12-29-2019, 01:13 PM | #1 |
Rep 810
Front-end Knock - When Accelerating hard on X-Drive
Hi All,
This is quite rare, but when i boot it from low speed and i presume the X-Drive is pushing the Torque to front wheels, i occasionally get a single loudish clunk from the front left. I'm pretty sure its not the rack as i fitted the updated parts and it now feels tight with no slop. I also don't think its the ARB droplinks either as the car is quiet around corners and over bumps. Any ideas what it could be please? The car does also make a pinging noise also from the front left when reversing and turning - i suspect it could be top-mount related? Thanks and happy new year! |
12-30-2019, 01:38 PM | #5 |
Rep 6
I had the same symptoms. It was a broken motor mount bracket. Here’s to hoping that if yours is broken, it’s the right side. That one is 1/3rd the price of the left.
12-30-2019, 03:49 PM | #6 |
Rep 810
Wow thanks for the suggestions guys, I'll check all those things. Pretty sure it's not the spring as give given it a good feel, plus I bloody hope it's not the transfer case! It definitely feels like a front left knock.
Thanks mate, did you manage to spot the damage or is it a case of using a prybar to check it? |
01-01-2020, 10:14 AM | #7 |
Rep 6
I am lucky enough to to have an extended warranty so the dealership saw the damage. But apparently it’s obvious from underneath once the panels are all removed.
When I get my car back it should have the broken part in the trunk. I’ll take pictures of it and post here. |
