08-29-2017, 09:33 AM | #1 |
Driver
465
Rep 1,002
Vibration/rattle in drivers door
340i just hit 4000 miles and developed a rattle/vibration in the drivers door, a few inches below the lock button. Any ideas? Maybe the lock mechanism? Back to the dealers or an easy door card removal and fix?
08-29-2017, 11:01 AM | #2 |
Rep 3,540
Could be the light mounted in that location that illuminates under the accented door card trim. Mine rattled a bit and I put some felt tape under it to fix it.
It could also be the door pin where it plugs into the latch mechanism. That piece can jiggle up and down. Felt tape on the door pin hole (where it pops out of the door card) should provide enough friction to prevent that. |
08-29-2017, 05:57 PM | #3 | |
Driver
465
Rep 1,002
08-30-2017, 06:34 PM | #5 |
Driver
465
Rep 1,002
Thanks but it's definitely not that, I get squeaky seal syndrome in hot weather, very annoying but we don't get enough hot weather in the UK for it to become a real problem! Its definitely a vibrating rattle coming from the inside of the door trim card, which stops if I firmly press the card trim!
09-06-2017, 02:23 AM | #6 |
Rep 240
Any luck fixing the rattle? I just took ownership of a new 2017 340ix M Sport and had the rattle at the same area going over bumps and while accelerating like a resonance in my front passenger door. I too read about the LED strip and I pressed firmly along the length of it and it seemed to have fixed it. I also wondered if it were the door lock pin. And like you, it doesn't seem to be the case. The rattle sounds like a loose hard plastic piece is making contact with something.
09-06-2017, 03:45 AM | #7 | |
Driver
465
Rep 1,002
09-06-2017, 11:25 AM | #8 | |
Rep 240
