10-20-2012, 10:34 AM | #1101 | |
Rep 145
Drives: F30 320ed
Rubber tyre valves here... |
10-20-2012, 11:00 AM | #1102 | |
Rep 40,785
10-20-2012, 01:48 PM | #1104 |
Rep 40,785
Sorry. FTMS (RPA)
10-20-2012, 03:23 PM | #1105 |
Rep 1,544
TPMS is only fitted on US-spec cars, it isn't available on any other country even as a cost option. Flat tyre indicator is standard tho for those countries.
10-22-2012, 06:09 AM | #1106 |
Rep 171
A few people (can't locate their posts) have been asking about opening the tailgate w/o unlocking doors.
Correct me if I'm wrong but this is a default option here on my car (Belgium, thats EU for you yankees ) idrive -> settings -> locks -> second option available iirc Also I'd love it if anyone can send me the links for esys as well. I probably cant receive PM yet so here's my mail (laraake@'remove'gmail.com) Last but not least, any Belgians/Dutchmen/Germans who could help me coding? I live close to Aachen, but willing to drive around abit |
10-22-2012, 06:55 AM | #1107 |
Rep 171
just went out for a quick check and its:
idrive -> settings -> door locks -> 2nd option "Tailgate" open it and ou can select for tailgate only/tailgate + doors |
10-22-2012, 08:40 AM | #1108 | |
Rep 108
10-22-2012, 08:45 AM | #1109 |
Rep 1,044
Has anyone played around with options trying to set the power steering in Comfort mode to the effort level of Sport mode?
I know this is deep in an ECU somewhere. If nobody has tried this, does anyone have theory on which module might contain the settings? This is an MY12 N55 ZSL, June 2012 production.
MY18 X3 30i:
Produced: 2018-03-15; Delivered: 2018-03-29 MY19 X3 M40i: Produced: 2018-08-15; Delivered 2018-08-22 |
10-22-2012, 08:49 AM | #1110 |
Rep 802
Can someone please sehd light on how to create a back up of my cars files before I begin coding (or please direct me to the correct document). Went through a bunch of the documents, and couldn't find it. I want to code today/tomorrow (all software on the laptop is up and humming ... have the cable ... just want to make sure I have a back up in the event that something goes wrong).
10-22-2012, 11:47 AM | #1111 | |
Rep 1,892
Then go to explorer and navigate to the CAFD directory (mine is C:\ESysData\CAF) and copy the .ncd files somewhere safe. The .ncd (net coding data) are the value sets for each CAFD. If you have to revert them, you can use those to restore the settings to the factory defaults. I've also heard that you can restore to factory vales by selecting the "Code" option when the CAFD is active. I have not tried it myself. I think Shawn is the expert on this. |
10-22-2012, 11:54 AM | #1112 | |
Rep 1,105
So may be ur solution shall be helpful to me too |
10-22-2012, 12:59 PM | #1113 | ||
Rep 802
10-22-2012, 01:22 PM | #1114 |
Rep 171
10-22-2012, 02:37 PM | #1115 | |
Rep 40,785
10-22-2012, 02:41 PM | #1116 |
Rep 40,785
Yes, but what is standard in Belgium isn't always standard elsewhere, hence really the whole premise or coding ones car. So, behind your standard iDrive option lies an FDL code that must be set to enable that option on non-Belgium cars, that others outside of Belgium will have to code.
10-22-2012, 04:52 PM | #1117 | |
Rep 45
How do I restore from my current saved files? I know it's written in this thread somewhere, but I honestly didn't understand how to do it. On an (important) side note, I also have 2 problems: 1. I modified V_SCHWELLE_1 and V_SCHWELLE_2 within REM_01 AND from within PMA, but the rear view camera and the top view camera still can't be activated at high speeds. Any ideas, please? 2. In the F10 cheat sheet there is FLA_AUTO_AKTIV under FRM module, it sets High Beam Assistant to Automatic On. Is there a way to do this on the F30? The F30 has no FRM module and I have no idea which one is its "counterpart". Last edited by rolandleth; 10-22-2012 at 05:07 PM.. |
10-22-2012, 09:11 PM | #1118 |
Rep 12
Hi to all
I picked up a new F30 (328i) about a month ago and am now keen to get into some coding. My cable arrived a few days ago - from Codecard so now I need to get hold of the software and data files. Could someone (shawnsheridan ) please send me a link to download them ... rs3tier@gmail.com Thanks for any help. |
10-22-2012, 10:17 PM | #1119 | |
Rep 40,785
10-22-2012, 10:18 PM | #1120 | |
Rep 40,785
10-22-2012, 10:46 PM | #1121 | |
Rep 1,892
For example: 1. You save an old .ncd file for CAFD_001_002_003 (made up number). 2. Service updates the module to CAFD_002_003_004. 3. You apply the 001_002_003 ncd file to the 002_003_004 software version. Isn't there some risk that the .ncd layout changed between 001_002_003 and 002_003_004 that would completely screw up the FDL data? i.e. if you changed the value for RDC_SAFETY, are we sure that the value location in the saved .ncd file is always going to be in the same regardless of the software version? I would think it would be safer to just re-code everything field by field with the new CAFD files. |
10-22-2012, 10:51 PM | #1122 | |
Rep 40,785
