BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > N55 Turbo Engine / Drivetrain / Exhaust Modifications > ♛ OFFICIAL ♛ HEX Tuning BMW (F3x) ECU Software (Re-Release)
proTUNING Freaks
Closed Thread
      02-18-2017, 05:14 PM   #23
mr_kay
mr_kay's Avatar
126
Drives: F30 335i
So is this comparable to PTF BootMod3? Also, please PM me pricing.
      02-18-2017, 05:39 PM   #24
VF-Engineering
VF-Engineering's Avatar
1009
Drives: F82 M4
It's comparable in the fact that BM3 and HEX Tuning are both Flash Tuning options, but our primary focus is in fully engineered and validated, turn key software solutions, based on popular hardware combinations and common fueling options.
HEX Tuning customers are typically looking for impressive power gains on unleaded pump fuel, with OEM like drivability and reliability; without the need for customization/datalogging/code clearing/etc...
We do offer multiple Stage Level software options for each application with easy/user friendly MAP switching via OBDII. You can update/upgrade/and flash between stock and performance mode at will. Set it and forget it. Drive and enjoy.
Zel33582.00
      02-20-2017, 07:11 AM   #25
BryanF30
Drives: black 2013 335i xdrive m-sport
What hardware is required fore stage 2? Also, how does the stock clutch hold up under these power levels? Thanks
      02-20-2017, 03:11 PM   #26
VF-Engineering
1009
Drives: F82 M4
Originally Posted by wakeofdeath
Do you also have the Charts in SAE or STD ?
+1 if you can post those CF too.
Should reference at least those examples in SAE/STD/Uncorrected and why they differ and why you use Uncorrected.
Most fanboys here only know about Tuning from what n54tech/jb4 says, so they go with the STD charts.
I'll go ahead and post the SAE and STD Correction below (for Stage ONE) for
the sake of conversation.
As you can see from the results above, correction factor may change the "peak"
values, but the delta remains nearly the same for all three runs.
UNCORRECTED: 24HP / 67TQ
SAE Correction: 24HP / 65TQ
STD Correction: 24HP / 67TQ
What we are trying to do as a company is get people to start focusing on the
"delta" between before & after runs, rather than "peak numbers" from a single
run example; as well as "Max Gains" and "Area Under the Curve" instead
of "peak gains". Dyno plots are meant to tell a story more so than just make
an exclamatory statement.
Additionally, correction factor is often times used incorrectly or out of context
as it's primarily meant to create uniformity when the same car is measured for
power on different days with different conditions. Modern ECU's adapt for
changes in ambient temperature and barometric pressure, so where correction
factor will create uniformity for the same car, on the same dyno, on two very
different days - it's misleading to assume that dyno results with correction factor
applied will equalize two different cars, on different dynos, on different days,
under different conditions.
As a general rule of thumb, dyno results on a day which is warmer than SAE (77°F)
or STD (60°F) will result in correction factor increasing the values for HP and TQ,
while dynoing on a day that is cooler than the established conditions for SAE and
STD will result in correction factor that decrease the values for HP and TQ.
On that same note, STD correction is uniformly higher than SAE by an average
of 4%, which is why it remains a favorite by tuners and consumers alike.
The purpose in our uniformity in always posting Uncorrected numbers is to
eliminate the debate about when/where/why/how correction factors are used to
ones advantage.
Have tested any on 93 ?
As a California company we test and tune on 91 Octane for our "pump fuel"
Stage Levels, and we use Sunoco SS100 for our "race fuel" Stage Levels. While
it's widely known that CA 91 Octane is a lower quality fuel grade than in most
other parts of the country, we calibrate in a way that still allows for the ECU to
take advantage of the same adaptations strategies as OEM.
321/374 is stg1 & 356/413 is stg2 ?
The 321HP/374TQ dyno plot does represent our Stage ONE,
and the 356HP/413TQ does represent our Stage TWO.
More importantly it demonstrates the 24HP / 67TQ gains for Stage ONE, and
60HP / 105TQ or Stage TWO - at the wheels, which are well in line with our
advertised claims for each power level.
Do they have FMIC or stock IC ? if not do you have a car with Stg2 + fmic ?
Both advertised power levels are with stock intercooler.
We do offer a "high output" Stage ONE and Stage TWO file for cars with
upgraded FMIC and/or use with 100 Octane or higher "race fuel".
"High Output" dyno plots will be released soon!
SeanWRT3179.00
      02-20-2017, 03:15 PM   #27
VF-Engineering
1009
Drives: F82 M4
Stage TWO is advertised as "Off Road / Non-Highway" Use Only, and is
calibrated specifically for vehicles with aftermarket downpipes & exhaust.
In all of our testing the stock clutch has held up well to our increased
torque levels.
      02-20-2017, 03:23 PM   #28
BryanF30
torque levels.
Thanks. Will there be a cel with this tune for the DP?
      02-20-2017, 06:51 PM   #29
VF-Engineering
1009
Drives: F82 M4
For vehicles used off-road, the Stage TWO will address the CEL.
