11-26-2018, 11:31 AM | #1 |
Rep 9
Sport+ for Trackday?
Heading to Sebring in December. What setup do you guys run with? DSC off? Sport + with M/S?
I'm a novice driver and safety is more important to me than squeezing out a few extra seconds. Thanks! |
11-28-2018, 12:58 AM | #2 |
¯\_(ツ)_/¯
947
Rep 1,762
Sport, keep your traction on since you're a novice especially if you've never been to the track before. The last turn has A LOT of bumps and turning off traction will really put you at risk of losing control.
11-28-2018, 08:55 AM | #3 |
Rep 891
Sebring is famously rough so definitely keep everything on for your first visit, but that's for any first visit to any track.
I never was a fan of sport mode, have found it too sensitive to modulate to my liking. I always run comfort with dynamic stability on track.
328i RWD | MW on CRed Slick Top | 6MT | BM3 | MPE | GPlus FMIC | CSF Radiator | Millway Street Camber Plates & Monoballs | KW V2 6k/18k Swift Springs | F80 LCA/TS | SPL Bump Steer Kit | APEX SM-10 | R-S4 | DS2500 | RBF600 | SS Lines | Past: E36 328is & E38 740i |
11-29-2018, 08:08 AM | #4 |
Rep 9
Thanks for the tips! This is my second Sebring event. The first time I ran in Sport mode and "D" with a fully stock 428. I have made some modifications as I hated the brake performance. Changed the run flats to Indy 500's (245/40/16 all around), CoolCarbon Brake Pads, Motul RBF660 brake fluid, Remus Quad Exhaust, BMS Stage 1 Tune, and a front bumper M4 conversion with a front lip for that extra 50 whp Will post some pics after the event.
jmg18774.50 |
11-29-2018, 12:22 PM | #5 | |
Rep 1,934
jmg18774.50 |
11-29-2018, 12:58 PM | #6 |
Rep 1,597
11-29-2018, 01:00 PM | #7 |
Rep 1,934
How does a tire handle well without traction? That's literally all it is meant to do correctly lol.
11-29-2018, 01:54 PM | #8 |
Rep 1,597
11-29-2018, 02:40 PM | #9 | |
Rep 891
To get that back that stiffer handling, match the suspension to the new tire, just like BMW did by building a soft suspension around the RFT. Understandably not a simple job, but this is the track and AutoX board after all.
11-30-2018, 11:33 AM | #11 |
Diligentia Vis Celeritas
558
Rep 1,477
Drives: 335i
There's nothing from a performance standpoint that's better about run flats. With the right tire choice, wheel/tire widths, and tire pressures, a set of conventional tires will outperform RFTs in every way.
That said, RFTs nowadays are actually getting pretty good.
11-30-2018, 01:50 PM | #12 | ||
558
Rep 1,477
Drives: 335i
It's never a bad idea to start the event off in Sport mode...as you come up to speed, keep an eye out for the DSC light coming on to let you know where it's intervening. If you're able to mentally multitask on track, think about WHY it came on... was it because you need to be smoother in that section? If so, try to do better there next lap. Once you're cognizant of the areas where DSC was intervening (and let your instructor know, if you have one), switch to Sport+, which allows MUCH more leeway in terms of slip angles. In Sport+ you'll be able to tell whether the DSC was coming on unnecessarily in Sport, or if it was saving you from breaking loose.
12-01-2018, 08:40 AM | #13 |
Yoda of mods
1676
Rep 3,006
Drives: X5 RWD
Agreed.
12-01-2018, 08:48 PM | #15 | |
Rep 1,597
12-01-2018, 09:03 PM | #16 |
Rep 1,934
Tire dependenant really. You have to see how they react after a run or two and adjust appropriately. There's a thread in this section somewhere
12-01-2018, 09:21 PM | #17 | ||
Rep 891
12-03-2018, 04:43 PM | #18 |
558
Rep 1,477
Drives: 335i
Agreed. I run RE-71Rs (265/35-18 square) and generally shoot for 36-38psi hot... so depending on ambient temp, I typically start at 30-32psi cold.
zinner559.00 |
12-05-2018, 04:39 PM | #19 |
Rep 14,121
Drives: G82 M4C X-Drive
I'm still a beginner, but I've been told 38 cold is too much cold. After your warm up laps you want to be below 40 psi. Your onboard TPMS can be very handy, I leave it on while lapping.
2022 G82///M4 Competition X-Drive - KW-HAS, EBC Bluestuff, Millway Race Camber Plates, Cup2 Connect*, PSI High Flow Midpipe, Lightweight Front Lip, M Perf Flow Through Wing Previous • 2018 F80 ///M3 CS • 2016 F80 ///M3 IG: Raging_G82 |
12-07-2018, 06:19 PM | #20 |
Rep 103
I tracked my 440i for the first time recently - the run flats had plenty of grip although I'm sure if I got much faster I'd find their limits. One thing I noticed was that after 5-6 hard laps my (stock) brakes started to fade and times started going up.
Sport +; transmission in manual (ie on the paddles); AC off; The BMW app is awesome by the way - don't try and interact with it on the track - just hit record in the pit lane and let it do its thing... |
nissanite45.50 |
12-10-2018, 04:38 AM | #21 |
Rep 192
I have a manual on non-adaptive shocks so no suspension or shifting changes for me depending on drive mode.
I tend to keep it on Sport+, so DSC partially off. I find it keeps me smoother with my inputs since mashing the throttle will cause the DSC to cut in killing acceleration out of corners. Plus I like the quicker throttle response. Having said that, if I'm REALLY going for it, It's DSC off all the way. The slow throttle bothers me, but I do find the eLSD somewhat useful. However at my local track there are a couple of 90+ 100+mph corners that demand total commitment and they will make the DSC light up like a chirstmas tree, so in DSC off mode it can be somewhat unnerving knowing that if you mess up there aren't any nannies to catch the tail and going off track at 90mph is bound to make you real close and personal with the barriers... So yeah, I'd probably start with the nannies enabled and if you find you're comfortable, switch them off progressively. |
valve float162.50 |
12-10-2018, 09:22 AM | #22 |
Rep 68
Drives: 340i M-sport
I am an instructor and have been racing or DE since the early 80's.
I also have been a UHP education specialist for Bridgestone. I have seen hundreds of driver and tires at the track. If you drive without activating DSC then leave it on for emergencies. If you are getting slip,turn to Sport+ and be cautious. Overdriving with DSC on will cause extra load on the outside edge of the front tires and eat the shoulder off in a day. The nannies will mask a lot of driving skill deficiencies and you will learn more with it off. Just use caution and work your way up to speed. PS. The slightly stiffer sidewall of a RF gives more support in the corner. Grip is compound dependent. |
