BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > Navigation, iDrive, Audio, Video, Bluetooth, Phone, Cameras, Electronics > USB stick for audio
      12-16-2012, 01:13 AM   #23
Sirrus
Sirrus's Avatar
Drives: 2013 335i M Sport
Originally Posted by RPM90 View Post
This thread reminded me that I do have a USB input.
Now I'm going to load up some .wav files.
Your system should support Lossless WMA. I've been using those on my e92 for a while and they also worked on the HK system I test drove last week. The only gotcha is to make sure they don't have a bunch of extraneous metadata / tags.
      12-16-2012, 10:27 PM   #24
RPM90
Drives: 340i M-sport AT
Cool. Thanks.
      12-17-2012, 03:05 AM   #25
zibawal
Drives: 2012 X5D
Originally Posted by Dabaitu View Post
Your issue with the car's HDD is that it doesn't rip from a CD at a decent bit rate AFAIK.
You're better off doing what the OP and I do, which is RIP to a WMA lossless or 320 rated file and store it on a USB. It will pick up album art too if done correctly, and the 32GB Sandisk I use is about half the size of a thumb.
What is the best software to rip WMA lossless?
      12-17-2012, 04:29 AM   #26
MikeVictor
210
Windows Media Player (WMA = Windows Media Audio)
      12-17-2012, 11:37 PM   #27
Sirrus
Sirrus's Avatar
I like dBpoweramp.
      12-18-2012, 03:19 PM   #28
Mamasgotkids
Drives: BMW X3
Does anyone have tips for getting ALL iTunes - Apple purchased music uploaded? That's all we have. I could never get it to load onto my VW hard drive. VW even told me it wasn't supported (which sucked). Since this car is only 2 days old I haven't gotten around to trying it yet.
Current: 2019 X3
Past:
2006 328d Touring, 2008 318i, 2008 118i, 2012 328i
      12-23-2012, 07:26 PM   #29
RPM90
I can't help you with the iTunes question. I don't like using iTunes for that very reason, Apple is much too restrictive in allowing people to use the music they paid for in any manner they want to use it.
My suggestion is simply to use your ipod device and plug it in via USB or use the audio cable supplied by BMW that goes from your ipod to a stereo plug. The plug then plugs into the input inside the center armrest.
It sounds just as good.
Sorry I couldn't answer your question. Hopefully someone will chime in and tell you how to do it. IIRC there is 3rd party software that may let you do what you want, which is getting the audio files off you iTunes and onto your HDD.
This may or may not work, but what if you created a CD using iTunes and then put that CD in the CD player, then see if he audio system will rip the audio files from the CD and onto your HDD, just as it would with a regular audio CD.
Just make sure to create an actual audio CD and just use the CD as a file transport, IOW, burn an actual audio CD with your iTunes music.
      12-24-2012, 01:59 AM   #30
RichardM
England
133
Drives: G21 M340i LCI
Can you not just copy the files from the iTunes music folder on your PC to the USB stick? That's all I did.
      12-24-2012, 07:33 AM   #31
yepeztroncoso
Dominican Republic
Drives: 2013 BMW 3 Series Luxury 320i
I noticed i cant save the files frmo my USB to the car HDD. It seems tracks can only be recorded via CD.
      12-24-2012, 08:05 AM   #32
TonyS
Drives: F30 335i
Yes you can. You need to plug your USB stick into the socket in the glove box for it to work. However, the whole implementation is completely b*ggered and useless as far as I'm concerned, to the extent that I've given up using it and just have all my music on a tiny USB stick in the centre console, which works so much better.
      12-28-2012, 03:59 AM   #33
Micleg
iX1 2022
35
Drives: iX1 msport, 520d F11 X08
Playlist problems
Have any of you guys any problems with the playlists on the USB stick?
I got a USB3 Kingston Hyper-X, yeah I know, total overkill, but I wanted it to be fast when transferring from a PC.
The first batch of music files and playlist files worked fine although sorted from Z to A.
Then I added some more music and playlists only to see most of them not appear on the display! And the ones that showed up were put on top of the last one, listed before Z, Y, X... but in random order.
It's all crazy. By the way, I have an F31 with the new prof nav system and HK audio.
      12-28-2012, 04:50 AM   #34
RichardM
England
133
That's only for the old Nav. The new Nav doesn't have the USB socket in the glovebox any more, it's all done through the centre console socket.
      12-28-2012, 04:54 AM   #35
TonyS
Drives: F30 335i
Ah - wasn't aware of that difference.
      12-28-2012, 05:05 AM   #36
RichardM
England
133
I spent a while looking for it to load music
      01-02-2013, 05:53 PM   #37
Jeffersontp
Drives: 2013 328i M Sport
Good to know. I wasn't having much luck transferring music to the harddrive.
      03-02-2013, 04:00 PM   #38
DJHakim
DJHakim's Avatar
23
Drives: 330i xDrive
Does the 2013 F30 iDrive manual (can't find e-version) specify what formats are supported? I wonder if WMA lossless support is official.
F34 (2019 330xi): Luxury, ZCV, Nav, ABSD, Alp White
F34 (2016 328xi): Nav, ZDA, Alp White
F30 (2013 328xi): ZCP, Nav, PDC, Alarm, Shades, GS Metal [Ret]
E90 (2009 328xi): ZCP, iDrive, BMW Assist, PDC, Alarm, Shades, SG Metal [Ret]
E90 (2006 325xi): ZSP, ZCP, iDrive, BMW Assist, PDC, CA, Xenons, Shades, CrO3 Exhaust, TiAg Metal [Ret]
      03-02-2013, 04:20 PM   #39
zibawal
Drives: 2012 X5D
Some one suggested to use WMA but it was no go
      03-02-2013, 10:47 PM   #40
Sirrus
Sirrus's Avatar
I don't know if it's official, but I'm using it. If having trouble, remove as much tagging info as you can.
      03-27-2013, 12:42 PM   #41
momo3605
Drives: M340i LCI, 718 GTS 4.0
I'm trying to use wma lossless as well but it says file not supported. It works fine in my e9x 3series though
      03-27-2013, 03:36 PM   #42
dzaborn
Drives: 2019 BMW 440i GC
I ripped direct from CD to WMA lossless using WMP12 in Windows 7 and had no issues playing from a USB drive in my F30.
My disappointment is that the F30 playback is not gapless (as should be the case with lossless formats). The abilty to achieve gapless playback was my main reason for trying out a lossless format (as opposed to sound quality).
      03-27-2013, 03:48 PM   #43
zibawal
Drives: 2012 X5D
my tracks play in m3 not in f30?
      03-29-2013, 01:52 PM   #44
DJHakim
DJHakim's Avatar
23
Drives: 330i xDrive
I have Lossless WMA files that BMW sees, but does not play. It skips them. Media rights are not set for them. They do have a bit rate of >1 Mbps. Other lossless WMA files play fine. All were ripped from CD in WMP.
In the printed F30 Navigation/Entertainment manual (p. 51, top/right), BMW states that playback cannot be guaranteed for bit rates >256 kbit/s. This sux BIG TIME if I have to batch transcode my files to 256 kbit/s!!!
