12-21-2019, 03:40 AM | #1 |
Rep 21
320D remap figures.
Morning gents.
As you will have guessed from the title I got the 320 remapped during the week and got some low figures. Does anyone know if the f31 has an engine safe mode or power cut if it realises the front wheels are not turning? I'm 30bhp down on what I was expecting. Car is a 2015 with 43k miles on the clock. It's possible that the engine has adapted to short journeys and very little high speed runs. The extra torque is very noticeable and I've already noticed an extra 2mpg on my daily drives. |
12-21-2019, 04:17 AM | #2 |
Rep 3,967
Yes it’s Definitely low on power, your figures are closer to an E46 320d before and after runs.
Who did the remap and before and after dyno runs? Has anyone checked it over for anything obvious like a boost leak etc? |
12-21-2019, 04:38 AM | #4 |
Rep 21
Haven't checked the turbo or anything as didn't notice any issues. Mate of mine has a dyno and the tune was done by him using Monster Tuning software. Custom map after the engineer saw my first dyno run.
It's a 320d M Sport + so I'm down about 30bhp. Not that it means much as I only drive 18 miles per day! |
12-21-2019, 08:25 AM | #5 | |
Rep 332
Do you hear any whistling noises? Maybe a boost leak? How is your air filter? Maybe it needs replacing. Or maybe their dyno is reading low... what gear did they use for the power run? I would go for a long drive with some additive in the fuel tank to clean things up a bit. Clean the dpf and injectors. No safety to cut power off. |
12-21-2019, 08:27 AM | #6 |
Rep 15,858
12-21-2019, 08:38 AM | #7 | |
Rep 332
12-21-2019, 08:53 AM | #8 | |
Rep 21
No whistling that I can hear. I'll get the DPF looked at and I'll try putting additive into the fuel tank. Air filter was new in July so it shouldn't be that but worth checking. Thanks fantana. |
12-21-2019, 08:54 AM | #9 | ||
Rep 332
12-21-2019, 09:01 AM | #10 |
Rep 15,858
12-21-2019, 09:03 AM | #11 | |
Rep 332
Worth checking I guess. |
12-21-2019, 09:15 AM | #12 |
Rep 15,858
12-21-2019, 12:28 PM | #13 | ||
Rep 8,498
12-21-2019, 04:21 PM | #14 |
Rep 3,967
For some reason Jason at BW Chiptune uses 3rd gear on these auto boxes
12-21-2019, 05:36 PM | #15 | |
Rep 8,498
Seemed odd, considering everyone else (where I've been, and Web research) seems to use 5th (iwhich s close to a 1:1 ratio). 3rd and 6th are torque-limited, so using 3rd makes no sense.
12-21-2019, 06:42 PM | #16 | |
Rep 3,967
12-22-2019, 02:51 AM | #17 |
Rep 8,498
Sounds like he's told different things to different people.
A dyno should be set up to give an accurate reading of the true output as a starting point, rather than a theoretical published output. I do think it's strange he uses 3rd when 3rd is torque limited by the TCU. Anyway, ETTO their own on that one.
12-22-2019, 05:13 AM | #18 | |
Rep 3,967
I think we can agree though at least from the example I posted above which was tested in 3rd gear, it does make roughly the power you would expect from both stock (268) and PPK (295) so the remap reading (328) is likely to also be fairly accurate. I get the point you make about the torque limit in 3rd though. |
12-22-2019, 02:32 PM | #19 | |
Rep 810
There does seem to be a torque flatspot at ~3000-3500rpm both before and after the remap which doesn't seem to be common to the N47. I would try to see if anyone has done any MAF & Boost logs to compare them to your own. |
12-22-2019, 03:29 PM | #21 |
Rep 8,498
6th is also torque-limited though. I think that's why most remappers use 5th : close to 1:1 and full torque available (up to the gearbox limits anyway).
HighlandPete6658.50 |
