BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > Cosmetic and Lighting Modifications (exterior & interior) > F32 Rear Diffuser HELP!
      05-17-2018, 10:50 AM   #1
dxviiss
Drives: BMW 420d M Sport
Hi everyone, new here.
Looking for a matte black rear diffuser to fit to my 2014 420d F32, single exhaust tip on the left.
Any advice on the best replicas that ship to the UK?
Initially liked the idea of carbon fibre but understand it's a bigger job due to needing to remove bumper etc and not really interested in taking that on.
Thanks!
      05-17-2018, 05:30 PM   #2
ooshnoo
ooshnoo's Avatar
Drives: 2014 428i and 2018 X5
2018 BMW X5  [0.00]
2014 BMW 428i  [10.00]
I bought mine from Ikon Motorsports, and I believe they ship worldwide, but you'll want to contact them to be sure. It's a very good product with perfect fit. No modification needed. It was made in Taiwan by "GoodGo" so if you can find UK dealer that sells that brand, you should be set.
https://www.ikonmotorsports.com/2013...in-outlet.html
___________________
2014 F32 428i M-Sport
2018 F15 M-Sport
      05-17-2018, 07:01 PM   #3
yoon_209
Masterchief
yoon_209's Avatar
Drives: 20' BMW M340i
or you can bypass all the US middlemen and buy direct from the supplier on aliexpress
I bought all my CF parts thru aliexpress thru the taiwanese vendors
all parts came in quick and was signicantly cheaper than ebay vendors.
all parts fit 100% and had no issues whatsoever
i installed my CF diffuser for my f30 no removal of bumper and perfect fitment.
AWE Non-Res Touring | TE37 SL PW | Ohlins RT
      05-18-2018, 09:32 AM   #4
dxviiss
Thanks for the replies!
I have access to a P.O. box so don’t mind shipping from US.
Will look into those that you both suggested
      05-18-2018, 09:35 AM   #5
dxviiss
I have read some people have managed it but on the F32 the diffuser is bigger than that of the F30 and because the carbon fibre is more rigid than plastic it’s hard to get to pop into place without removing the bumper from most of the people I’ve spoken to unfortunately
      05-18-2018, 10:23 AM   #6
yoon_209
Masterchief
yoon_209's Avatar
ya i cant speak for f32 but from what you said, sounds like you may need to pop off the bumper
      08-01-2023, 04:07 PM   #7
Shah_F30
Drives: 13 335i M-Sport, 6-MT
So can F32 diffuser fits F30?
      08-02-2023, 08:57 AM   #8
Oksamit78
Oksamit78's Avatar
Drives: E39, F30 & F34
Nop. Two different animals.
My F34 CF diffusor (very short supply, comes only in CF) is larger than F32. The problem is that the lock tabs on aftermarket CF diffusors are typically too thin when compared to OEM design. I had to re-build those using epoxy putty (there was another person out of UK that had to do the same thing on his F34, if I remember correctly), otherwise the diffusor was popping off. No bumper cover dismantling was required. Taking the bumper cover off for installation will not prevent the diffusor from popping off later if the tabs are not holding on correctly.
2003 E39 530i 5-Speed w/ M Spec, Saphire/Black, M54B30, Active Autowerke Performance Tune
2010 Lancer GTS 5-Speed, Black Pearl/Black, 4B12
2015 F30 335i XDrive w/ M Sport Pack, Alpine White/Black, N55B30M0
2017 F34 340i XDrive w/ M Sport Pack, Azure II /Black, B58B30M0, Dinan Stage 1
f32, m performance, mods, rear diffuser
