry with those mounting positions. So what's the felt effect of doing this? In andino's case he noticed less bump steer and improved comfort due to improved suspension independence. Each corner was able to move without upsetting the other side as much as before. If you've only lowered your vehicle slightly (say up to about 3/4") then changing to adjustable end links probably isn't worth it. Beyond that though, it might be something to consider. Also if you're using aftermarket sway bars you might want to consider it. From all the bars I've had, the mounting points aren't exactly in the same position as the stock bars'. andino and I both used KC Design's adjustable end links, which have a solid build, and easy to adjust feature. You can see more about them below. Quote:
04-06-2020, 06:08 PM | #3 |
GasCompressor
333
Rep 564
So I have purchased and getting close to installing new Eibach springs on my F32:
2022 Porsche 911 Cabriolet Agate Grey/Black PDK 2019 440i M-Sport Smoke Topaz Metallic/Opel (Sold) 2014 335i M-Sport Black/Beige MPPK/MPE (Totaled) 2013 328i Sport xDrive Imperial Blue/Grey (Sold) |
04-06-2020, 06:17 PM | #4 | |
Rep 3,549
The nice thing about the front end links, is they're not too difficult to replace, so you can always do them later.
04-07-2020, 10:44 AM | #5 | |
GasCompressor
333
Rep 564
I am installing the Eibach Pro-Kit for xDrive and it lowers the vehicle 3/4" to the approximate height of the standard RWD Sport suspension. What if I was to just change the sway bar to the RWD version? Seems that a 2 MM thicker bar and the stock height could help in overall handling without swapping out the end links and use that money for stock sway bar? Thoughts?
04-07-2020, 12:10 PM | #6 | |
Rep 681
2016 328ix F31 - SOLD!
2006 997.1 C4S |
kpgray333.00 |
04-07-2020, 02:48 PM | #7 | |
Rep 3,549
kpgray333.00 |
04-08-2020, 12:03 PM | #8 |
Rep 1,079
I think I might be experiencing some bump steer after installing KW V1 and lowering it about 1.5" all around. No issues with comfort. Probably need these adjustable end links.
I also notice a small back and forth rocking on full stop, probably due to the progressive springs being softer on resting height, or preload on sway-bars? Last edited by thatBimmerBloke; 04-08-2020 at 04:17 PM.. |
08-27-2020, 01:22 AM | #9 |
Rep 1,296
FaRKle! i’m going to get aftermarket eibach antiroll bars, and bought these kcdesign endlinks; i’m on lowered springs, -25mm front, -30 rear. (Vs base model i suppose, so -15/-20 vs m sport)
i noticed in your video the max adjustment of 320mm is close to stock 315mm on front endlinks at least, so i’m not sure why the range doesn’t allow to extend the bar further since when you’re lowered you need to extend the front endlinks. Am i missing something? Great video though, very helpful!
2017 M550i | Sophistograu
Previous cars: 2014 F30 ActiveHybrid 3 | 2012 f20 M135i |
08-27-2020, 11:38 AM | #10 | |
Rep 3,549
Lancelot576.00 |
08-28-2020, 11:34 AM | #12 |
Rep 3,549
AFAIK they don't have any 3rd party resellers/distributors. If you email them (kc7133@gmail.com) they can send you a PayPal invoice. This is how I've done the many orders I have with them. They typically respond in under 24hrs.
08-28-2020, 12:19 PM | #13 | |
Rep 1,296
08-31-2020, 09:12 AM | #14 |
Rep 320
05-07-2021, 04:34 AM | #15 | |
Rep 1,004
05-07-2021, 10:13 AM | #16 | |
Rep 3,549
05-07-2021, 08:22 PM | #17 |
Rep 1,004
even though on ohlins the whole strut lowers through the bottom sleeve for the knuckle? i am going to measure with the hub jacked up to ride height with the wheel off. for some reason im thinking shorter but i know you have done a lot of research and i use your videos a lot. thanks for giving back.
05-23-2022, 09:29 AM | #19 |
Rep 1,934
So I just installed the ohlins for xdrive. Endlinks are on hospice. Looking at the Hotchkis and Turner custom length. They really look the same.
I see stock length is ~313mm once converted from your video FaRKle!. Turner provides them in lengths 290-305mm and 320-335mm which is noinclusive of stock length. Shpuld the latter be fine with its minimum length being longer than stock already? I'm currently at 14" fender to axle in thr front and can't go any lowet in the front because of the links
05-07-2023, 01:58 PM | #20 |
Car Hypochondriac
336
Rep 904
Anyone have any experience with any of the adjustable endlinks and the adaptive suspension? The OE links have a different design for the front right, want to verify if the adjustable sets work.
05-09-2023, 10:40 AM | #21 |
Rep 18
What’s up guys, question here, so I changed just about the whole front assembly in the cars suspension (rwd non adaptive) all I really left out was the tie rods which I’ll do when I see wear on them but I was doing some research after I got my end links and when I went to put on the driver side one I noticed it almost didn’t really wanna fit, what I ended up doing was rotating the whole shock assembly from the knuckle and I got the end link to fit, now when I drive, I hear a clunking sound on pot holes, as I been looking into it, seems like xdrive cars have a different end link than a rwd car, I’m guessing they sent me the wrong end links when I ordered them since it was a bit of a hassle to put it on (again only the driver side) anyways I just want to confirm if that’s true? Also would the xdrive ones fit on a rwd theoretically? As I got it on but again I’m not sure if what I got was the right part or not but the fact that I had to move the whole strut to get the end link in the slot makes me think that I got the wrong part. Also the clunking adds to my suspicions that I got the wrong part, I have driven the car, turned the wheel to the far left and right, nothing seems to sound off, only when I go over bumps, regardless I’m gonna lift the car and take another look down there, but any info would be appreciated!
05-09-2023, 10:43 AM | #22 |
Car Hypochondriac
336
Rep 904
Realoem says they are the same part between RWD and x-drive. 31306792211
Handling mods: Koni yellow - Eibach prokit - Millway street - M Performance LSD - M3 brakes - EBC bluestuff Exterior: Euro LCI tail lights - Shitty ECS CF spoiler - Chinese M performance diffuser Interior: Bavsound stage 1 and subs - custom trunk sub by Mike1327 |
