11-06-2017, 01:37 PM | #1 |
DINAN SELLER
170
Rep 544
SKU: D440-1639-ST2 Stage 2 DINANTRONICS Performance Tuner
Lowest price offered with free shipping Loaded with both maps!! For 3 series MODELS F30, F34 and 4 series MODELS F32, F33, F36 Stage 1 (DINANTRONICS Performance Tuner ONLY) Maximum Power: 360 HP, 392 lb-ft of torque. Stage 2 (DINANTRONICS Performance Tuner in conjunction with Dinan Intake and Exhaust) Maximum Power: 384 HP, 417 lb-ft of torque. Dinan stage 1 and 2 Dinantronics tune, comes with both that can be selected at your discression. This is a used in great condition unit and has been tested and verified working perfectly. comes with all wiring and connectors needed for this very easy 30 minute install done at home. No programming needed as the unit is ply and play. The is for cars without MPPK and have a EWG from 2012-2015. Dinan only covers the original 4 year 50k warranty from BMW. They do not work with CPO warranties or any BMW extended coverage, only the BMW new car 4/50k warranty. For those members thinking this will be covered with DINAN and BMW with your extended warranty you are wrong. SO save 1300$ from a new one and enjoy the great power increase. Retails for $2316 Special Note: This kit is currently NOT for cars equipped with BMW M-Performance software (MPPK). For MPPK equipped cars there is a separate part number. This version of the DINANTRONICS Performance Tuner is ONLY compatible with vehicles equipped with an the N55, electronic waste gate and no MPPK. Vehicles with a manufacture date prior to 07/2013 should utilize a mechanical wastegate. Vehicles with a production date after 06/2013 should utilize an electronic wastegate. Only a visual identification is 100% accurate. Installation Plug-and-Play installation in two hours or less, DIY at home, very easy install, comes with detailed video and instructions, ships in dinan box Easy To Use Dinan's ECU is Bluetooth® Smart meaning that you can change maps simply via a Bluetooth connection on your iPhone or Android device. Just install and you are done! Being Relisted Last edited by Dinan_Rated; 11-20-2017 at 10:10 PM.. |
11-07-2017, 02:45 AM | #5 |
Rep 77
Glws I thought I could pickup
Dinan_Rated169.50 |
11-07-2017, 09:17 AM | #6 |
DINAN SELLER
170
Rep 544
11-07-2017, 07:07 PM | #9 |
DINAN SELLER
170
Rep 544
11-09-2017, 01:39 PM | #12 |
DINAN SELLER
170
Rep 544
FS:SKU: D440-1639-ST2 Stage 2 DINANTRONICS Performance Tuner $1100
11-10-2017, 11:12 AM | #13 |
DINAN SELLER
170
Rep 544
Can’t believe this is still here for sale. Come and get some power, upgrade your baseline sport bypass tune and see what a true dinan tune can do for your car when all parameters are adjust to account for the power. Oem feel!!. Night and day upgrade with smooth linear power. Less then 50% of retail price.
11-10-2017, 08:27 PM | #16 |
Rep 44
Still available?? I'm not super happy with Dinantronics Sport.
Dinan_Rated169.50 |
11-11-2017, 09:15 AM | #18 |
DINAN SELLER
170
Rep 544
I can understand the disappointment with the sport tune, not really anything different except the throttle response change.
This however will not fit if you have the B58 engine. I can source one for you at this price point, LMK |
11-11-2017, 11:31 AM | #19 |
No 55mph
1622
Rep 8,476
Back when I was shopping tunes I looked for ages to find this at a good price - now it pops up
Since then I went with Active8 tune & I'm happy, just wish this would have been available back then GLWS
Dinan_Rated169.50 |
11-11-2017, 12:32 PM | #20 |
DINAN SELLER
170
Rep 544
thank you!, here if you need anything DINAN at a great price. there will be more builds for ya
