06-23-2014, 01:44 PM | #199 | |
Rep 266
06-23-2014, 02:43 PM | #200 | |
Rep 337
This is just me, but I'll take it out (once warm) with about 10-15 miles on it and do a 3rd or 4th gear pull (whatever I have room for) and let the gear slow the car down, no braking. This is an old sportbike thing I subscribe too, basically gets the rings to wear against the cylinder walls for a nice snug fit. I think this is touched on in some break in threads as well. But yeah, I plan to baby mine for the most part for the first 1200mi. Saw a guy last week at the dealership cold start a 335i and immediately start revving it to redline. No amount of break-in period will help that car... |
06-23-2014, 03:05 PM | #201 | |
Rep 266
06-23-2014, 06:35 PM | #202 |
Rep 1,986
Drives: 2014 335i xdrive, 2014 X5 3.5d
2000km, RPM under 4500. Having said that I revved it too high a few times before that. It's just too much fun to resist
06-23-2014, 06:41 PM | #203 | |
Rep 374
Too bad BMW doesn't repeat the feature they had on the e46 M3. When cold, the tach showed a ring of red diode lights around the circumference of the tach. The driver was supposed to keep the shift points at or below the red lights. As the engine warmed up, the red lights gradually went out one by one 'til you could flog it with abandon. Made the warm-up process very easy.
'14 328d, '13 M3 ZCP, '12 535i, '11 335d, '09 Z4 DINAN Stage II, '05 330i ZHP, '05 M3 ZCP, '02 M3, '91 328i, '90 535i, '88 528e, '88 M5, '87 M6, '95 Z3, 95 M3, '93 M5, '87 325e, '89 535i, '86 635i, '73 Bavaria. |
06-23-2014, 08:59 PM | #204 |
Rep 75
Baby your car if you want to, I'm not here to tell you otherwise. But consider that if spirited driving really did any damage, BMW would have electronically limited the performance during the break-in period.
06-23-2014, 09:56 PM | #205 |
Rep 374
You don't have to baby the car during the break-in period. I've never seen anything in writing by BMW that says you need to baby the car during the first 1200 mi. All they have ever said is to avoid WOT and keep the revs under 4500 (3500 for diesels) for the first 1200 mi. There's plenty of performance (spirited driving?) available under those limits. Of course if the mantle of Nuvolari, Senna, whomever, descends upon you whenever you fire up your new bimmer, you can cane the beejesus out of it from the get go. In fact many people swear that is the proper way to break in a new BMW. BMW gives you your choice; no electronic nannies needed.
06-23-2014, 10:11 PM | #206 | |
Rep 1,627
06-24-2014, 10:45 AM | #207 |
Rep 266
what is WOT???
06-24-2014, 10:47 AM | #208 |
Commander-In-Chief
2119
Rep 8,922
Drives: 2023 M2 Coupe, 2020 GLE 450
Greg Lake Oswego, Oregon, USA 2023 M2 Coupe - Brooklyn Grey/Cognac/CF, 6MT; 2020 MB GLE 450 |
06-24-2014, 10:48 AM | #209 |
Commander-In-Chief
2119
Rep 8,922
Break in
Best is varying speeds and rpm, not more or less constant. Also, need to work transmission and brakes more than on the freeway.
06-24-2014, 01:00 PM | #210 |
Rep 374
An added tidbit re the difference between the 1200 break-in on M cars (oil change) and the non M cars that get no 1200 mile oil change:
I did a used oil analysis (UOA) on the 1200 mi drain from my e92 M3 and was quite surprised at what I found. The oil was a thin 5w30 weight (the service fill on the non-turbo M cars as most know is a 10w60). It had a very modest detergent additive pkg and nothing too robust for the antiwear adds either. In other words it appeared to be an old school break-in oil designed to seat (wear-in) the cylinder rings as quickly as possible before the hot shoes (as in some on this forum) started to drive the snot out of the car. And like many break-in oils it was most likely a conventional mineral (non-synthetic) oil. These oils are actually designed to allow controlled but more than normal wear during a brief period. And with the weak detergent pack, they are definitely not suitable for an extended drain interval (10-15k mi), thus the early drain. The wear metals on my UOA incidentally were very low. So much for the myth that the 1200 mi drain is done to "wash out" harmful levels of wear metals. So this kind of begs the question: Why does BMW do this for M cars and not other BMW's? My uneducated guess is the difference in metallurgy, engine design and operating parameters (e.g. the e92 M3 had silicon-impregnated aluminum cylinder barrels - - very, very hard). In other words, BMW feels the non M BMW's don't need it. One more tidbit to throw into the Hard Break-in vs Soft Break-in debate: BMW has an interesting site that describes their engine factory in Austria that makes the six cyl N55 gas engines and all their diesel engines. It describes how as a quality control measure all the engines are run briefly on an engine dyno powered by electricity (no mass emissions to choke the towns folks), but some are randomly selected and run under their own power at WOT for an extended period - - called the "dynamic engine audit"! Doesn't say what they do with these engines afterwards. http://www.bmw-steyr.com/index.html
06-26-2014, 06:44 PM | #211 |
Rep 82
Another thing to remember is that the engine is built without cylinder liners. It has twin-wire arc-spray coating (instead of liners) in cylinder bores. Thus tehre is less material between the piston rings and the aluminum block.
