08-30-2017, 08:48 AM | #1 |
Rep 505
Leaving for 3 weeks, trickle charge battery?
Leaving for vacation to Europe for 3 weeks, car will be sitting in my garage, should I leave it on a trickle charge or will it be fine?
08-30-2017, 09:01 AM | #4 |
Rep 906
only if you are in Antarctica
2016 X3 35i M-Sport
2019 440i Coupe M-Sport - Retired 2018 330i Sedan M-Sport - Retired 2015 428i Gran Coupe M-Sport - Retired |
08-30-2017, 09:10 AM | #5 |
Rep 1,502
Not strictly necessary but do it if it makes you feel better (it won't hurt).
Edit: Removed my suggestion about battery reconditioning. That may not be recommended for AGM batteries. Last edited by chiefneil; 08-30-2017 at 12:17 PM.. |
08-30-2017, 09:15 AM | #6 |
Big Beaver Smile
2101
Rep 3,791
Your car will be fine. My cars routinely sit longer than that without any problems (till I just opened my big mouth).
______________________________________________
Current- '21 430 , '19 911, 07 M6 ,'17 Jeep Wrangler, "23 Bronco OBXluxsquatch |
08-30-2017, 11:52 AM | #8 |
Rep 2,118
08-30-2017, 01:56 PM | #10 |
Rep 291
08-31-2017, 06:57 AM | #11 |
Rep 2,118
I agree with the short trips but in normal driving there is zero reason to have to charge the battery. It's 2017 for goodness sake and modern batteries have plenty of capacity and are fully charged in day to day driving. I owned (leased) 3 different 3 series over a 9 year period and about 140,000 miles and never had a battery issue.
08-31-2017, 10:50 AM | #12 |
BMW CCA #257
75
Rep 190
You will be fine but the investment in a Battery Tender Jr. for about $25 is well worth the investment in battery life. I use mine whenever I go on an extended trip and the battery is always fully charge but NEVER overcharged upon my return.
2014 F31 328 xDrive Touring
2020 G20 330 xDrive Sedan 2023 G01 X3 xDrive BMW CCA # 257 |
08-31-2017, 11:15 AM | #13 | |
Rep 15,858
If the driving profile doesn't support much over-run 'regeneration' we can find the battery never gets any real 'boost'. Due to this thread, I've just run a 'smart charge' on my battery, this afternoon, to see its condition. This is after some weeks of normal use in favourable driving, including 90 mile drives. Battery was lower than 80%, at the start, typical of what I find any time I've run a charge. I've kept my battery topped up over winter months, this is the first check since early spring. BTW, battery is now into its seventh year. Says something for giving it the occasional boost through the winter months. Last edited by HighlandPete; 08-31-2017 at 11:21 AM.. |
Katin134.00 |
08-31-2017, 11:22 AM | #14 |
Rep 1,055
Drives: 2016 340i M Sport 6MT+RWD
I went away for almost 3 weeks recently - zero issues with battery drain when I got back after sitting in my garage.
You should be fine but I agree a battery tender is always nice to have - just be careful not to get a cheap one as the components that prevent overcharge may eventually fail due to cheap components. Car batteries don't have over charge protection like your phone does - it relies on the charging source to do that.
2016 Estoril Blue II 340i M Sport | ///MPPSK | 6MT | RWD | Fully Loaded
BM3 Stage 2+ 93 | B58TU HPFP | VRSF v2 Catted Downpipe | 550i Clutch |
09-02-2017, 08:53 PM | #15 | |
Rep 291
09-02-2017, 09:01 PM | #16 |
2JZ-GTE
3045
Rep 3,996
Just put it on the charger/trickle when you come back
09-02-2017, 09:24 PM | #17 |
Rep 4,031
I would charge it up before you go if you don't want to leave it on and then again as soon as you get back. I did that with my E93 ad that isn't my daily.
Also if you have an alarm that will drain the battery if you are leaving it locked and activated.... Enjoy Europe!
2012 BMW 328i E93 | Deep Sea Blue Metallic - 2015 BMW 328i F31 MSport Sports Wagon | Alpine White - BMW CCA DelVal
09-03-2017, 11:22 AM | #18 |
Rep 906
I was away for over a month and just left my car locked in the garage. It started right up when I got back.
Doesnt hurt to charge up the battery before you go. I think leaving it locked helps more because it goes into some sort of power saving sleep mode.
2017 328d xDrive Sports Wagon: Estoril Blue, Black Sensatec, M-Sport Pkg
2020 i3 Rex: Capparis White, Giga World |
