11-07-2019, 06:13 AM | #23 | |
Rep 5,997
11-07-2019, 06:55 AM | #24 |
Rep 8,498
I put the AT in neutral almost every time when stationary. The ZF8 in my 2012 car develops significant torque when stationary and is held on the brakes - you can hear the engine 'unloading' when shifting from D to N.
No point just holding the engine/transmission on the footbrake when the car perpetually wants to creep - no good for fuel economy. As has been said, requiring the footbrake to be applied when shifting into D is a safety feature and is absolutely required.
11-07-2019, 07:31 AM | #25 | |
Rep 15,858
There are several parameters to be met, for NIC to function, (includes rpm and accelerator pedal values). I wonder if something is changed in your setup. |
11-07-2019, 08:35 AM | #26 |
Rep 1,049
Drives: F31 320D Xdrive Msport+
I've only ever put mine in N when stopping at lights the few odd times in Wales where I had known the brakes would be hot so didn't want to put pad to disc to cause transfer so just popped into N put the hand brake on then went on my way going from N to D without any issue other then a tiny bit of faff to select it in and out and use the hand brake.
[url=https://www.deutschespeed.com/threads/the-bimmerpost-refugee-thread.561/]Click here for the Bimmerpost UK Refugees - Censorship Sucks![/url]
11-07-2019, 08:55 AM | #27 | |
Rep 92
11-07-2019, 09:10 AM | #28 |
Rep 3,066
11-07-2019, 09:26 AM | #29 | |
Rep 8,083
Ian
Current: 2021 G21 330i M-Sport Previous: 2018 A6 Avant S-Line MMI+, 2014 F31 320d M-Sport, 2013 F10 520d M-Sport, 2011 F10 530d M-Sport, 2008 320i M-Sport Coupe, 2002 325i, 2001 318i valvetronic, 1998 318i, 1996 525i, 1990 Porsche 944S2 |
11-07-2019, 10:14 AM | #30 | ||
Rep 8,498
Difficult to be precise about the reduction in TC load but it definitely has the feeling that it's still in D rather than N (fully disengaged), hence you can feel the difference when shifting from D to N. Of course an AT in N is different to a manual transmission in N, and the AT in my car (2012) definitely has permanent drive in D rather than emulating N/disengaged when stationary.
11-07-2019, 02:47 PM | #31 | |
Rep 251
I have changed my driving style after reading some of the comments on here regarding not slow coasting and leaving it in drive. However I still feel it is right to pop it into neutral when stationary otherwise the car just wants to pull off. |
11-07-2019, 03:16 PM | #32 |
Rep 643
Honestly I've never even thought to put in neutral..
Do use park now and again if stopped at lights.. holds off having to keep brake pedal down, plus if start/stopped (not a gripe of mine) car starts again when drive selected.. |
11-07-2019, 03:55 PM | #34 | |
Rep 25,114
My car made front page of Bimmerpost
11-07-2019, 04:31 PM | #35 |
Rep 810
I occasionally do as the OP does, slipping in and out of N would be useful but it's prevented the same way in most autos. Like rent a goat says, you don't want the brakes clamping a stopped disc when hot.
It is a bit annoying, but doubt you could code it out |
11-07-2019, 06:42 PM | #36 |
Rep 251
Code it out.... Finally a possible answer to my original post
11-07-2019, 08:06 PM | #38 |
Rep 5,997
On the DCT there is no P, like on the M2C. You just turn it off in D and it shifts to P by itself. The regular 8AT does this too if you shut off the motor in D. Like the other poster, you can use N for car washes but it only stays in N for 15-20 minutes before going to P so it could be a problem if there's gridlock at the car wash or it is just a really slow car wash. If you don't want it to go to P for towing then the tow truck driver has to use a tool to shift it into N from under the car which is dangerous AF but that's how they made it cuz they're more concerned with the car rolling when you forget to put it into P when parking.
11-07-2019, 08:14 PM | #39 |
Rep 251
11-08-2019, 01:16 AM | #40 |
Rep 1,240
I hesitate to ask this for fear of looking stupid but here goes...
Why do you need N in a car wash?
Current: Portimao Blue G21 330i
Previous: EB F30 340i Shadow Edition Previous: EB F30 330d xdrive |
11-08-2019, 01:41 AM | #41 |
Rep 969
Rhino at Work713.50 |
11-08-2019, 02:11 AM | #42 | |
Rep 1,863
11-08-2019, 02:34 AM | #43 | ||
Rep 251
Anyway I have come to terms with the fact it is me that needs to adjust to the car not the other way round. By the way I absolutely love it. Had it a week the had it remapped by DMS. Wow just wow |
11-08-2019, 03:02 AM | #44 |
Rep 424
