05-30-2013, 05:02 PM | #3 |
Rep 1,997
I don't see why they wouldn't, but I'd have to research to be certain because of the offset. They're not wide rims so I suspect they would unless you went with a super tall tire.
You're able to fit 19x9 on the front without issue with a slightly less aggressive ET than that so I suspect it would work. (I'm being a slacker and not looking it up, but I'm sure someone else will chime in with experience and say for certain. |
05-30-2013, 05:06 PM | #4 |
Rep 1,201
The reason I ask is because I already have a set of 4, but the rears don't seem like they would fit. 9.5 inch ET 22, but I could try and buy a pair of fronts and then use 4 fronts all around.
Stock is 19x8 ET 34 front and 19x8.5 ET 47? 220M is 19x8.5 ET 29 (all around) Does that help? |
05-30-2013, 07:20 PM | #5 |
Rep 886
They will 100% work, front and rear. 245's all around would be nice
2015 M3 - AW 6Spd w/ CCB
MCS 2WR Dampers, Spec Twin Disk Clutch, MaxPSI CH, F80Paul Ethanol Tune, 3.5in DPs |
05-31-2013, 09:52 AM | #7 |
Rep 886
05-31-2013, 01:37 PM | #9 |
Mark 42
1051
Rep 716
225/40/19 is the stock spec tire size for 19" wheels on the F30. Even though the M3 wheels are .5" wider than the stock F30 19's, the tire size will work. I was considering doing the same thing and running four 19X8.5 front M3 wheels and in the rear putting a 255/35/19 tire, which is again the stock tire size for F30's M-Sport rear wheels
05-31-2013, 01:44 PM | #10 |
101
Rep 1,237
It should work. This guy did 4 front Competition M3 wheels on his F30.
http://www.f30post.com/forums/showthread.php?t=832809 |
05-31-2013, 02:38 PM | #11 | |
Rep 1,201
06-06-2013, 03:49 PM | #12 |
Rep 1,201
Just attempted a test fit, and it baarely fits. The rim is about flush, but the tire might stick out by a couple mm. So just to let everyone know 8.5ET29 is probably the max you can fit, in the back it worked fine though. Not sure how that guy fit those 9 inch ZCP rims, haha