      02-20-2017, 07:26 PM   #30
sicmadek
Drives: 2013 335i sportline
ones advantage.
how much for each additional map? bm3 is already cheaper initially and ptf charges $50 per additional map.
      02-20-2017, 07:34 PM   #31
VF-Engineering
1009
Drives: F82 M4
Additional MAPs are $50-100 dollars, and will vary based on whether it's an upgrade from
a lower Stage Level, or an accessory file for your current Stage Level.
IE:
Upgrading from Stage ONE to Stage TWO will be the difference in retail price ($100).
Adding a "high output" or "race fuel" file for your current Stage Level will be $50.
      02-20-2017, 07:42 PM   #32
sicmadek
IE:
anyway to see a dyno plot of your stage 2 vs jb4 map 2 on the same vehicle with same fuel? i would think most people on here have a jb4. i know the drivability will be different but i would like to see the power curve of both at the same boost level.
      02-20-2017, 08:15 PM   #33
VF-Engineering
1009
Drives: F82 M4
We typically don't post comparison plots against other manufactures as we just
don't think that's good business.
It also tends to be more credible when posted by a consumer (via independent
testing
) rather than by a manufacturer who may or may not have skin in the game.
That being said, we feel there's more to the Features & Benefits / Pros vs. Cons
between piggy-back devices and a proper flash tune than just power delivery.
You mentioned drivability yourself already, and there's many more that are even
more subjective than that.
      02-21-2017, 06:19 PM   #34
VF-Engineering
1009
Drives: F82 M4
UPDATE
Additional Dyno Plots added to "POST #2". (click link to jump)
We just had the chance to add two new customer plots, one for
Stage ONE and one for Stage TWO. The new dyno plots are shown
with Peak Gains as well as MAX Gains for each specific vehicle.
A handful of you have been asking for "Mustang Numbers" so we also
went ahead and added a Stage ONE dyno plot from a testing session
on the Mustang AWD-500-SE.
      02-21-2017, 07:03 PM   #35
sicmadek
UPDATE
Impressive for 91 oct and downpipe
      02-21-2017, 09:24 PM   #36
Jadar
Dejan
Jadar's Avatar
Serbia
1753
Drives: 2018 Audi S3
Have you guys worked with or tuned a PS1 car? Any results?
FBO-PS1 and stuff
      02-21-2017, 10:10 PM   #37
VF-Engineering
1009
Drives: F82 M4
No aftermket turbo testing yet.
As soon as our development schedule clears up we'll be looking for
a couple local test cars and will devote a fair amount of time to it.
Jadar1752.50
      02-23-2017, 12:26 PM   #38
VF-Engineering
1009
Drives: F82 M4
Got BURBLE?
      02-23-2017, 12:29 PM   #39
sicmadek
Got BURBLE?
I want burble in all modes!!
yoandry692.50
      02-23-2017, 01:31 PM   #40
VF-Engineering
1009
Drives: F82 M4
Our customers love it, and it seems to be quite addictive as well!
It would actually be much easier to keep the same throttle overrun
sequence across all three drive modes, but we intentionally (and
by most customers preference
) allow for it to be turned off by
clicking into ECO/Efficient Mode so that there is an easy "on the fly"
method for quieting the car when necessary.
I'm sure we can all imagine the scenarios for when this feature will
be a benefit, and because it doesn't have any effect on power, we
feel that having 3 options at your fingertips is better than none.
      02-23-2017, 02:45 PM   #41
GTBrandon
GTBrandon's Avatar
Drives: 13' M3 Competition
If I'm not mistaken, eco-pro mode does affect throttle response as well as overall power delivery. Are you saying that with your tune, all three modes become the same other than an exhaust note??
Current: 12' E70 X5D | 04' Yamaha Warrior
Past: 13' Audi S6 | 13' E70 X5M | 13' E92 M3 Comp | 14' BMW 335xi GT | 95' E36 M3 | 84' BMW 733i | 06' Porsche Boxster S | 15' Jeep Grand Cherokee | 06' Acura TL |
85' Honda Shadow VT700 | 05’ Yamaha R6 | 12’ Triumph Tiger
      02-23-2017, 02:55 PM   #42
VF-Engineering
1009
Drives: F82 M4
I was stating that the "throttle overrun" feature doesn't have any effect on power,...
essentially meaning that making it "burble" in all three drive modes, versus
Aggressive Burble (Sport Plus) / Mild Burble (Sport) / No Burble (ECO), will make no
difference in the HEX Tuned power delivery.
A HEX Tuned vehicle in ECO Mode, will still function as an "ECO Mode" as
Relative to Sport and Sport Plus. This allows for a drive mode that is still more
exciting to drive, while also being quiet for those times when you need to fly under
the radar, so to speak.
GTBrandon260.00
      02-23-2017, 04:00 PM   #43
GTBrandon
GTBrandon's Avatar
Thank you for the clarification!
      03-04-2017, 02:45 PM   #44
wakeofdeath
Albania
71
Drives: X6M
So the tuning is done on Mustang "load-bearing" first and then taken to Dynojet (next to it) for Comparison of runs and (Standard) Dyno numbers?
Closed Thread
