11-06-2019, 04:20 PM | #1 |
Rep 251
zf8 gripe, surely I can turn this off??
Hi,
I have recently bought a 335d xdrive auto. So far I am very pleased. My only gripe is that I find it extremely frustrating that I have to apply the brake to put the transmission into drive from neutral. This isn't an issue if I am completely stationary. But if, for example, I am approaching a red light and I select neutral from drive and almost coast to a stop but then the light turns green I should be able to press unlock on the selector and engage drive to pull away. It seems silly that I have to press unlock and have foot on the brake. Surely just pressing unlock should be enough. Is there anyway to switch the footbrake unlock off? |
11-06-2019, 04:46 PM | #3 |
Rep 203
Sounds like your first auto
Use the box properly and you wont need to. Just leave it in drive Its well worth reading up on how to use these things before presuming that they are badly designed Last edited by Busted; 11-06-2019 at 05:30 PM.. |
Iyrix100.00 |
11-06-2019, 05:01 PM | #4 |
Rep 3,216
Why would you select neutral ? The car puts itself into neutral as you coast up to the lights.
As to the interlock with the brakes, that is a safety feature designed to make it impossible (or close to impossible) to put the car into gear unless sitting in the drivers seat. |
11-06-2019, 05:16 PM | #5 |
Rep 5,997
Looks like you posted the same subject on another forum.
335d xdrive into drive without applying brake?? https://f30.bimmerpost.com/forums/sh....php?t=1667124 |
11-06-2019, 05:20 PM | #6 | |
Rep 5,997
11-06-2019, 05:48 PM | #10 |
Rep 251
Surely neutral should be used otherwise the car would never be able to be stationary with out having the brakes applied.
11-06-2019, 06:12 PM | #11 | |
Rep 203
Leave it in drive. Its a clever little gearbox, let it do the work for you |
11-06-2019, 06:14 PM | #12 | ||
Rep 5,997
11-06-2019, 06:20 PM | #13 | |
Rep 15,858
Using the brakes is normal in auto use. Some models have brake auto-hold, does it all automatically. * Only time extra care is needed for sitting on the brakes when stationary is after aggressive braking when discs will be really hot. |
11-07-2019, 12:38 AM | #14 |
Rep 624
I'm pretty sure the manual states neutral shouldn't be selected while moving. I'm surprised the ECU even allows this.
Yes - you have to keep your foot on the brake at lights etc but that's normal with an Auto. If you want to stop the car creeping forward without the foot brake for some reason select Park. Ordinarily; just leave it in drive and let the greabox manage everything. |
11-07-2019, 02:59 AM | #15 |
Rep 424
I've done it on occasion when playing about. If you're going at crawling speed, it will sometimes go back into drive without the brake. I've no idea what criteria it uses to decide whether you're allowed though
On a separate note, there's no way in hell the little f**ker will let you reverse with the drivers door open Before anyone starts, I realise we have reversing sensors, but I don't trust them with low walls etc |
11-07-2019, 03:14 AM | #16 |
Barge driver
8656
Rep 12,425
When you're stationary you should have the brakes applied.....that's the point.
730d/Z4C
11-07-2019, 03:22 AM | #17 |
Rep 3,967
11-07-2019, 04:20 AM | #18 |
Rep 3,066
Down side with all these people in autos is not the fact that they have to hold the car on the brake when stationary but the fact that they have the brake lights on continuously when stationary, which in the drizzle and dark car be quite dazzling to the car behind. In fog it's even worse with the extra couple of lights on, but I'm not going there !
Why not put it into park when stationary or just apply the handbrake with your foot off the brake to give the folk behind an eyeball rest. So I don't get shot down in flames I'm not talking of when stopping and junctions or roundabouts but at times when traffic lights or stationary motorway stuff means you are stationary for some time. |
11-07-2019, 04:45 AM | #19 | |
Rep 15,858
Car manufacturer's are not helping the lighting situation. |
11-07-2019, 05:10 AM | #20 |
Rep 7,703
I occasionally put mine into Park if stationary to be polite. But most of the time I forget because personally I've never felt dazzled or annoyed by someone's brake lights in front of me.
As most people sit there with their foot on the brake, I'm glad it doesn't bother me, enough things to get annoyed about without letting that one wind me up. |
SportySpice204.00 |
11-07-2019, 05:44 AM | #21 | |
Rep 665
11-07-2019, 06:10 AM | #22 |
Rep 38
Holding the car on the brakes took some getting used to after years driving manuals. It still doesn't feel quite right to me.
I do put it into park or neutral if the car has been driven hard - I seem to recall reading somewhere that bits of the pad can fuse to the disc if the brakes are hot. I'm not sure if there's any truth to that? |
RENT-A-GOAT462.50 |
