05-05-2015, 12:26 PM | #1 |
Rep 100
Which front lip for F30? I drive HARD.
Hey guys I've finally decided to pull the trigger on a front lip for my M sport 335xi. The car is lowered on Dinan Springs, and I drive rather spiritedly most of the time. That being said, I don't want to smash the damn thing off within the first week of having it. The car is my daily, and the roads aren't the best around the SF Bay Area.
All that being said, which lips have you all tried? How was the fit? How was the ground clearance? And how much did it cost? I'm thinking to get a lower cost lip at first to see if I can deal with it and then perhaps upgrading to a nicer one if everything works out. Feed back is appreciated!
2014 Mineral Grey 335xi ZMM, ZPP, ZCW, ZDA, ZTP.
Performance: FBO; MPE, Brembo M BBK, ER CP, ER DP, Phoenix IC, JB4, KW V2, Mechunik Front Tower Strut Brace, Michelin PS AS3+, JL Audio W6 10" HO sealed/ported box, and a bunch of other stuff you probably don't care about either. |
05-05-2015, 05:15 PM | #2 |
Rep 1,556
The difference between the lower ebay one and the BMW one is near impossible to tell. Save your coins on the lip and go ebay for that. That way when you scrape it, which you will, won't feel as painful. LOL.
05-05-2015, 06:10 PM | #3 |
Rep 100
Link?
05-05-2015, 06:24 PM | #4 |
Rep 135
05-05-2015, 06:42 PM | #5 | |
Rep 100
05-05-2015, 08:42 PM | #6 |
Rep 101
I just ordered this one from Selma based on how many others ordered from them and said the fitment was great. Here's the link.
http://www.ebay.com/itm/181625783335...%3AMEBIDX%3AIT |
05-05-2015, 09:41 PM | #8 | |
Rep 100
05-05-2015, 09:55 PM | #10 |
Rep 101
Here is the main thread with tons of pics and details.
http://f30.bimmerpost.com/forums/sho....php?t=1089224 |
05-06-2015, 12:54 PM | #11 |
Rep 1,556
I have the Selma one. It fits perfectly like OEM all the way to the edges and matches the curve. You can seen a picture here.
http://f30.bimmerpost.com/forums/sho...dippydo&page=3 |
05-06-2015, 01:11 PM | #12 |
Rep 1,035
well.. i don't know much $$$ is a consideration, but being that you drive so hard/spirited, maybe you should go for as inexpensive as a lip as you can find right now ($99), and let go of the perfect fitment - if the chances are high that you might really tear it up.
Just so you can see how it might get affected. If you end up destroying it, then it won't be as bad as if you paid 2x-3x as much, and at least you'll know. |
05-06-2015, 01:35 PM | #13 | |
Rep 100
05-06-2015, 01:43 PM | #14 | |
Rep 1,035
Look at the thread $100 ebay front lip Just as long as you know that pretty much all these lips don't have perfect fitment. The biggest thing we've noticed is the gaps at the end of the lip, on the cover that goes over the apron. There are pics in that thread. Most people here on these boards are OCD (its a requirement for membership), so they notice. Most everyone else will not notice. These lips really are good for testing/experimenting on, since its so inexpensive, especially for what you are going to do.. hahah (just kidding) Last edited by squidlyboy; 05-06-2015 at 01:51 PM.. |
05-06-2015, 02:01 PM | #15 | |
Rep 100
It seems that the eBay link has been removed, and the next cheapest I can find is the Selma lip for $160.
05-06-2015, 10:05 PM | #17 |
Rep 1,035
Odd... all the $99 lips have all but disappeared, and the best fitted lip closest to OEM is now also the least expensive.
OP, this is a good opportunity for you i think. When i purchased it, it was $175 and made an offer of $150 and he took it. I would offer $100-$125 and see if they bite. You may score a great quality lip and an even better deal Heck, at that price, i may get a spare today for a couple of years down the road when I anticipate having to do my next replacement ... |
05-06-2015, 11:26 PM | #19 |
Rep 1,035
Yeah, they did have fitment problems, but now, apparently they are not available any longer, or jacked their prices.. because i don't see $99 lips anymore. And now the low-ball price tag ($159.99) belongs to the Taiwan-made Selma lip, which was the best (fitment) of the bunch. Go figure.
Yes, the Selma lip comes with all the mounting hardware. Install is a piece of cake once you get the car up. EDIT: check that... if you are putting on a lip for the first time, you will also need expanding rivets to attach the lip to the bumper. I already had a previous lip that i was REPLACING, so i just re-used those. But they are cheap, and you can buy a dozen of these for about $10 from any BMW dealership or online. Last edited by squidlyboy; 05-07-2015 at 07:43 PM.. |
05-07-2015, 04:12 PM | #20 |
Rep 1,738
Did you use ramps? And which ones? I'll rarely use them so don't want to blow a lot of cash on them. But I don't want get it up in them and find out I can't back off without tearing out the lip 😱
05-07-2015, 04:56 PM | #21 |
Rep 1,035
I couldn't use any of the commercially available ramps because my car is lowered and the ramp angles on all of them were too steep. Plus, making a simple one out of 2x12's was much cheaper. Cost me like $20 for one long piece of lumber that i cut into smaller pieces.
A 2x12 works well as the 12 is wide enough plank for the entire wheel to fit comfortably on it, and the 2 (actually 1.5 inches high) is low enough for my lip to clear (barely), which is 2.5 inches off the ground. So when the wheel hits each 1.5 inch step, there needs to be enough clearance between the tire and front of the lip (distance from tire to lip is around 14"-17") to clear it. To be conservative, each step should be 18" apart to insure the front of the lip will clear the next step. HOWEVER... I got cheap and I made each step ~14" apart so that i could make the ramp out of two 2x12x12 (had only tiny slivers of wood left over after cutting out the steps). So... top-step: 14" 2nd step : 28" 3rd step : 42" bottom step : 56" Had I gone with each step being 18" apart, the base step would have been 72" long (6 feet!!) and i would have had to gone to using two pieces of 2x12x16, which is a little more. Plus it would have been a lot heavier to lug around. Anyways, my procedure is this: 1) Drive up the 4-step ramp till car is high enough to slip the floor jack under the front of the car 2) Center the floor jack so that the contact spot is just before the oil drain pan flap. 3) The 4-step ramp gives me just enough clearance so that i can jack the car up high enough so that i can slip jack stands under both sides of the front of the car, and rest the front of the car on the two jack stands. $20 of lumber, a saw, a hammer, and some nails Last edited by squidlyboy; 05-26-2015 at 08:51 PM.. |
ahoroba1.50 |
05-07-2015, 06:19 PM | #22 |
Rep 1,738
Ok I get the ramp...that'll be easy to make. Since I'd only be doing the lip at this time that's all I'd need, right? Only need to put it on stands if the wheels are coming off (which I Prob will do at some point to put on spacers).
